Lg intellowasher wd1074fb
Hello, I want to ask whats the sign "de" means, when Im tryin to start the machine and it doesnt even work. It just doing 'beep' and not starting at all
  • 2,509 Answers
DE means Washing machine door detected as being open Door open error code can also be displayed as "dOE"
Very simple error, the fault code indicates that either the door is indeed open or that the door lock or door interlock mechanism cannot inform the electronics that the door is properly closed. LG door locks are known to fail. Worth shutting door very firmly to see if it clears
Posted on May 13, 2014
    Sniper:
  • 97 Answers
When you see the DE error code, it means a "door error". This is a sign that either the door is not shutting, locking or opening. Most of the time, this is a simple fix and service is probably not needed. Check for something stuck or lodged in door. Check door gasket. Check door latch.
SOURCE: LG Intellowasher - CL in led code whats wrong?
had this prob too. took me a while to work out. CL is Child Lock... hold down 'Rince' and 'Prewash' buttons at the same time to unlock.
Posted on Aug 13, 2007
  • 489 Answers
SOURCE: LG INTELLOWASHER DD 7KG
You may need to have the door switch replaced but before that should be done, make sure the wire connector is securely in place.
Posted on Sep 29, 2008
  • 412 Answers
SOURCE: What does SE mean on my LG Intellowasher 7kg WE-8074FHB display
Error SE is a sensor problem as per LG support.
you need to change the senser of your machine...
Good Luck!!
Posted on Mar 22, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: My LG intellowasher 7,5kg WD-
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
LED display models LCD Display Models
Step 1: Check the drain pump filter.
Step 3: Confirm that the washer is leveled properly.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
NOTE: Perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Posted on Dec 25, 2010
Having lg intellowasher WD10160F, if i select any
DE error means that there is a fault with either the door lock or main pcb.
Oct 06, 2014 | Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
I have an intellowasher made by LG WD1023C I have
This means -Child Lock trying to solve the problem myself- I think by pushing 2 buttons together... but which ones?
Aug 16, 2010 | LG WD-1080FD Front Load Washer
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
Good Luck!!
Mar 22, 2009 | LG Washing Machines
I have a lg intellowasher and its displaying a fault code "LE" and i've no idea what it means and have misplaced the manual. can anyone help?
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Send me the model # and I'll see if I can send you the user guide download location.
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | LG Washing Machines
My LG intellowasher DD WM1480 FDH washer displays DE (door open) and refuses to start, if I repeatedly open and close door sometimes it will start or the door will lock and it still doesnt start.
I have this problem too for my LG Intellowasher. I suspect it is because you're selecting "Rinse Hold" from the options. Try turning the power off and washing again on another setting to see if this resolves the issue.
May 03, 2008 | Washing Machines
LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Jan 12, 2008 | Washing Machines
Broken washing machine
we also have now gotten the same message and same poor help the company is aware of this problem but sadly, the almost $500 replacement to fix the problem is the same original parts that go wrong in the machine so they haven't upgraded the replacement parts which means you pay to get the new part--WAIT for it to arrive because NO ONE stocks LG parts, and then the new part is not any better than the original. We are selling ours and getting a Kenmore.
Nov 27, 2007 | LG WM1814CW Front Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
