Question about Kenmore 51262 / 51264 / 51269 Side by Side Refrigerator
Does kenmore top freezer model 106.71202100 have electronic control board
5 Suggested Answers
SOURCE: Kenmore fridge electronic defrost manual start procedure
unplug overnight started OK
Posted on Jun 22, 2009
  • 180 Answers
SOURCE: kenmore fridge. freezer top works, but bottom doesn't.
Either your fan has stopped working, or it is not defrosting. Take the back panel of the freezer off and see if the evaporator coil is iced over, if it is replace the deforst heater, and the deforst thermostat. If the compressor is running the fan if the freezer should be running. Also make sure both your fridge and freezer controls are centered. Putting the freezer on the coldest setting acutally shuts off airflow to the fridge.
Posted on Dec 05, 2009
SOURCE: Have a Kenmore Chest Freezer
hallo guten abend ich heise ekrem und habe ein problem koenen sie mir bitte helfen
ich kan nich ein arbeit finden und ich schafe nicht im ausland gehen und geld verdienen
Posted on Jan 15, 2011
richroth
  • 9472 Answers
SOURCE: kenmore top fridge not cooling bottom freezer working fine
Do you see ice on the back of the freezer wall?
Posted on Oct 19, 2012
Where is the main electronic control board located in a Kenmore Elite Model #596.76253702 ?
Hello Mike;
My name is Peter. I am a retired field service refrigeration technician.
UNPLUG YOUR UNIT BEFORE STARTING ANY WORK!
Your defrost problem may be your control board but, that is not where I would start.
In answer to your question, your control board is in the top front of your freezer section. When changing the control board ground yourself by rubbing your hands on something steel. Static electricity will knock a control board out.
Part number 12784415 - $120.00
More likely your problem is your defrost heater. You check your defrost heater with a multi-meter. Set the meter to the lowest Ohm setting. Place one meter lead on one end of the heater connector and the other lead on the other end of the heater connector. If the meter reads '0' or OL or infinity the heater is bad. It should read something like 35 or greater Ohms.
Part number 12729128 - $47.00
When changing you defrost heater it is common practice to also change the Bi-metl-def.
Part number W10165425 - $26.00
Both of these components are located behind the back freezer wall.
This is a major task to change these components. Bottom freezers are not service friendly.
1.) Completely empty the freezer (Unplugged).
2.) Take off the freezer front door.
3.) Remove the ice maker assembly.
4.) With a screw driver pop off the thermostat cover plate in the back upper right.
5.) Unscrew the back cover.
6.) Remove the center air vent. This is held in with plastic tabs. with a screw driver pop up the center tab and the side tabs.
7.) Pull the back cover out. You will need to flex the cover to clear the side rails.
Unless you are really good with basic electrical and hand tools, I do not suggest you attempt this repair.
A local service company will charge you about $400.00 or more.
Dec 02, 2014 | Kenmore Refrigerators
Defrost timer
The defrost timer is part of the electronic control baord located on the back of the refrigerator. If the freezer is not defrosting check the thermistor on the evaporator(freezer) coils. It can cause the control board to thing it doesn'y need defrosting. a common problem
Mar 22, 2014 | Kenmore Side by Side Refrigerator
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
The top part of the refrig keep freezing?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Apr 14, 2010 | Kenmore 71279 Bottom Freezer Refrigerator
Self defrosting not defrosting not cold in bottom of frig has top freezer
How to checkeverything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. Inmost newer models the timer has been replaced by an electronic control board.If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicksand everything shuts down. The heater should now come on. If it does, replacethe timer. If it doesn't, check the heater and defrost thermostat. Turn thetimer again till everything starts back up to end the defrost cycle.
Sep 06, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore upright freezer no digtal light no motor running
if it is an electronic control freezer then the electronic control sounds as though it has failed if there is no digital read out
May 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore side by side frig
hi!!! it looks like you have a problem with the damper control mechanism inside your frig section..most all new model have an electronic board.replace that and you should be fine..good luck..
Jan 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Banging noise from fridge
If i was in your shoes i would buy a new one,sorry,close,eire
Dec 16, 2007 | Kenmore 64192 / 64194 Top Freezer...
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore 51262 / 51264 / 51269 Side by Side Refrigerator Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
