Question about Mantis Tiller
Why does a honda f210 tiller only run with full choke?
2 Suggested Answers
  • 208 Answers
SOURCE: My tiller won't run after cold start, after choke
Watch this video and do it.
http://www.alamia.us/mantis_parts_s/148.htm
Posted on Feb 20, 2011
Tiller won't start
well I would be checking the gas first...
Dec 01, 2013 | Garden
Pull starter honda f210 rope has come off
remove the starter cover whined the spool in the opposite direction that the rope pulls out hold it into place with a knot on one end feed the other end threw and out threw the opening pull it threw and tie on the pull handle
Aug 18, 2012 | Honda Clutch Cable F200 F210 F260 Tiller
Honda mini tiller cuts off when start tilling. runs great when held above ground with no load. cut off seems to be associated with the movement and shacking when tilling ground.
Hi thermo259, sounds like the high speed adjustment is lean, find the high speed screw and turn it counter clockwise 1 half turn and see if that helps. Should cure it.
Dec 10, 2010 | Honda 25cc 4-cycle Mini Tiller
Engine does not continue to run
Are you laying off the choke at any point? Full choke should only be used when starting a cold engine, it should run with no choke on full throttle. If there is not enough throttle i'd first try adjusting the tiny black screw on the carb beneath your air filter while you have it idling, letting the throttle have a little bit more room. If this doesn't work and you're running it properly than you may need to make some adjustments to the H L settings for your gas/air mix. This is also done while idling mind you and only with a clean air filter.
Apr 02, 2010 | Honda 25cc 4-cycle Mini Tiller
Having carburetor problem with honda f210 tiller and it won't stay started
I need the year make and model. This sounds like you just need to adjust the idle screw or clean the carb with some carb cleaner and it should be good to go
May 16, 2009 | Honda Garden
Need new carburetor
I will check to see if I can get you one at a resonable price.
May 07, 2009 | Garden
Honda f210 tiller leaks gas when not running. if you leave the gas valve on it leaks on the floor. if you start it you have to regulate the amount of gas going into it, or it will flood out. it runs rough...
yes that's the problem.float level...you remove the float bowl and bend the float until it is at the factory specs.get you a manual and it will tell you the float height.if it says 4/32 you get you a 4/32 drill bit.put *** under the float chamber and bend until the bottom of the float touches the bit.
Apr 29, 2009 | Garden
Cannot keep tiller running
Could a gas/oil mix been used by mistake. When you cleaned carb did you also clean dusty air filter?? Try leaveing off filter first and run. Are you sure you are in "choke position" when engines seems to be running ok,be sure to double check yourself here. If engine runs ecelleant in "choke" sounds like your in "Run" position and positioning is problem not performance.
Please rate. Thanks jj505
Mar 28, 2009 | Garden
Mantis Tiller Logo
49 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
