Question about Krups FME2 Coffee Maker
Why is the display not on, like there is no power to it?
It's plugged into a functioning outlet and it's as if there is no power to the device. No display, it won't brew. It's working like it's not plugged in, but it is. It's a couple years old and has been a trooper and this morning it's just dead. I tried to get into it but don't have a set of drivers to remove the bottom. Does it have fuses?
  • 2,509 Answers
There is a thermal fuse inside that's probably blown.
Posted on May 13, 2014
3 Suggested Answers
SOURCE: Froth control problems
Your vinegar did the job: it as removed the deposits, now these deposits are clogging the four holes porcelain valve.....if the froth lever is not broken.
Remove all the screw you can see on the top and under the top of it, remove the cover, unscrew the frothing device down to the porcelain valve consisting of two 4 holes discs, clean them, and voila!
Posted on Sep 22, 2008
  • 39 Answers
SOURCE: Dead Krups XP2070
I think you are right. Most likely the power board at the bottom. I saw a post about replacing the transformer but I when ahead a replaced the power module to fix mine.
Posted on Dec 29, 2009
No power when I turn the unit on
  1. Verify whether or not the date and time appear on your Brother machine's LCD. If anything is displayed on your Brother machine's LCD, then it is most likely receiving power.
    1. If your Brother machine's LCD is blank, continue toStep 2.
    2. If your Brother machine's LCD displays a message other than the date and time, please refer to the FAQ about the message being displayed for further information.
  2. Verify the Brother machine's power cord is connected securely to the power outlet. If you are using a surge protector, extension cord, or power switch, disconnect it and plug the Brother machine directly into the wall outlet.
  3. If the Brother machine is turned OFF, its LCD will be blank. Please make sure the Brother machine is powered ON by pressing and holding theOn/OfforPower Savekey. This key is located in the upper-right corner of the control panel.
  4. If your Brother machine's LCD is still blank, connect it to a completely different, known working power outlet. If the Brother machine powers up, then the problem is related to the original outlet.
    -OR-
    Confirm the power outlet is working by plugging another known working device (a lamp, radio, etc.) directly into the same outlet. If the other device does not work, the problem is related to that power outlet. If a wall switch controls the outlet, verify that the switch is ON.
  5. If your Brother machine still will not power on, please contact Brother Customer Service.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Nov 14, 2013 | Brother MFC-J220 All-in-One Color Inkjet...
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
There is no display on the hand set
ascertain that the device has display screens. second ascertain that the device is in functioning order or else is least connected to power outlets
Jul 20, 2011 | GE 29267GE3 Corded Phone
I CAN NOT CHARGER MY DEVICE IN USB
USB connection cables comprising of ports on computer telecommucnations devices are versatile outlets to managing multimedia. First the USB port on the device makes device to device connection where resoruces can be shared among several function requests. Second, the USB port on device least allows to derive power charge from another device only has to be attained from power outlet. For example, while a device is plugged into another device for media resources sharing is least like to attain power charging simultaneously. First use the USB port to power charge from an outlet to attain required functioning status. Circumspectively, the devices that have USB ports has several functions either as media resource sharing also for power circuit charging only each separarete process is attained where it is impossible to power charge a device while using the same port to derive functionality.
Feb 18, 2011 | Computers & Internet
My sony grand wega kdf e55a20 power light keeps blinking red. what can the problem be?
Red is an indication signal for power connectivity. Recent devices have two power functionalities. Using the remote control would turn off the display of images to power saver mode. A red power light imiting diode display is indication that requiring display of images is achievable by pressing on the display mode button once more. NOTES; Powering on the device may be achieved with the same function buttons as shutting down the entire Device to least communicate with the power supply circuity from outlet sources. The device is in power off mode ready for repower on with the remote control. Requesting the TV to shut down completely would require to press on the TV button firmly until power cuicuit are disbabled completely. Refer to the TV user guide to ascertain fucntionaility modes usual during operations. Goodluck
Jan 08, 2011 | Sony KDF-E55A20 55 in. LCD Television
Tower turns on but nothing appears on monitor
You need to follow the easy steps and get rid of it
1. Make sure your display (moniter, CRT, LCD, screen, whatever you prefer to call it) is plugged into a wall outlet or power strip and powered on. Also ensure that it is securely plugged into the back or bottom of your display. Many displays do not have removable power cords, making them more prone to shorts and other damage. Check your cable to make sure it isn't damaged.
2. Make sure the power strip or wall outlet that your display is plugged into are functioning by plugging another electrical device, such as a lamp, into it and switching it on.
3. Check the connection between your computer and your display. Make sure that it is completely plugged into both as well as fastened with the attached screws.
5. To double-check any possible cable problems, if at all possible, swap out the screen's power cord and the cable connecting your computer to your display.
6. Swapping out your display is also a good way of narrowing down the problem. If you get the same result with a different display, then you can be near positive the problem is something in your computer. If switching displays fixes it, then the culprit is a faulty display.
7. Try turning your display on and off. Does the power indicator light change? Green means On, amber means Standby, and no light means no power. If your display starts out green when it is turned on, then goes to amber, that usually means that it is not receiving any signal from your computer and therefore assumes it is not needed. The problem is most likely not with the monitor but in the computer.
Read more: http://www.brighthub.com/computing/hardware/articles/12648.aspx#ixzz0s9UQmWub
Please rate me if this solution works for you
Thanks......Have a great time
Jun 26, 2010 | Gateway 504GR PC Desktop
Describe your Epson im- 700 pos machine com portProblem Hi, We have IM -700 POS now its getting problem with printer and display. Showing com port error code 1001 pls any body can help
If you are getting display problem then
7. Try turning your display on and off. Does the power indicator light change? Green means On, amber means Standby, and no light means no power. If your display starts out green when it is turned on, then goes to amber, that usually means that it is not receiving any signal from your computer and therefore assumes it is not needed. The problem is most likely not with the moniter but in the computer
May 18, 2010 | Epson POS TMT88IV Thermal Receipt Printer
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
Feb 09, 2010 | CyberPower 725SL UPS System
Krups FME2 Coffee Maker Logo
94 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
