Question about Frigidaire Washing Machines
I have a frigid air gallery series washer that lights up and just humms,it will not start cycle. I have checked pump and motor isn't ether one of those making humm sound
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Cloy,
I understand that you are getting a humming sound on your Frigidaire washer, and it will not start a cycle. I also see that you've checked the pump as well as the motor, and neither of those is making the humming sound. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine what is causing your appliance to make that humming sound and not run a cycle. Hope this is helpful.
-Best Regards-
WP
Posted on May 15, 2014
watugot
  • 290 Answers
SOURCE: Kenmore 80 series won't spin
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
Posted on Nov 05, 2007
duby1990
  • 367 Answers
SOURCE: Kenmore washer humms and smells horrible....
You have a bad motor. ( very common) If you take your model number to a local used parts store you may be able to find a good used motor for cheap. If no luck finding a used one, Order it from sears. (the motor is deffinately your problem, I replace them all the time.)
Posted on Nov 20, 2008
  • 212 Answers
SOURCE: Maytag/Amana top-load washer motor humms but fails to start
id start with the start capacitor first. but ive seen a bad pump lock up a unit too. motor switch could be bad if the capacitor does not fix
Posted on Jun 24, 2009
jsrock516
  • 5911 Answers
SOURCE: My washer filled with water and now it won't do
Check your lid switch. Symptoms may include, no spinning, no agitation, stopping at the rinse cycle and no draining. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the model number is correct, the part number for a replacement switch is 3949247. The average price is about $20 - $30. Prices differ between these sites, so shop and compare.
If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing so I can provide you with better assistance. Please include your model number (located on a nameplate along the wash tub rim under the lid) if its different than the one you listed the question under so that I may be able to assist you better. I hope this information is helpful to you.
NOTE: Roper is manufactured by Whirlpool so these instructions do apply. In addition, if the tub is full of water, and will not drain, you do not need to drain the tub to complete this repair.
Posted on Jan 05, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Series 80 wont do anything.
Check the coupling/transmission.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
I have a frigid afire gallery series washer lights up and just humms, won't fill with water. I checked water pump and motor,not ether one of those humming
I WOULD CHECK MY WATER INLET VALVE, DO U HAVE WATER FROM THE HOUSE WATER OUTLET TO THE WASHER WORKING? NOTE" A BAD CONTROL BOARD CAN SEND A WRONG MESSAGE TO THE INLET VALVE? POSSIBLY IF NOT THE VALVE ITSELF, CHECK IT WITH A METER FOR CONTINUITY
May 13, 2014 | Frigidaire Washing Machines
HUMMS WHEN IN SPIN CYCLE, DOES NOT SPIN
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 11, 2011 | KitchenAid KAWS850L Top Load Washer
Frigidaire Gallery Series # GLTF 2940FS The washer stopped running in mid rinse cycle. When I try to start it a clicking sound occurs.
You will need to check the drain pump and make sure there is nothing obstructing or restricting the flow of water.Once you know that is clear and the problem returns then you might have to change the main control board and possible the door lock.Also make sure to check the motor and all the wiring the motor.
Dec 22, 2010 | Frigidaire GLTF2940ES Front Load Washer
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I have a kenmore 90 plus series model # 11068972892............... when i push start button the dryer motor will humm and mabey start to run or it will just humm and not run at all..if it...
Check under the machine and see if the motor turns easily by hand. It could be the motor, or it could be the bearing. The switching off after a while implies that the motor is struggling against a heavier than normal force and trips because of overheating. Most likely the bearing/s is/are ceasing up.
Sep 06, 2010 | Kenmore Dryers
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Washer not completing cycle
try checking the motor bushes,this is normaly the case with your problem.
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet washer wont run
sounds as if perhaps the hummm is coming form the drain pump not the motor, remove the front cover and you ll be able to acess the drain pump resivior, unscrew it and you find all sorts if things jammed into the pump preventing free spinning, 7 years servicing this unt never saw a bad motor, 1000's of pumps
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
