Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
944.608860 Whats the belt number for mower deck?
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
  • 148 Answers
SOURCE: Need deck belt for older chaftsman mower
Try www.searspartsdirect.com and type in your model number. They'll let you know what is still available and you can order directly from them online.
Posted on May 19, 2009
wadembly
  • 475 Answers
SOURCE: I am trying to replace my mower deck belt. I
got to www.searspartsdirect.com eneter model # for the tractor & it should give you the option to look at & the chassis & deck to help route the belt or give you the right belt part #
Posted on Jun 08, 2009
  • 32 Answers
SOURCE: I need the routing diagram for the belt on the
look under the running board most are on there
Posted on Jul 23, 2009
Can you show me the correct diagram for the drive belt on a 44in Dixon zero turn mower
Hope this helps. Serpentine Blade Drive Belt
1 Lower the mower deck to its lowest position.
2 Route the serpentine blade drive belt (part number 6109) onto the V-pulleys located on the mower deck. One double pulley is located at the front of the deck near the center. The other two pulleys are located near each side of the deck. Route the belt around the outside -- the side toward the outer edge of the mower deck -- of each pulley. For the double pulley near the front of the deck, route the belt around the lower pulley (part number 6058) only. If pulleys are fitted with belt guards, work the belt in between the pulley and shield.
3 Push the idler pulley toward the center of the deck with your hand. The idler pulley (part number 6059) is the fourth pulley on the deck and is located near the rear of the deck. It is the only movable pulley on the deck. Wrap the belt around the side of the pulley nearest the edge of the deck. Release the idler pulley to place tension on the belt. No adjustment is necessary because the serpentine idler spring (part number 6065), located on the idler pulley, adjusts the belt to the correct tension.
May 10, 2016 | Garden
Whats the length of the deck belt
the original length of deck belt is Deck Length 96 1/2" Type Covered Width 1/2". Fits Model. CUB CADET : LT1040 and LT1042, 42" ...
and pls vote me as helpful if it is
Jun 23, 2015 | Garden
How to change engine deck belt on a 2006 Dixie chopper mower
there isn't such a thing... it's either a hydro (motion) belt or the deck drive belt. Dixie's also sometimes had 2 belts for the deck... the drive belt and the blade belt. your model number should be under the seat
Sep 13, 2014 | Garden
Need to know what size deck belt it takes for a roper lawn mower the model number is yT140Dr
Electrolux 532106085 (replaces 106085X) BELT-V.79.1.MWR : This is the OEM belt number for the yT140Dr mower deck. Length = 79.1" ; Width = 0.5" (1/2").
Welcome to VBELTS4LESS COM Belt Supplier For Industrial Belts Lawn...
The above link is for VBELTS4LESS, an excellent web site for belts. I've used their belts for two mowers, and the belts are excellent...
Jun 15, 2014 | Garden
I need to know the belt size and part number for the 915037 1844 ariens zeroturn
Hi and welcome to FixYa, I am Kelly.
http://partsradar.arinet.com/scripts/EmpartISAPI.dll?MF&app=ariens&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer
Make sure pop-ups are enabled... (No ads on site)
Enter this model number:
915037-000101
Then on the side of the page choose: (Scroll) Mower Deck, Belt Idlers and Blades
There are 5 belts listed! There is nothing that relates to a mower or deck serial number either.
You have to know the model numbr of the deck (see item 1 same link to cross ref your belt size)
035
Belt PN: 07241700 V belt (037) = 44 inch deck model 51519000 & 5159100
039
041 / 313
Belt PN: 07242900 V belt (501) = 44 inch Deck Model 51510400
Thanks for choosing FixYa.
Kelly
Sep 10, 2011 | Garden
Need diagram to replace belt on manual trans john deere 265
See if this is even remotely close to your mower deck:
http://opebycrigby.tripod.com/decks/jd/jd48edgew.jpg
Also see if you can locate the mower deck model number i.e STX 38, STX 42 (Deck color Black or Yellow?) Should be a silver decal with black lettering. Also... there is supposed to be a belt routing diagram on the mower deck. (Another silver decal with the belt routing picture)
Kelly
Apr 13, 2011 | John Deere Garden
Replaced deck belt and it keeps coming off,whats wrong?
The belt tensioners on top of the deck need adjusted, or you make have to adjust the pulleys to tighten the belt. Sometimes if you have the deck lowered to low to the ground, uneven terain can cause that. If you have everything adjusted correctly, simply raise the deck another notch and mow.
Aug 09, 2010 | Yard Machines 155 Torque Briggs Stratton...
How long is the deck belt for a craftsman 42" deck
You must have tractor model number to find exact parts. There are many different types of mower decks. If you have your craftsman model number, you can go to www.searspartsdirect.com and find the sears part number. If you don't have your broken belt, to find size, it might be good to buy one from sears. Then when you get the belt see if there is a normal belt number on it to record. If not take your new belt to store to match it up to a power equipment belt. For example Tractor usually stocks a nice supply.
Jun 30, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Looking for mower deck belt diagram for a Husky
THAT NUMBER IS NOT COMEING UP CAN YOU SEND ME THE NUMBERS FROME UNDER THE SEAT
Sep 19, 2009 | Garden
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
