How can I solve a system error E100 on a Canon printer MF4010?
Please My printer is canon 1023if. Now my printer has error E100. How solve this error. If can explaim by video file.
Please see this explanation. It's for a Image Runner 1022A which should use the same error codes.
Thread E100 error code in Canon IR1022A
Please unplug the unit before trying to fix anything in the laser unit, it may damage your eyesight.
Jul 18, 2016 | Canon Office Equipment & Supplies
What is responsible for system error e225
have listing of most common codes here:
http://www.visualhawk.vcc.ro/canon_error_codes_en.html
system error e225 refer to bad connection or power failure to the scanner, sometime can be solved, please follow this procedure:
1. switch machine on and wait till fully initialize, while it is "alive" disconnect power cord
2. leave disconnected for 10min
3. if possible - connect to known working different power socket (directly to the wall socket! no extensions, no power boards!)
4. wait till fully initialized, check if error still display, if not - problem solved,
if still error is displayed, go to canon site (this is not us unit, select therefore your appropriate division, somewhere there find contact and ask them for firmware update:
canada:
http://www.canon.ca/inetCA/en/serviceDetail?m=load&id=5&sid=28&mid=0002200586&type=S
australia:
https://www.canon.com.au/about-canon/contact
europe:
http://www.canon-europe.com/For_Home/Product_Finder/Multifunctionals/Laser/i-SENSYS_MF4380DN/
hope this will help you find correct solution, do not forget to vote...
Jan 12, 2015 | Canon I-sensys MF4010 All-In-One Laser...
System error e100
m/c on go additional key then printer then printer reset then yes then power cycle hope problem was solved
Jan 25, 2014 | Canon imageCLASS Office Equipment &...
SYSTEM ERROR E100 on canon IR1018
Main cause The laser driver/BD PCB is faulty (laser activation failure, BD
detection fault). The DC controller PCB is faulty. The image
processor PCB is faultly.
or drum is faulty.
Oct 20, 2012 | Canon IR1018J Black and White Copier
How can i solve a system error e225 on a canon printer mf4010
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Nov 22, 2011 | Office Equipment & Supplies
ERROR E225
system error e225 on canon mf4010
Jun 04, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
Jul 15, 2009 | Canon iR 2016i Black and White Copier
System Error E100
Most likely, the tab on the rear side of drum unit has broken off. Thus causing the Lazer Shutter not to open. There are 3 or 4 other possibilities other than replacing the drum unit.
Jun 02, 2009 | Canon iR 2020i Laser Printer
Solve System Error E100
Hi
E100 is laser related error.
You can try to reconect the conectors on dc controler board, and on laser unit, clean the laser, check if the laser shuter is broken.
If notthing helps the next step would be to chnage the laser unit and/or dc pcb
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
24 people viewed this question
k24674
jasbo
jasbo
