Question about Kenmore 24" Built-In Dishwasher with UltraWash HE Wash System
My dishwasher seems to be stuck in washing mode. how do I troubleshoot?
How long should each cycle normally take? I had my NORMAL, high temp scrub, sani rinse cycle on and I saw the light panel indicate washing, then heating, then it went back to washing.
    New Friend:
    Problem Solver:
  • 17 Answers
The schematic behind the lower panel below door should have paper in clear bag with how to get codes.
Posted on Jun 02, 2014
How to reset Kenmore Elite 665-16572202 Dishwasher...clean light blinks 7 times pauses then repeats. My model does not have a Heated Dry button it has an Air Dry button.
Here's the key sequence(s) to use, depending on how your keys are labeled:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
This will start the diagnostic cycle. Let the dishwasher run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. Please note, that this clears the error, but if you haven't found the cause (water-not-heating error), the condition will come right back the next time you run the dishwasher.
Jan 19, 2015 | Kenmore Dishwashers
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
Run a service test for kitchenaid dishwasher
Did you check behind the toe-kick panel for the tech data sheet? Assuming that you have checked and that it is missing, there here is the "secret keystrokes" that will make most Whirlpool/ KitchenAid/Kenmore/Maytag diswashers enter the diagnostic cycle:
Oct 18, 2014 | KitchenAid KUDS30IXSS Builtin Dishwasher
How to reset a Kenmore 668.1687582 dishwasher
Yes, depending on the model, and the buttons that your dishwasher has, try the following key sequences:
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds.
Sep 03, 2012 | Kenmore 24 in. 15142 Built-in Dishwasher
Reset kenmore dishwasher
The most common "reset" key sequences are:
Jun 15, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
My KUDS011JBSO undercounter dishwasher is blinking the normal wash light. What do I need to look for to fix this?
Hi
If light is blinking then it may be an issue with heater circuit, door switch or the thermal fuse, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the thermal fuse located on the control or the door switch that is bad and should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | KitchenAid Dishwashers
I have a Whirlpool Gold Quiet Series Plus, Model GU940SCGT3, not working. It ran a cycle, cleaned the dishes, but the water didn't drain and the "CLEAN" light is stuck on. It is now...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Mode light stuck on clean. will not start by pushing the start button.
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
Hope this helps... Please post back for further assistance.
Daniel
Mar 25, 2011 | Kenmore 1348 Builtin Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24" Built-In Dishwasher with UltraWash HE Wash System Logo
212 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
