Question about Pyle PLBT72G - Single-DIN In-Dash DVD Receiver with 7" TFT LCD To
I'm having problems with microphone being low when I'm using the bluetooth phone connection people say they cant hear me what could this be?
I can hear people when I hook up bluetooth but they say they cant hear me. they say I'm very low in there hear.
  • 2,509 Answers
Try changing the position of the microphone to nearer your mouth if possible.
Posted on May 13, 2014
On answering a call i can hear them but they cant hear me
I would delete all paired devices from the Parrot kit and delete the Parrot kit from your phone, then remove your battery from your phone for 5 mins, then repair as a new phone. If this does not work you have a microphone issue, check the wire is not trapped behind one of the trims.
Nov 21, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
My speaker have water damage, i can hear but they cant hear me, can i use blue tooth
Hi, a blue tooth device would allow you to hear and speak through it so it should solve your problem.
the only problem you may have is if the water damage has causes damage to bluetooth inside the phone, try choosing bluetooth on your phone and see if you can still do a search and connect with another phone, if you can still connect to another phone to say send music or picture via bluetooth then this would suggest your bluetooth is fine and using a bluetooth head set will solve your problem and allow you to use your phone again.
if you cant connect to another phone via bluetooth then the chances are it wont pick up the bluetooth head set and you would be no better off
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 13, 2010 | LG enV3 VX9200 Cell Phone
Nokia CK-7W, nobody can hear me!!
It sound like a faulty microphone, try and follow the wire to see if it is trapped somewhere, mabe down the side trims.
Nov 19, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
People can't hear me on my Blackberry Curve unless I turn the phone and talk loudly right into the speaker. I am so sick of having the "I can't really hear you" conversation! With my bluetooth, I have the...
When using the IHF1000 with your Blackberry Curve, I recommend to go into the device properties for the IHF1000 in the phone's Bluetooth devices listing. Under that, there should be a phone setting to turn Echo Canceller: On, Off, or Automatic. By default, it is Automatic. For this phone with the IHF1000, I would set it to Off. This has solved audio quality problems for a number of people.
Note: this may or may not directly address the low uplink audio level you are experiencing, but it does seem to help with general call audio quality when connected to the IHF1000.
Mar 06, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
IPhone 3G Bluetooth microphone volume to low
This is a Normal problem, remeber the echo is for the mircrophone is in the same place like the speakers, & dont have a noice cancelation system, I recomended to use a bluetooth earphone
Nov 14, 2008 | Apple iPhone 3G
Microphone...
You need to clarify whether microphone or its connection bad or system causing the problem. I suggest you to try with external bluetooth or normal headset. If sound microphone works with headset you need to have microphone connection be fixed
Jun 19, 2008 | Nokia E90 Cell Phone (Unlocked) - Black
Motorola h350 blue tooth headset microphone does not work
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
May 30, 2008 | Motorola Mobility Bluetooth Headset H3...
Pyle PLBT72G - Single-DIN In-Dash DVD Receiver with 7" TFT LCD To Logo
141 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
