My final portfolio of SUS 1501 does not appear on the assignment list please send me one, or where can i send my portfolio
What was the previous ministry of Ajay Chandrakar?
In 2003, he was allotted the portfolios of Panchayat and Rural Development Minister as well as a Minister of Parliamentary Affairs in the Chhattisgarh government. In 2004, he was also assigned additional portfolios of Science and Technology, Technical Education, and Manpower Planning. Due to a reshuffling of the cabinets in 2007, he was made the Minister of Higher Education.
Sep 23, 2016 | R8 Your Politician Deil eireann App
What kinds of briefcases are there?
Briefcases can be of three kinds:
Portfolio: a handle-less case to be carried in the hand or under the arm.
Folio case: a portfolio with a retractable handle.
Attache' case: "a box-style case made of leather (occasionally aluminium), scrunched over a hinged frame that opens into two compartments. It was traditionally carried by an attache', a diplomatic officer attached to an embassy or consulate officially assigned to serve in a particular capacity. In recent years, leather pouches (usually slightly larger the size of standard paper, 8.5 x 11) with a zipper sealed compartment has been referred to as attache''s or poche document holders." (Wikipedia)
Nov 11, 2013 | Luggage & Travel
No audio in my dell inspiron 1501.Send a driver link.
Hi
you can get the drivers from the link below, then select the operating system from the drop down list, then select the Audio
Hope this help
Please click here
Aug 10, 2010 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 cannot indentify ac adapter
try this first. drain the flea power. remove batter and ac adapter. press and hold on the power button for 10 seconds. plug back ac adapter and battery. go online to http:support.dell.com then download the latest bios update.
once you reach the dell support site select on support for home users. then drivers and downloads. enter the service tag.
when the list of drivers and updates are listed make sure you selected the correct operating system. look for the BIOS then download it via browser. (do not download the manager)
after the download run or install the update.
If all fails. try a diff ac adapter if same problem message appears then replace the motherboard. else replace ac adapter.
Mar 30, 2010 | Dell Inspiron 1501 Notebook
Unable to assign optical and digital inputs to other inputs
It won't let you assign the same input twice. Check to see that DVD is not already assigned to any other In(x) function.
From the manual:
• You cannot select a specific item more than once.
• You cannot assign the same input source to both “IN (2)” and
“IN (3)”. For example, you assign “CD” to “IN (2)”, “–––”
appears in “IN (3)”.
Mar 16, 2010 | Yamaha RX-V363 Receiver
Sometimes a shadow appears when it changes scene and the black is a bit hazy
This problem happens to plasma TVs usually due to the Z SUS part, Z SUS board and Z Drive Board, malfunctioning. The Z SUS is responsible in resetting the screen for the next picture to appear. If it malfunctions, the image of the previous picture freezes and appears as shadow. Usually, the last image on the screen when you turned the unit off appears when you turn it back on before the actual picture appears.
The usual fix for this is alignment. That is, adjusting the voltages that powers the boards to an appropriate value that is indicated on the back of the panel. You may need the service of a qualified technician to perform the alignment.
I hope you find this information helpful.
Nov 05, 2009 | LG 42PX5D 42 in. Plasma HDTV
Black screen on HP PL4260N 42? Plasma HDTV
The problem is the "Y-SUS" board. It is inside the set on the left side with several aluminum heat sinks, under the left side brace bar. You can order this board from Union Electronics at www.ued.com .Search for part number: TNPA3243AB-PA
It lists for about 115$
Mar 19, 2009 | HP PL4260N 42 in. Plasma HDTV
Gulbeyaz_hellokitty@hotmail.com
This is directly from Logitech:http://logitech-en-emea.custhelp.com/
"Logitech MouseWare Software:
1. Right click on the Logitech white mouse icon in the System Tray and select "Mouse Properties".
2. Click on the "Buttons" tab and your pointing device should be shown. If you have more that one mouse connected, select the mouse you wish to program by clicking on the "Devices" tab, and select the mouse you wish to program from the drop down menu, then go back to the "Buttons" tab.
3. Scroll down the list of buttons and select the button you wish to program, and click on the function to highlight it.
4. Now click on the "Modify" button. A "Modify Button Function" box will appear with a drop down menu. Select the button assignment you wish to use and click the "OK" button. Now click the "Apply" button to save your changes.
Using the "Keystroke" button assignment.
If the button assignment or keyboard command you want is not listed under the button assignments, you may want to use the "Keystroke" button assignment. Using the MouseWare steps above select Keystroke under Step 3. The "Keystroke Assignment" box appears. Click your mouse cursor into the box that states "Unassigned". Now press the key or combination of keys you wish to use and click the "OK" button. The function should now be displayed in the current list of button assignments. Click the "Apply" button then the "OK" button."
Hopefully this will help. Please let me know if it doesn't.
Nov 25, 2008 | Logitech Cordless Click! Mouse
Setting up a speed dial
from the website:
How do I set speed dial for one of my contacts? First, find the contact in your Contact List, highlight it, and press OK. Then select Options -> Speed Dialing and press OK.
Choose one of the numbers from the list and select Assign to assign it to your contact. You can now use 1-Touch Dialing for that phone number. Just press and hold that assigned one or two digit number instead of dialing the contact's entire phone number.
Sep 16, 2007 | Kyocera K10 Royale Cellular Phone
Computers & Internet Logo
376 people viewed this question
David Payne
David Payne
