Question about Ovens
HAVE NO IGNITION
THE IGNITION HAS FAILED COMPLETLY ON MYNEWHOME 600si dlm HELP !
Where do I find the ignition on the 600 SI DLm
seems you need to lift the top , but without the make,model we really have no idea .
Nov 03, 2015 | Ovens
H I have a stoves newhome 600si the rings,lite but when the grill or oven is on the flames nearly go out as if its lost full pressurean ideas please
I would have your regulator checked going to your stove to make sure you have enough flow rate or a obstruction
Jan 04, 2015 | Stoves Ovens
Upper oven door will not close completly to shut off light
Not sure if the door was removed recently, if so you may have to try to put it back into it grooves properly - if not is may be the hinges but before you look into that option, check this video out and see if it may help you
Apr 13, 2014 | Whirlpool GBD307PDS Electric Double Oven
HOW DO I LIGHT OVEN PILOT?
Hi and welcome to FixYa, I am Kelly
Your model number was missing digits so I used this manual:
GRP17WEWWW
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981380002.PDF
and if your unit is older this one:
http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=ShowPDF&FileName=49-8514.PDF
Automatic Ignition
The oven burner is lighted by electric ignition. To light the burner, press the pad for the desired electrical function and press the INCREASE or DECREASE pad until the desired temperature is displayed. The burner should ignite within 60 seconds. After the oven reaches the selected temperature, the oven burner cycles off completely, then on with a full flame to keep the oven temperature controlled.
GE contact data:
If you don't understand something or need more help, call:
GE Answer Center®
800.626.2000
24 hours a day, 7 days a week
Both the new and OLD units use a glow bar for lighting the burner. Most likely your Glow Bar has failed: GE PN: WB2X9154
The Glow Bar is item 316 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214914&diagram_id=20725728#d20725728
If you net search the WB ge part number you can save lots of money!!!!
http://www.amazon.com/WB2X9154-Gas-Range-Oven-Igniter/dp/B004H3XQPM
If the glow bar is glowing and you still do not get ignition respond here and we can go through troubleshooting.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | GE JGRP17 Gas Single Oven
Have a 1980s model oven model #EH4W4 .My problem is the burners work great but oven does not lite anymore when temp is selected.?
If it is a standing pilot the thermocouple has most likely failed. If it is electronic ignition the the igniter has probably failed. Is the oven plugged in to the wall outlet all the way or is it direct wired? Is it standing pilot or elctronic ignition? Really need more info to correctly diagnose
Mar 11, 2011 | GE Ovens
Gas oven not heating, stove top working
Is your stove electronic ignition? Can you here the ignitor clicking as it trys to light? If so the gas valve on the back of the stove for the oven has failed and is not letting gas to the burner. If you smell
Jul 04, 2009 | Ovens
Manual for cooker
just wondered if u ever managed to get a manual for the stoves new home 600 si dlm ? if so,could i be cheeky and ask u to email me a link please?
thx in advance :)
Ant
flatlanderuk21@yahoo.com
Mar 08, 2009 | Stoves Ovens
Electronic ignition system failed
electric ignition. Electric goes to ignition button, then to a spark generator, where upon a spark is produced. If any part of this sustem is wet, then it is shorted to earth. No spark.
Feb 11, 2009 | Bosch HBN 131560B / 131520 hot-air...
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
