Question about Makita 10" Miter Saw LS1030N
How do i reassemble the blade guard makita ls1013?
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: i need step by step on putting blade guard back on Makita LS1013
Go to Makitatools.com and in the header type in your model number and just follow thru till you can download a parts breakdown with exploded view of the guard. Just lay parts out in the order you see them and its not hard to reassemble. Might I ask what happened to guard? If you stilll have problems let me know and I will help. If I have helped you with your request would you please rate this response accordingly. Thank you.
Posted on Sep 12, 2009
  • 15 Answers
SOURCE: How to remove guard and
Theres a nut on the guard you need to loosen. Guard will then open enough to change blade. if you want to remove it completely theres a phillips srew you also need to remove.
Posted on Jan 25, 2011
rowdy45176
  • 2176 Answers
SOURCE: How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Posted on Jul 12, 2011
How do I view the owners manual on line for a Makita LS1013 sliding miter saw
I have attached a link with the parts breakdown and the owners manual both in PDF format.
The parts breakdown should help you, if not let me know and I'll try to talk you through it.
Makita Products Tool Support
Mar 11, 2015 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Makita LS1013 saw head is frozen tight and will not move down freely to cut position How is the head disassembled from the body of the tool?
With problems like this, I would always recommend getting in touch with your local Makita service agent, details of which will be on the Makita website, then using the dealer locator tab.
However, before thinking about taking the head off, have you checked all other options. Does the lock pin have free movement and is it well clear of the cast arm? Is the guard and guard release system working properly. The arm will not lower if the guard isn't retracting properly. You should also make sure the cutting arm linkage and spring are clean and lubed (WD40 should be fine). The arm is under tension due to the return spring so make sure that is secured/removed first, then remove the pivot pin and the arm should come away. Click here for a diagram, the spring is on page 1, position 13 and the pivot pin etc is on page 2, pos 85/86/87/96/95. The guard and associated parts are also on page 1.
Oct 12, 2013 | Saws
How do u change out bushes on a makita ls1013
there are 2 black screw caps on the outside of the tool that need to be removed. USE a good quality blade and right size to avoid chipping the caps. UNPLUG TOOL first and remove the old ones and replace with new and reassemble. They might arc for a short period of time depending on the commutator wear. Run at NO LOAD for about 10 minutes. Let me know if you still have a problem
Apr 05, 2012 | Makita 10" Dual Bevel Sliding Compound...
How do u remove the blade on a chop saw ls1013
Be sure the saw is switched off and unplugged. Use the Makita socket wrench on the side of the saw base if you still have it. If not make sure you use a socket or wrench that fits the bolts properly so you get them off and back on without damaging them. Lock the handle in the up position with the stopper pin. Loosen the hex bolt holding the center cover in place, this will let you raise the guard and center cover so you can get at the blade bolt. There is a button on the back side of the blade guard that locks the spindle. Push and hold the button in and turn the blade until it locks in place. Using the socket wrench, turn the blade bolt clockwise or in the same direction the blade turns while cutting to remove it, the outer flange and blade. Put the new blade on (check that the direction of the arrow on the blade is the same as on the guard), the outer flange and blade bolt. Use the spindle lock to get the bolt on tight. Return the center cover to it's original position and tighten it's hex bolt. Turn the blade by hand to make sure the spindle lock released then pull the stopper pin and make sure the blade guard works properly.
Feb 03, 2012 | Saws
How to remove guard and blade on LS1013
Jan 24, 2011 | Makita 10" Miter Saw LS1030N
The spring in the blade guard came out while replacing the blade
Hello. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist you. If this is helpful, please rate it a four-thumbs up, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
Dec 14, 2010 | Makita 10" Miter Saw LS1030N
How to replace saw blade and re assemble the blade guard
Hello. The guard does not have to be taken apart when changing the blade. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist. If this is helpful, please rate it a four-thumbs up, Thank You.
Oct 10, 2010 | Makita 10" Miter Saw LS1030N
How do I install the spring after changing the blade on the Makita 10 miter saw
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Jan 16, 2010 | Makita 10" Miter Saw LS1030N
I need step by step on putting blade guard back on Makita LS1013
Sep 12, 2009 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Makita 10" Miter Saw LS1030N Logo
230 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
