Question about RCA 32LA30RQD TV
I have no sound-was working one day, then just stopped. I have checked all connections and rebooted cable box.
I have also checked the mute buttons to be sure.
  • Karen Hensley
    Karen Hensley May 13, 2014
    I have checked all connections and power cords. All good,
  • 2,509 Answers
How is it connected to the TV, have you checked the connection/cable to the tv (unless its connected through the aerial in which case it isn't that)
Posted on May 13, 2014
  • W.L. May 15, 2014
    Can you connect cable box to a different tv with the same connectors to eliminate it?
    Top Expert:
  • RCA Master
  • 36,408 Answers
Could be power supply failure
Testimonial: "TV has power-we have picture, just no sound"
2 Suggested Answers
SOURCE: No Sound on RCA L46WD22
I own the L46WD22 for a few months and lost the sound and analog inputs, only HDMI worked, apparently this is a design flaw and they should have recalled all units. I didn't really needed the speakers because I have a sony receiver where I playback the sounds, but I decided to repair it myself after I neglected to take it out to the repair center and use the warranty. If you have a little soldering experience you can fix it, or you can buy the fuse and take it to any repair center, the problem is a surface mounted fuse that is located in the PCBA where all the signal inputs are, the component location is 1C33 the fuse has the letter F printed on it, you can't miss it, it's about 2 inches behind the tuner where you plug the coaxial cable. the fuse I bought it's marked with a G letter, it's 750mA, I just soldered it on top of the one it has, now I can hear the speaker and use the analog inputs (and now I'm the hero and have a very happy wife). the whole fix took me about two hours
Posted on Sep 28, 2008
Has a beautiful picture, but all of a sudden there is no sound. It was working one minute and the next it wasn't. I use the cable remote to operate the tv, not the tv remote. What should I do?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 29, 2016 | Honeywell Televison & Video
Restore sound on my Tv, suddenly lost.
  1. Check if the mute button on the cable box/TV/VCR is activated. If so, turn off the mute feature
  2. Verify the volume on the cable box/TV/VCR is not turned all the way down, either by adjusting the volume level on the equipment itself or with the remote control
  3. Check if the TV has an earphone or headphone jack. If so, make sure there are no earphones or headphones plugged into it
  4. Check if the Cable Box/TV/VCR has a SAP/MTS switch (Secondary Audio Program / Multichannel Television Sound). If so, make sure it is set to the proper setting. Consult your TV/VCR manufacturer's user manual for information for your specific TV/VCR. Click here for information on changing this setting on a Cable Box
  5. Check behind ALL TV and equipment (Cable box, TV, VCR, DVD, stereo receivers, etc) and the coax cable at the wall outlet for any loose or damaged connectors
  6. Make sure all equipment and connections are hooked up correctly for the video and audio based on the type of connections being utilized
Mar 10, 2015 | SEG 19 in. TV
How do I get the sound back on my tv
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 18, 2015 | Samsung LN46A650 46 in. LCD HDTV
My dreamax dtt5211 set top box has lost it's sound
Check whether the audio is muted by accidental press at remote control button {Either with TV or with Set-top box}. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Dec 09, 2014 | Televison & Video
KDL52W3000 sound was working fine, but suddenly the sound stopped working
On both the set and a box if used check for sound being all the way down, muted etc.
In the set check to see if speakers are for some reason switched OFF.
A few sets have options to select internal/external speakers also.
If sound and picture are coming from a box via cables to a rear input unplug the box-wait and power it up to see if box reboot will cure this.
Sets using a HDMI for picture/sound are prone to all kinds of audio problems especially if loss of power or hookup done with box and set on........
Look for the simple things first like do you have sound with a DVD etc--that means the problem in not likely to be in the set other than a wrong setting.
Apr 10, 2012 | Televison & Video
All of a sudden the sound isn't working and yes I checked the mute button already and it is just a cable connection....sound was working fine one day and the next day it won't work at all.
Tries cables or satalites boxes and tv unplug,replug it back like about an hour later,for the tv to do resetting itself back to the factory setting and those pay boxes to updated it softwares.Go to tv Menu go to Audio Setting go down for a resetting to go back to factory setting.By doing these steps have a great chances getting ur tv audio back.
Mar 24, 2011 | Protron PLTV-32 Television
My htr-5850 just stopped producing sound while using the cable TV. I muted it once and when I took it off mute I have not been able to get the TV's sound to work since. I have no idea what to do. Any...
How is TV sound coming into your Yamaha? If it's from the TV analog audio then maybe the TV's audio output is muted.
If it's from the Cable Box maybe ITs audio is muted. I'd refer to the guide for the Cable Box.
MUTE on the receiver is not source-specific.
May 25, 2010 | Yamaha HTR-5850 Receiver
I have a SA 8300HD cable box connected to Yamaha RX-V2500 receiver using Digital Audio Out from cable box to DVR/VCR2 on the receiver. It had been working for 2 years. Then this past weekend it stopped...
Pretty good problem description.
Make sure the DVR/VCR2 digital input is assigned to the Cable box.
When the DVR/VCR2 input is selected do you get any front panel indicators on the Yamaha that indicate a good digital bitstream?
Try swapping the cable box output to the working DVD In connection to isolate it to either the source or the receiver's ability to decode it.
Check the audio output settings for the Cable Box, too. Sometimes their outputs are adjustable. It may be muted or set too low.
Mar 31, 2010 | Audio Players & Recorders
Volumn not working
WHen I hit the mute button again to bring up the volumn the sound remains muted. I have tried all other channels, direct cable and even a dvd player connected. No sound. I unplugged all the boxes and tv and then plugged in again in a attempt to reset what might be wrong. Still no sound. solution 1 while operation mute button has got demaged or pressed more. 2 sound section might have gone defective in tv 3 no supply to sound section 4 or speaker defective or ic got demaged.
Aug 02, 2007 | RCA 27V520T 27" TV
No sound
If the tv does not have sound with out connecting the dvd then you are having a problem in your audio circuit have a tech look at it.if its only when you connect the dvd then you could have connect cables wrong.you cannot route a dvd through a cable box.any dvd s compatible with tv so long as the connections are there. goodluck.
Dec 28, 2006 | Toshiba 32HF73 32" TV
RCA 32LA30RQD TV Logo
44 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
