Question about Dryers
Electrolux dryer T4190 making lot of noise during running
Is 440 volts 3 phase 60 Hz on my ship
  • Leon D'penha
    Leon D'penha May 13, 2014
    When the dryer starts its not noisy. When it picks up speed the noise starts.Removed the drive motor found bearings good condition. The blower motor also in good condition.
  • 2,509 Answers
The rear bearing (doesn't fail as often) front bearings (which are just nylon pads and do often wear) and the belt tensioner should be looked at. Rotate by hand and look /listen, you should be able to locate the problem
Posted on May 13, 2014
  • 142 Answers
SOURCE: Kenmore Heavy Dut Model 86427810 runs but does not heat
You need to have a look at the thermal protection devices and the thermostat section and make sure they are functioning such that power is reaching the heating elements. If they are and there is still no heat, the elements are probably malfunctioning. If the dryer is producing ANY heat, then the thermostat and thermal circuit is OK, and all you need are elements.
Posted on Apr 16, 2008
SOURCE: whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Posted on Feb 02, 2009
SOURCE: Gas Dryer coil glows but no flame
Sounds like you need to replace your coils. Probably only one of them is bad, but why hassle with determining which one when you can get a pair for about $20 (the other one may be ready to fail soon anyway).
Posted on Jul 12, 2009
  • 491 Answers
SOURCE: GE Dryer works but keeps stopping after only 5 minutes
IT SOUNDS LIKE YOU NEED TO REPLACE TERMOSTATS.
Posted on Oct 19, 2009
  • 46 Answers
SOURCE: dryer wont get hot
check thermal fuse
Posted on Jan 21, 2010
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
We bought electrolux washing machine ewf 85761 in penang malaysia, before we brought on board ship test is done on the store,the washing machine is in good condition..Then we brought the washing machine on...
Just as a wild guess, the control circuit in the washer may not work with 60 Hz shipboard power. The motor probably is not affected. You must be getting awfully tired of hauling that washer back and forth!
Sep 07, 2012 | Washing Machines
The voltage in my country is 230volts 50HZ I have a 120/240 volts maytag dryer what can i do to get it working
Normally the 240 volts rating is nominal and the device will run at 230 volts. The question is will the dryer run at 50 HZ? Check on the electrical rating tag on the machine. It may work. The motor may just spin at 50/60, 5/6 of the 60 HZ speed.
Gary
Aug 31, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a WESTINGHOUSE WELDER type rs 250 that is wired for 440 volt and need to change to 220 volt.
HI:) If that is a 3 phase 440 volt and you want it to use 220 volt 1 Phase you will have to get a phase inverter to change it from a 3 phase to a single phase.
Dec 19, 2010 | Welding Tools
I have small 3 phase motor with 440 volts. my power supply is only 220 volts 1 phase. its posible to use this motor? if yes what is the connection to be made?
Not without adding a phase converter which will cost as much or more than just purchaing a new 1~ motor to use instead. For more information about phase converters if you want to go that route just google the phrase and you will get a lot of hits.
John
Aug 21, 2010 | Pool & Spa
ELECTROLUX DRYER T4190, error code E08 flashing on panel. have tried turning power on and off, but still flashing. problem?
How to solve this problem
Aug 14, 2010 | Electrolux Dryers
What type of powercord and outlet does this dryer require? Electrician installed a 220 outlet.
ELECTRICAL REQUIREMENTS
ELECTRIC Dryer
CIRCUIT - Individual 30 amp. branch circuit fused with 30
amp. time delay fuses or circuit breakers.
Use separately fused circuits for washers and dryers, and DO
NOT operate a washer and a dryer on the same circuit.
POWER SUPPLY - 3 wire or 4-wire, 240 volt, single phase, 60
Hz, Alternating Current.
POWER SUPPLY CORD KIT - The dryer MUST employ a 3-
conductor power supply cord NEMA 10-30 type SRDT rated at
240 volt AC minimum, 30 amp., with 3 open end spade lug
connectors with upturned ends or closed loop connectors and
marked for use with clothes dryers.
WARNING – Risk of Shock. Appliance grounded to neutral
conductor through a link. Grounding through the neutral link is
prohibited for (1) New branch circuit installations (2) mobile
homes; (3) recreational vehicles; and (4) areas where local codes
do not permit grounding through the neutral, (1) disconnect the
link from the neutral, (2) use grounding terminal or lead to
ground appliance in accordance with local codes and (3) connect
neutral terminal or lead to branch circuit neutral in usual manner
(if the appliance is to be connected by means of a cord kit, use
4-conductor cord for this purpose). USE COPPER CONDUCTOR
ONLY. The dryer MUST employ a 4-conductor power supply
cord NEMA 14-30 type SRDT or ST (as required) rated at 240
volt AC minimum, 30 amp., with 4 open end spade lug
The complete installation manual is at ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134917700es.pdf
Jan 28, 2009 | Frigidaire FEQ1442ES Electric Dryer
I have a Teco Inverter JNEV-203-H1 The Input is 230 volts , single phase AC, 60 HZ The output is 3 phase, 230 volts, 60 HZ In the Instruction Manual apear how to program aqnd a list of parameters I am...
I found information about this issue in Internet
If you need additional informationin how to get it let me know.
Best Regards
Eliseo Ruiz
Industrial Solutions LLC
Gate Operators System
Power and Electrical Control Consultant
786-499-7333
Industsolution@aol.com
Jan 04, 2009 | Computers & Internet
Electrical requirements for a Nexxt MO# WTMC 5321US
it would be simpler and cheaper to get a new dryer
most of the world uses a single phase 240v 50hz system, your dryer is designed to run on a 2phase 120v 90degree system.
the common statement that high voltage items like dryers use 220-240v is not strictly true, instead they run off both 120v phases of the 2phase system.
A transformer to produce a 2phase 90degree 120v 20A secondary from a 240v single phase source is expensive and very large.
It would be cheaper by far, to sell the dryer, and replace it with the equivalent model built for 240v single phase, than to buy the transformer and ship the dryer.
Sep 13, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
