Question about Samsung WF337AA Front Load Washer
Front load samsung washer wire ring came off door gasket
  • 1531 Answers
SOURCE: I have a Samsung front load washer model #
to properly install this you nee to remove the retaining spring on the front of the boot.
then remove the lid.
next remove the four screws that hold the control panel in place.
then remove the four screws that hold the fron panel in place ther may also be two screws on the bottom of the front panel.
once you remove the front panel you need to set it aside but the door lock switch is still attached so be carefull.
one you remove the front panel you can get to the other retaing spring and remove the boot.it is easier for me to also remove the counter weights on the front of the tub.to put the boot back on.i hope this helps would like to here more on your progress
Posted on Feb 02, 2010
  • 196 Answers
SOURCE: i have a samsung front
This means your drain is blocked. You may have access to it through the front at the bottom but If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
Posted on Mar 01, 2011
  • 6277 Answers
SOURCE: samsung silvercare washer stopped running and now
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor. The bit about checking the motor is near the end ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution accordingly.
Thanks and good luck!
John C
Posted on Apr 09, 2011
SOURCE: I have the Samsung WF448AAP/XAA
I have the same problem. Did you manage to get the spring back on???
Posted on Nov 21, 2011
caroldon
  • 17129 Answers
SOURCE: How do you remove the door gasket on the samsung wf410 front loading washer?
Please check this link for tips to replace the gasket.
click on Door seal
Posted on Aug 18, 2012
How to Replace rubber seal on front load washer
The rubber seal on your washer and similar front loading washers is a relatively easy repair. The seal is held onto the front washer panel and the fixed inside washer drum with separate spring-loaded rings that are reusable. So, don't throw them away! You need to remove the front ring from the front panel before you can remove the front panel. With the ring removed the gasket should be pushed into the washer; noting any drain holes, so that you can reinstall the new gasket in the same orientation. Once the outer ring is removed and the front panel is out of the way, you will have access to the ring holding the gasket to the drum. After the inside ring is removed, the gasket should pull off the fixed washer drum. You are now ready to install the new replacement gasket.
The amount of disassembly of the front of the washer is your option if it interferes with the installation. The door is usually heavy and it is useful to remove it from the front panel. Usually, a couple screws holds it in place. Removal of the front panel may also involve removal of the top of the washer and moving the control panel out of the way so that you can access the screws holding the front panel onto the frame of the washer. The locking latch may have to be temporarily removed but can be left in place if you simply push the front panel out of the way to have access to the inside gasket ring. It is useful to take pictures of each stage of the disassembly process to make sure your reinstall everything as it was.
Installation of the gasket starts with reattaching it to the fixed washer drum flange and then replacing the spring-loaded ring to hold it in place. Make sure the gasket orientation matches the original position. After the gasket is attached to the drum, you can now reinstall the front panel. If you unscrewed the latch mechanism when you took off the panel, now is the time to reinstall it as it can be manually held in place behind the gasket. The door can usually remain off the front panel until installation of the gasket onto the front panel is complete. Now bring the gasket forward and reinstall it on the flange of the front panel; secure it in place with the spring-loaded ring. Your gasket is now reinstalled. Simply reinstall the door and your repair is complete.
Tools needed include a blade screwdriver to help pry the rings off the gasket seal and one or two specialty screwdrivers (usually Torx or Philips) to remove the front panel.
Aug 05, 2014 | Frigidaire Washing Machines
How do I replace the oring gasket on a front loading samsung wash machine model number wf219anw/xaa
I can tell you how to fix one on the WF218ANW/XAA washer. Your model may be the same. You need to take the top panel off the washer by taking out two screws on back panel. You need to remove the control panel and place it on the top of the unit (it is attached with electrical cord). You need to talk out the detergent tray (press the clip in the middle). You then take off the front panel. it is not necessary to take off the door; however, to remove the panel you will need to remove the door latch mechanism on the inside of the door. To remove front panel, there are also two screws on the bottom of the unit. Once you have the front panel off, remove the old gasket by loosening the two springs rings. Pay attention to how the gasket is installed before removing. Replace gasket by installing inner portion first and replacing spring ring and tightening. Put all the parts back on the washer and install the outer portion of the gasket (with the spring ring). Samsung charges $130 to do this in my area and it's a pain in the neck.
Aug 11, 2010 | Samsung WF337AA Front Load Washer
Need to reinstall gasket
Unplug the machine and carefully pull the edge of the door gasket near the door opening. Put the lip of the door gasket properly over the lip of the door opening. Check that it is properly seated before putting back on the retaining hoop around the lip of the door opening and the gasket. Replace the retaining hoop if it holds the door gasket loose.
Feel free to update me about the result and if you need further assistance.
Jan 24, 2010 | Maytag MAH8700A Front Load Washer
Rubber ring ripped
You can buy and fit a new door gasket if you have the required mechanical knowledge
Take the power off , the top off remove the fitting band take off the old gasket and re-assemble in the reverse order
Jan 03, 2010 | GE WSXH208A Front Load Washer
My kenmore he2 plus washer door gasket is loose.
it goes on the groove in the gasket at the door , the side view of the gasket would be a V, it goes right in the middle. make sure the gasket is first snug on the metal frame groove. the spring is very tight, start at top then work down, use a flat screwdriver to pry it in at bottom. it may help to wet the gasket
Apr 27, 2009 | Kenmore HE2 Plus Front Load Washer
Rubber gasket Bello!
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
Apr 29, 2008 | Bosch WFMC 3200 Front Load Washer
Front Door gasket and ring
no trick or technique - just a pain to do. don't be afraid to stretch it and if done as a two man job its far easier. one way i thought of was to make a former of approx the right diameter and slip the ring from the former on to the door boot
May 14, 2007 | Bosch WFMC 3200 Front Load Washer
Samsung WF337AA Front Load Washer Logo
20 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
