Question about Motorola Computers & Internet
Mc9090 loses time after cold boot - Motorola Computers & Internet
  • Official Brand Answer
  • 3,100 Answers
Contact Motorola Solutions.
Get Support
Mark Motorola Mobility Support
Posted on Jan 05, 2015
3 Suggested Answers
SOURCE: Motorola MC9090 G oes not cold boot.
I've found this method works best especially on Window Mobile versions, windows CE does not seem to have the problem.
  1. Have the battery inserted,
  2. Remove the battery so its at the first stage of removal,
  3. Hold down the On/Off button and trigger,
  4. Insert the battery, still with On/Off button and trigger held,
  5. As soon as the amber light flashes release the On/Off button and trigger.
  6. Unit will attempt to cold boot and then warm boot,
  7. If it works then it will boot through to the Windows Splash screen or desktop.
  8. If it fails and continuously warm boots, remove the battery fully as soon as it cycles a warm boot.
  9. The terminal will not switch off at this stage and will completely drain the backup battery and RAM, giving you a complete clean cold boot
  10. Leave the battery out fro 20 minutes.
  11. Power on and see how far you get.
If it still fails after this I would suggest a complete re-flash of the system. Please post a follow up question on how to do this.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Posted on Jun 08, 2010
SOURCE: Hi, unable to boot mc9090. (warmboot
909XCLEANBOOT.ZIP
This file is intended for use when a CLEAN BOOT of an MC909X WM 5.0 device is required. Unzip the contents of this device to either the root of an SD Card (and place the SD Card in your device) OR the TEMP folder. Then follow the UPDATE LOADER boot instructions below.
909XCLEANBOOTANDBLANK.ZIP
This file is intended for use when both a blank Application Folder and a CLEAN BOOT of an MC909X WM 5.0 device is required. Unzip the contents of this device to either the root of an SD Card (and place the SD Card in your device) OR the TEMP folder. Then follow the UPDATE LOADER boot instructions below.
There are two methods to perform an Update Loader Boot on MC909X:
Method 1
1. Navigate to the location where the ZIP file was unzipped
2. Tap 'StartUpdLdr.exe'
3. After 20 seconds or so, the device will perform an Update Loader boot which will cause the PKGS.LST file deposited on the device to be processed. Leave the device on A/C power during the Update Loader process
Method 2
1. Press the primary battery release on the mobile computer to partially eject the battery from the mobile
computer.
2. On an MC9090-G, while the battery is partially released, simultaneously press and release the trigger and
the Power button.
3. On an MC-909X-K or MC909X-S, while the battery is partially released, simultaneously press and release
the left scan button and the Power button.
4. Push the battery to fully re-insert it in the mobile computer. One audible click can be heard as the battery is
fully inserted.
5. The mobile computer initializes. During this time press and hold the trigger used on step #2 or step #3 (as appropriate) and place the device on A/C power either by placing it in a cradle or a CAM.
6. The device will invoke an Update Loader boot, which will cause the PKGS.LST file deposited on the device to be processed. Leave the device on A/C power during the Update Loader process.
When the device has completed the process it will return to the Windows Mobile ""Tap the screen to set up your Windows Mobile-based device" screen. At this point, if you used an SD card, please remove it from the device. If you placed the files in the TEMP folder, they will be automatically erased by the CLEAN BOOT process.
The files can be downloaded from:
https://docs.symbol.com/downloads/909XCLEANERS.zip but this didnt work for me i use another similar ones, probably its because you will need to find the properly version.
Regards
Posted on Jul 12, 2012
MC9090 Stuck Warm Booting
Here you can find links to both clean boot files for the WM5.0 and WM6.1 OS for the MC9090. If you need the full WM5.0 OS you can download it here. For upgrades to WM6.1 from WM5.0 fill out this form and BCTP will help you out.
Aug 20, 2012 | Symbol Computers & Internet
When I press the keys on my MC9090 they give the wrong output.
The Motorola MC9090 can have different keypads attached. If you do change the keypad for any reason for example go from a 53 key to 43 key layout the terminals must be cold booted.
