Question about Hoover UH70400 Bagless Upright Vacuum
Uh70400 brush won't turn
Red light flashes, brush won't turn. took cover off and no power to brush motor swapped the switches still nothing could the curciut board be bad?
I have a sebo x4 , when I switch it on the red lights flick on and off and nothing happenes
The red lights should flash very quickly upon vacuum start-up (normal). If the motor is not turning on there is likely a problem with the motor or power supply board. The lights flashing does indicate that you are getting power to the PC control board. If your vacuum is under warranty, this would likely be covered. I have included a link to the parts list for your reference. http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Oct 05, 2014 | Sebo X4 Bagged Upright Vacuum
My Sebo X4 does not switch on, when powered up two red lights flash momentarily. There was a buzzing from the black box underneath but that has now stopped. I changed the bag yesterday as it said it w
Your red lights flashing momentarily is normal start-up. The fact that your servo motor is operating tells you that you are getting power. If the vacuum motor does not turn on, you likely have a problem with the motor itself or the power supply board that feeds power to the motor. These items should be covered under warranty. However, if your vacuum is outside the manufacturers warranty, you can replace either of these parts fairly easily with only a phillips head screwdriver.I have included a link to the parts list for this machine. We do stock both parts. http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Sep 24, 2014 | Sebo X4 Extra Bagged Upright Vacuum
I have a Dyson DC28 animal vacuum and the beater brush will not turn. It has one flashing white light and a red flashing light.
It appears that the drive belt is not adjusted properly or has stretched. THe gunk that vacuums pick up can also affect the belt in amking them too slippery to drive. Check it out.
Mar 03, 2013 | Vacuums
Faithful Sebo X1 upright, about 12 years old, stopped working today. I replaced old with new dust bag, checked all dust paths were clear, checked main brush was clear/clean, and drive spindle rotated OK...
At 12 years, this vacuum has had a good long life. I suspect the motor is shot, but it could be due to faulty wiring and connections. A bad switch, break in the power cord, and worn brushes in the motor are other causes.
I recommend taking it to a shop for diagnosis and repair. You may be better off buying a new vacuum if the cost of repair and parts seems excessive.
Mar 01, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
No motor when switched on and 2 red lights flash
Your Sebo has switched itself off to prevent damage. The flashing red lights indicate that the brush roll is jammed and that there may also be a blockage somewhere. You should take the brush roll out and make sure it is clear of obstruction, and also check for blockages (in the inspection flap on the underside, and in the plastic pipe and the flexible hose), and check the condition of the filter in the bag compartment. If the brush roll is clear and the problem persists, you should seek help from a professional repairer as something is probably broken inside (although with Sebos this is extremely rare). Good luck!
Jan 29, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Dyson DC 24 pick up head wont spin
- Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Jun 20, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Front wheel problem
I would send it to protechrobotics. they will test all your components and let you know what needs to be done. if the repair is more than it's worth--they will help you out too.
http://www.protechrobotics.com/
Apr 07, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Miele SEB-213 powerbrush stopped working
Pull the head cover off to check the belt, if the belt is ok then it might be the power connection between the handle and the power head shaft. If the red light is on the power head, then its not the connection
because its getting power. Now some heads have a reset button on them,you could check this also.
With the cover off the power head, remove the belt, now turn it on, and be careful, but try to make the motor shaft spin,with one finger, because if it does start to spin you do not want to hurt your finger.
If the motor starts to spin,put the belt back on, if it does not spin again, the motor is too weak.
If it does not spin at all, the motor is bad.Hope this helps you,and you get it working.
Mar 24, 2009 | Miele SEB 213-2 Vacuum
Hoover UH70400 Bagless Upright Vacuum Logo
143 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
