Midea manual WASHING MACHINE AW60-9906 IS STOPPING BEFORE SPINNING. WHAT IS THE REASON? PLS PROVIDE SERVICE PROVIDER'S DETAILS IN SHARJAH, UAE.
  • 1294 Answers
SOURCE: washing machine
You have to check and clean out your outlet filter. This requires periodic cleaning, according to your usage. If its a front loader, the small door is at the front bottom, be prepared for water to come out while opening.
Posted on Oct 08, 2007
Dissolu
  • 221 Answers
SOURCE: instruction manual for service gem 1000 washing
I know the place where to get it for $10. If you won't find anywhere else, just let me know
Posted on Jul 25, 2009
SOURCE: my siemens washing machine S14.39 keeps stopping a...
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
Posted on Aug 22, 2010
caroldon
  • 17130 Answers
SOURCE: fault code E2 on midea
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Aug 08, 2011
SOURCE: Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
give it a try
Kolbrun
Posted on Feb 22, 2012
MIDEA WASHING MACHINE INSTRUCTION MANUAL FOR MAE00-S2002GPS
Are you sure about the model number? I found an MAE100-S2002GPS washer on the Midea site. Go to http://www.midea.com/us/consumer/washing_machine/fully_auto/201404/t20140401_81499.shtml and click on the support tab for the manual. The direct link is http://img1.midea.com/us/Local_Library/info_instructions/washing_machine/fully_auto/201606/P020160614194954149229.pdf .
I hope this helps.
Sep 02, 2016 | Washing Machines
MIDEA AW70 509 WASHING MACHINE manual
Some manuals are here. If not similar to yours contact them direct.
Manuals Downloads
Dec 16, 2015 | Midea Heating & Cooling
Midea washing machine not spin/draining
The drain may have been clogged with something else.
Nov 25, 2013 | Washing Machines
I have midea AW60 9906 top loaded washing machine and i lost its manual
If you type into your search engine 'midea aw60 manual' you should be presented with a number of sources from where you can either download free or pay. At some point you will be asked for the other number.
Hope this helps.
John C
Feb 07, 2011 | Washing Machines
Hi there, my washing machine will not finish it's cycle and keeps stopping with 3 minutes to go. I am unable to open the door and can only re start a new cycle. I had drained the machine manually...
hi emily pritch and welcome to fixya,
Consider also if your washing machine has a timer. Or maybe theres a piece of something left or fall on the spinner that is why it does not drain properly and stop in a minute. If you can have your unit checked by the service provider so that they can also checked if the electrical may also be the reason.
thanks and have a nice day.
Jan 10, 2011 | Bosch Washing Machines
My haier washing machine is not working, can I get any service expert in UAE. I am staying in Sharjaha
my hier washing machine is new 1year and 3 month, but the program is making machine spinning and moving up and down what can i do?my 1 year cover expired
Oct 25, 2010 | Haier Washing Machines
Broken glass of caterpillar watch
RECOMENDATION:
Seek professional help.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 21, 2010 | Caterpillar (UB141344020) Wrist Watch
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
