Question about Amigo Health & Beauty
How do you add a throttle control POT to an amigo value shopper? I see where it goes on the circuit board but need to know the value and the pin out. Thanks in advance.
Trying to speed up my old value shopper I inherited from my mother. :-)
  • 53 Answers
Older smart shoppers had a speed pot built onto the throttle assy. but the value shopper is programed into the motor controller user can't change
Posted on Mar 16, 2015
3 Suggested Answers
gewiz
  • 1263 Answers
SOURCE: pride mobility legend XL throttle/speed fault
what about the overall connection , start at the handlebars from the speed pot,
Take off the rear cover , first remove the seat, pull the connector one by one and plug back in,
chec kthe connectors around the speed pot , in particualar if there is a circuit board.
Posted on Jun 13, 2009
SOURCE: amigo smart shopper
FIX IT
MAY IT NEED CERTAIN PARTS
Posted on Jul 13, 2010
I need a manual for the amigo smart shopper cart
You will need a serial number, should be at the bottom of the steering shaft or in the battery compartment, call amigo at 1-800- myamigo for help when you have it
Jan 12, 2014 | Amigo Smart Shopper Scooter
How much does a new amigo value shopper scooter cost
Grainger has them for $2630 new. There are used ones on ebay for $350
Sep 14, 2013 | Amigo Value Shopper Scooter
Controls won't respond
Does the battery indicator light up. If it does then remove the rubber seat cover to expose the seat safety switch then turn power on hold seat switch down and try the throttle if the cart moves then try to put 2 10 x 10 pieces of card board on top of the foam directly above the seat switch then put the rubber cover back on.If it doesn't then have the on off switch and batteries checked or contact amigo for the nearest service company in your area (1-800-my-amigo)
Apr 04, 2013 | Amigo Value Shopper Scooter
Have a amigo smart shopper scooter and "dead man" switch apparently not working correctly. When I depress thottle, scooter goes forward without any weight on seat?
need to know how old unit is smart shoppers now use seat switches that are normally open without weight and when seated normally closed, if you unplug the wires that come from the seat switch and the cart doesn't move then the seat switch is stuck and should be replaced. older units were normally closed without weight and normally open when seated in this case check to see if the wires have come unplugged and reconnect them then recheck if cart won't run when seated replace seat switch.
Feb 01, 2013 | Amigo Health & Beauty
Have an Amigo RD. It goes reverse perfectly, but it stalls going forward. Help?
My Amigo RD was doing the same thing, I had to replaced to circuit board and that fixed the problem, don't replace the pot throttle, because I replace the throttle thinking that was the problem, but it wasn't. It was the circuit board.
Jan 03, 2013 | Amigo RD 3-Wheel Scooter w/33AH Batteries...
I want to reprogram an Amigo Value Shopper to have a faster top speed
Sorry but you would need a programmer to attach to the controller I am a service tech and use it to program the controllers
Nov 03, 2012 | Amigo Health & Beauty
I snapped the cable on my amigo value shopper what do i do
if it's the wire that drags on the ground it's a static ground, you can order a replacement from amigo or make one from a piece of stranded copper wire (14 gauge)
strip 3 inches of insulation then wrap once around axle and twist together cover twisted portion with electrical tape to hold together make long enough to allow end to drag on ground
strip 1 inch of insulation to allow wire to contact the ground and that's it
it it's the gray flat cable or the motor wire it will need to be replaced
Sep 09, 2012 | Amigo Value Shopper Scooter
I have a Fiesta by Amigo, When I turn the switch
check here there are different codes
http://myamigo.com/amigo-mobility-scooters-support/amigo-mobility-scooters-owners-manuals.html?download=20%3Aamigo-rtexpressjunior-amigo-rd-amigo-ext350-amigo-hd450-amigo-mc-amigo-mcx-2003-present
Nov 09, 2009 | Amigo HD450 3-Wheel Scooter w/33AH...
Amigo smart shopper
FIX IT
Oct 19, 2008 | Amigo HD450 3 Wheel Scooter with 33AH...
Health & Beauty Logo
197 people viewed this question
Top Amigo Health & Beauty Experts
James Rose
Level 1 Expert
Tom Chichester
Are you an Amigo Health and Beauty Expert? Answer questions, earn points and help others
