Question about A4tech Computers & Internet
Mouse not working on desk
The mouse will work on my clothes (dark surface) but not on my desk (light surface) any more. I have tried re-installing the device, changing batteries, and changing usb ports. i can't find the re-set button either on the mouse. model: G9-500F for A4tech.
  • Lutece Irwin
    Lutece Irwin May 14, 2014
    i've tried with different usb ports and all the settings. basically i need to somehow hit the reset button on my mouse, but i can't seem to be able to find it/it does not exist apparently. thanks for trying to help! i think i'll take it back to the people i bought it from. (i'm a uni student so money is tight :/ )
  • 2,509 Answers
There is little you can do other than clean around the sensors, and check the settings in control panel (if on a PC). It sounds like the sensor has lost sensitivity. I assume you have tried it in a different usb port or on another computer in case the voltage is low on your usb port? mice are so cheap it's just not worth repairing.
Posted on May 13, 2014
yooperbud
  • 8637 Answers
SOURCE: Interlink 4350 wireless mouse won't work
You probably already tried this.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Posted on Jan 17, 2009
romsky79
  • 822 Answers
SOURCE: IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Posted on Jun 02, 2009
yooperbud
  • 8637 Answers
SOURCE: MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 28, 2009
virtualhost
  • 2185 Answers
SOURCE: My mouse cursor wont move and the buttons won't click.
Try restarting your computer with your logitech mouse plugged. If you said you have successfully installed, the system will automatically detect your mouse.
Posted on Jul 20, 2009
SOURCE: microsoft mouse 3000 doesn't work
I email you idiots to fix a problem not to buy another product. Why should I buy a premium plan from you. With any luck it probably won't work either. Yes I did fix the problem. I threw the worthless mircosoft wireless mouse 3000 away. Problem solved
Posted on Aug 25, 2009
How to clean the magenta toner sensor on a canon imagerunner c5255 copier
Step 1Turn off and unplug your Canon copier. Put on a pair of latex or work gloves to keep toner and debris off of your hands. Cover a table, desk or other surface with three to four sheets of newspaper to protect the surface from spilled toner Step 2Open your copier's toner cartridge door on the front or top of the device and remove the toner cartridge. The cartridge contains the drum as part of its unit. Lay a flannel cloth onto the newspaper-covered table, desk or other surface and then shake the toner cartridge gently above the cloth to coat the cloth lightly with ton
Place the cartridge upside down on the newspaper-covered surface and open the drum's shutter door, which contains hinges. Rotate the drum using the spindle on the side and wipe the drum's surface with the toner-covered flannel cloth to remove any dust, dirt and caked-on debris. The drum only rotates in one direction. Work quickly so as not to expose the drum to light. Artificial and natural light can damage the drum's surfac Step 4Continue rotating and wiping the drum's surface until it is free of any debris and dirt. Close the drum's shutter door and reinstall the cartridge back in your Canon copier.
Sep 28, 2016 | Canon Office Equipment & Supplies
Hello..just moved my desk top to new desk..everything is fine..but mouse won t work..while it was unplugged i cleaned keyboard..monitor with soft cloth..can u tell me why my mouse won t work
IF it's a serial mouse (meaning green round connector) it's probably not plugged in correctly. Now these are not plug and play so you need to reboot your system in order for it to work. Try that.
Jul 10, 2011 | E-Machines eMachines Desktop PC
My mouse keeps stuttering, I really don't know why. I changed the batteries and installed the latest drivers available. It works on and off. The stuttering really makes it unusable. I'm not sure what I...
When the mouse stutters, check the adapter plugged into the computer. If the little light on the adapter (labeled #2 in the picture) is blinking then you may have accidentally pressed the sync button on the bottom of the adapter or the mouse.
To fix this problem, press the sync button on the bottom of the adapter.
Next, press the sync button on the bottom of the mouse.
Mar 01, 2011 | Microsoft Wireless Mobile Mouse 3000
I have a wireless lazer mouse and key board, the mouse all of a sudden started acting eratic and the red lazer light had gone off. I tried troble shotting but it came back an said that everthing was...
common causes; -dirty optics, clean red light area with canned air. -polished or shiny desk surface. optical mice dont like shinny surfaces. try a piece of paper under the mouse to see you need a mouse pad. - batteries low. even though they have some charge, low batteries can cause erratic behavior. as the mouse and base connect then fail, then connect, then fail. ect. often people dont realize how fast optical mice eat up batteries. check the wire to the base, sometimes these get caught in sliding keyboard drawers and get damaged. hard to see untill you inspect the whole wire( to the base anyway). Animals sometimes chew em up too. :) if any of the above help you. please provide some thumbs up. Cheers
Aug 26, 2010 | Logitech 9311570403 Mouse
What surface works best for cordless mouse
A flat dark surface works best. Glass won't work at all. I always prefer a mouse pad so that there are no imperfections on the table surface. Although, I did see a guy use one on his belly once.
Hope this helps.
Oct 25, 2009 | Logitech Cordless Mouse
My mouse connects to my laptop but does not move the cursor. It does scroll and the buttons work however
i was having the same problem, but i found out what was wrong. it's the surface that the mouse is on. originaly i had it on my desk and it didnt work, but a surface like a book cover worked. try it and see what happens. if it works then great but if not then try another surface or just call up logitech and ask them.
Oct 24, 2009 | Sony VAIO VGP-BMS33/B
Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Jun 17, 2009 | Logitech Cordless Mouse
Microsoft standard wireless optical mouse troubleshooting...
alright The Optical Mouse works on the "reflection" principle.
If it is only working on the T-shirt,the T-shirt Must allow it to read the Light Reflection with more details compared to the other shiny or smoother surfaces.
so,make sure you use some surface close to the T-shirt's.
and as you have been use that mouse directly on the deck surface, the little LED must have goten Dusted or the plastic arround the LED(light).
Hope that helps...
If the Mouse is in warranty **** any replacement if possible underwarranty.
Jul 17, 2008 | Microsoft Standard Wireless Optical Mouse
Microsoft Wireless Optical MOuse
I've noted that certain mousepads do cause problems- it seems to be with the graphics on the pad- reflective/light/dark areas on the pad cause the different movement patterns. I'd guess a pad with a dull non-reflective & uniform color might be best.
Sep 13, 2007 | Microsoft Wireless Optical Mouse USB...
Computers & Internet Logo
126 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
