Question about Whirlpool Washing Machines
Its a cabrio washer
F70 and f51, i have replaced shaft and bearings and rotor position sensor and wires, got the same codes again you think its the moder board?
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the model number?
Posted on May 13, 2014
  • jamie osborne
    jamie osborne May 15, 2014
    w10199994
  • Richard Roth
    Richard Roth May 15, 2014
    You will need to replace the control board. Remove the 3 screws on the back of the control top to access it. Here is the part to order.http://bit.ly/1qGIuka
the dr
  • 447 Answers
SOURCE: Whirlpool washer Cabrio WTW6600SB1
Its the Rotor Position Sensor very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
reg501
  • 413 Answers
SOURCE: F51 error with Cabrio washing maching
This has been a troublesome issue for Whirlpool and may of Whirlpools customers. The F51 code indicates a problem with the RPS (Rotational Speed Sensor) that monitors the motor speed. This issue has been identified as relating to the the connection system between the RPS and the controller.
Whirlpool has changed the RPS connector design, providing a more reliable connection and is available as a service kit. The control has also been updated for better sensing of the RPS. Also, if you have experienced problems with certain wash loads getting tangled and knotted, there is also an update washplate intended to reduce this issue. You should contact Whirlpool for possible repair concessions related to these issues.
If you would like to get to the RPS.. Here's how:
In some cases, the F51 code can be fixed by cleaning the RPS connector. The RPS is located on the motor armature underneath the machine.
1. Tilt the machine backwards, resting the console against the wall.
2. using a disposer tool or suitable hex wrench loosen the center stator screw completely (the screw is captive and will not fall out of hole).
3. The stator contains a series of strong magnets and will take some tugging and wiggling to pull off.
4. Remove the 4 bolts that secure the armature to the tub. CAREFUL this assembly is a little heavy, support well before removing last bolt.
5. The RPS is attached to the armature. Remove and insert RPS connector (the one with 6 wires) 10 times to 'wipe' the contacts providing a cleaning action.
If I can assist you further, please let me know
reg501
The FixYa Team
Posted on Jun 21, 2008
  • 39 Answers
SOURCE: Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Posted on Jun 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Cabrio Washer
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Posted on Sep 28, 2010
Macmarkus
  • 2605 Answers
SOURCE: whirlpool cabrio washer showing F51 error code
Hi Craig,
Just saw this post come up among F51 error codes (as it will show previously posted and answered questions ) and wanted to add some info I have regarding this exact issue you may or may not already have, no harm in posting either way.
The F51 typically indicates a failed "RPS" has been detecected...but it can be the result of other issues...just for future reference and if anyone has not come accross this before.
The scenario you describe is usually associated with a item stuck under the tub or a loose stator or a faulty "RPS" device or connection at the "RPS"...but I don't know if you checked that yet or if you know how, thus the error F51.
**The repair tip below is directly from Whirlpool**
F51 is usually associated with the rotor and stator/RPS assembly and quiet often it is initiated due to a loose rotor or bad RPS...I'd start by checking the bolt.
There is a repair tip regarding this which suggest checking the wires to the RPS and then the rotor, while insuring the center bolt is really tight via applying some "lock tight".
I actually see a lot of these and most times it's a loose rotor bolt, that is where I always start my diagnosis. Here's an exert from my files directly from Whirlpool...
You may want to check the rotor, I've seen the center bolt become extremely loose, thus causing the F51 error, this is where and what to look for shown below...
...but either way that should help out with the repairs and good luck.
Regards,
Macmarkus :)
Posted on Dec 22, 2011
What does F 51 mean?
The F51 fault code on your Cabrio washer indicates that the control board is not sensing the proper drive motor spin. To clear the fault code, press the Pause/Cancel button.
Make sure that the drain hose is not stuck way down the stand pipe. This can cause siphoning of fill water which will inhibit proper motor rotation.
Check to see if the wash basket spins freely. If it does not, you may have an item of clothing stuck between the outer tub and the inner basket. This restriction in rotation will also cause an F51 fault code.
If these tips do not help you resolve the F51 problem, then you probably have a component failure. Possible failures include: wire harness or wire connection problem between the machine control and the RPS sensor (Rotor Position Sensor), a failed RPS sensor, a failed drive motor, and a failed machine control board.
Mar 08, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not spin code 51
Hello there and thank you for choosing fixya
This is the Cabrio washer. F51 fault code is likely the Rotor Position switch failure, located on the motor. Even though it might run, the Hall sensor inside it has gone out. The Cabrio manual is in the Online Repair manuals Forum which you may jump to from any page at the bottom right if you want to test motor resistance from the convenience of the console. Many people mistakenly replace the main control board in hopes of correcting this issue but it is actually a communications error between the Hall sensor and the main board.
There is a Rotor Position switch kit which should correct the problem, and comes with a new harness and excellent instructions. picure below :
Jan 26, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Unit had a f51 code. took back off and top control panel off check all connections and run it a couple of cycles and it seems to be working now. But it sounds like i put a turbo in it. It is alot louder...
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit.
This can be caused by several different problems.
Make sure that you are not overloading the washer. Overloading can cause this problem.
A toy or foreign object could be under the washer that is interfering with motor rotation.
With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily.
If not, you could an item caught between the spin basket and the tub.
You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board.
A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question
Oct 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Sd 51
In addition to the above tips, check the installation of the drain line. Make sure that the drain hose is not stuck way down the stand pipe. This can cause siphoning of fill water which will inhibit proper motor rotation.
If these tips do not help you resolve the F51 problem, then you probably have a component failure. Possible failures include: wire harness or wire connection problem between the machine control and the RPS sensor (Rotor Position Sensor), a failed RPS sensor, a failed drive motor, and a failed machine control board. You will probably need a technician to diagnose and repair one of these component failures in your washer.
Aug 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code F 51
Jul 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What is the F51 error code
its the rotor sensor and control bord that need replacing here is a link to help you understat the problem
http://cabriof51error.blogspot.com/
Jul 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer shows the code "F" 51. I looked in the book and it just said if I hit cancel and it comes back to call for Repair. What does it mean though?
It is very common on this washer.Basically the F51 error is
due to the rotor position sensor error.The two parts realy needs
to be replaced.
1.rotor sensor itself
2.the control board
Apr 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
IT SAYS F51 ON THE DISPLAY IT DOES NOT LET MY WASHING CYCLE FINISH
You have the F51 code. The reason could be due to an intermittent connection at the rotor position sensor (RPS). To correct this, remove and install the the connector at the rotor position sensor (plug and unplug) at least three times to clean off any corrosion build up on the connector or the rotor position sensor due to the intermittent connection.
Confirm that the connector is fully seated onto the rotor position sensor upon final connection and verify that there are no damaged wires. The electronic control unit may have to be replaced, since the upgraded version is less sensitive to intermittent RPS connections.
Sure hope this helps you and best wishes.
Aug 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio f51
at each corner of top is a clip ..with a putty knife locate clips and push inward lift top either on front panel or side panel i belive you'll find the tech manual possible cause may be the rotor position sensor or it's connection ..good luck any electronic problem can be a real bear by the way that motor /rotor idea is a fisher paykel
Jul 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
