Motor oil spewing out of the intake manifold of a 05 road king when it's running
"Spewing out of the intake manifold". Check you oil tank. If the level is really low, it sounds like the scavenge side of your oil pump is not working. If the oil is coming out of the intake that bad, the engine is full of oil.
The Harley oil system is a "dry sump" type of system in that the oil is not carried in the crankcase like in the Japanese bikes but rather in an external oil tank. The oil pump has two sections in it. A "feed" section to pump oil into the engine and a "scavenger" section to pump oil out of the engine and back to the oil tank. If the scavenge section is not working, the pump will pump all the oil into the crankcase but it cannot pump it back out. When this happens, the oil is blown out of the crankcase vent system and into the intake manifold.
You need to check the operation of your oil pump.
Good Luck
Steve