To cold boot an MC9090 running Windows Mobile 5. Partially remove the battery, hold down the On/Off button, the trigger and reinsert the battery. When the orange light on the keyboard flashes release the on/off button and the trigger.
If the on/off button or trigger is held down longer than required this occasionally causes the terminal to get caught in a warm boot cycle
If the device is still not giving the correct key output it may have a faulty keypad.
helpdesk@biastechnology.com or TEL +44(0)1202 620955
Jul 11, 2012 | Zebra MC9090-G Barcode Scanner
Symbol MC9090 I formatted the Symbol MC9090 installed the drive after I do a setup on the device everything works correctly, after rebooting the symbol mc 9090 its configuration is...
this is because you are cold booting the unit. Everytime you cold boot a 9090 it re-sets all saved settings. You need to warm boot only unless you want the unit reset to default. any problems please mail technical@codeo.co.uk for support - we supply MC9090's in refurbished condition complerte with like new warranty incase you need any
Oct 21, 2011 | Zebra Symbol Technologies MC909X-G Series...
MC9090 Motorolla RFID Create images
I presume this is if teh battery is removed for a significant ammount of time so the terminal cold boots.
What you need to do is download from Motorala/Symbol is
StartUpCtl
this will allow you to reinstall programs automatically after a cold boot and also auto run them.
Download the application and read the instructions, its very easy.
If you need any further assistance then please contact us
Aug 28, 2009 | Symbol Motorola MC909X-G Series Portable...
MC9090-GFOHJEFA6WR Frozen on warmboot
The 9090 will continuously reboot when someone has cold booted it and has held the trigger down too long after the cold boot. What it's doing is looking for OS update files in the proper directory to do a system update. When it doesn't find them it just reboots again continuously.
To get out of this, cold boot it again but release the trigger right after you push in the battery.
Thanks,
Brad Radaker
Radicomm (maker of QuickTalk - push-to-talk for the MC9090)
www.radicomm.com
Mar 07, 2009 | Zebra Symbol Technologies MC909X-G Series...
The MC9090 is forzen cannot select any icon. help
Have you tried performing a cold boot? release battery half way, press and release trigger and power button at the same time and put the battery back in.
Mar 04, 2009 | Symbol MC9090 Barcode Scanner
Not ABLE to switch on MC9090. tried replacing the battery . Held the power button for 2 mins . nothing is working. Is there any key combination to start the reader ? please help.
I know it may be a little late now since you're question was a couple months ago, but I have had this problem with some 9090's before too where a warm boot (holding the power button down) will not bring them up, but a cold boot always does (unless of course it truly is defective - that's not usually the case though).
To do a cold boot, pop the battery out part of the way until it "catches" (you'll know what I mean if you have an MC9090 and try it). Then hold down the trigger and the power button simultaneously while pushing in the battery all the way. Once the battery has been pushed in, release the power button and the trigger.
This should cause the MC9090 to boot up fine. Make sure you release the trigger after doing the steps above. Sometimes people don't do that, and this causes the MC9090 to go into an infinite warm boot where it just continuously reboots over and over. The only way to get out of it is to cold boot again, but this time release the trigger in time.
Thanks,
Brad Radaker
Radicomm (makers of QuickTalk - push-to-talk over WLAN for the MC9090)
www.radicomm.com
Mar 02, 2009 | Zebra Symbol Technologies MC909X-G Series...
My MC9090-G scanner is stuck in boot mode. I've tried a cold boot and warm boot and nothing works.
Actually if it is continuously rebooting, it is usually because someone was holding down the trigger through a cold boot process. That's what puts it into this continuous reboot loop. To get out of it do a cold boot again (pop the battery part of the way out, hold down the power button and trigger simultaneously, and then push the battery back in while the power button and trigger are still down). But as soon as you push in the battery to the point where you hear it click, release the trigger. If you hold it in too long, the unit will start continuously rebooting.
Thanks,
Brad Radaker
Radicomm, Inc. (makers of QuickTalk - push-to-talk for the MC9090)
www.radicomm.com
Nov 21, 2008 | Symbol MC9090-G LORAX MONO 64/ 64MB 53 VT...
Computers & Internet Logo
124 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
