How to replace a canon c5051 ITB belt
How to replace canon c5051 ITB belt
3 Suggested Answers
muleskinner2
  • 270 Answers
SOURCE: If the Transfer belt is
Just the belt has to be replaced. P/N FB6-2930-000. Best left to a qulified tech.
Posted on Jul 27, 2011
SOURCE: Canon iR-ADV C5051 drum replacement
go to service center it is better
Posted on Nov 16, 2013
E000075 0003
E075 is the transfer belt displacement error. Remove the ITB and check if the belt isn`t a little bit to low (marks on the frame) If it is, just correct it, if it happen again, change the frame of the itb.
May 24, 2013 | Canon imageRUNNER ADVANCE C5051
E00070-0001
E070 is an ITB home postion error, if the belt was recently replaced the ITB unit may have been reassembled incorrectly. If the unit has not been recently serviced, a faulty ITB cleaning unit can soil the ITB Belt enought to where the home posistion sensor cant read correctly. Also the sensor itself could have gone out but ive only seen a bad sensor once.
Check Transfer Belt Sensor (PS51) output in I/O mode. If sensor state does not change when blocked and unblocked, suspect a bad sensor.
Service Mode * 2/8 *Copier>I/O>DC-CON>P014>BIT-7 0=Blocked 1=Unblocked. The Transfer Belt Sensor PS51 (FH7-7394-000) and the Manual Feed Tray Paper Sensor PS15 are the same. Try swapping sensors and test them in I/O mode to determine if the sensor is bad.
If sensor seems fine replace the ITB Cleaning AssyTransfer Cleaning Assembly (FM2-0082-020)
Mar 14, 2012 | Canon imageRUNNER C3170U Color Copier
E000075-0003
The E075 error code refers to the ITB belt shifting front to rear of the machine and can not compensate. There are two causes that will make this happen.
a) The machine that is not level
b) Uneven thickness of the ITB belt from front to rear.
To resolve this issue, first observe the ITB Position value of displacement in service mode under Copier > Display > Misc > ITB-POS. The range is between -300 to +450. If the value is very close to the high end or low end, perform the following:
a) Check to make sure that the machine is level.
b) After leveling the machine, run Copier > Function > MISC-P > ITB-INT in service mode
c) Check Copier > Display > MISC > ITB-POS again to make sure the value is approximately within the mid range
d) If the value in step c is not within mid range, remove the ITB belt and reverse it from front to rear and repeat the prior steps again.
This Should Only Be performed by a certified technician
Mar 07, 2012 | Canon imageRUNNER 4570 Copier
EOOOO700002
this is error related to ITB belt - Image Transfer Belt.
Probable cause can be fault on HP detection sensor or on drive rollers of ITB belt. How ever, the ITB belt needs to be removed and inspected/fixed.
Call service!
Hope that helps!
Sep 10, 2011 | Canon imageRunner C3100N Copier
E000070-0002
this error is for ITB belt( transfer belt ). Probably because it needs to be changed along with the ITB cleaning blade.
In error, the 0002 means that second sensor cant read the Itb belt.
As first aid, you can clean the back of the Itb belt and the driving roller.
Hope that helps!
May 01, 2011 | Canon imageRunner C3100N Copier
Canon 3170u error E000070-0002 how to fix this problem
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
sensor
0002 The next HP fails to be detected within
the specific period of time after the HP
of the ITB is detected.
Clean the ITB back side and the drive roller
BE CAREFULL TO REACH THE WHOLE ITB UNIT YOU NEED TO REMOVE FIXING UNIT TOP COVERS IN PAPER DELIVERY SECTION, IT NOT WOULD BE BAD TO REMOVE RIGHT DOORS OF COPY MACHINE, REMOVE ITB CLEANING BLADE UNIT,...
Jan 10, 2010 | Canon ImageRunner C-3170U Copier
Canon IR3100CN E000070-0002 During start up the code pops up and the copier don't work.
you have a broken ITB unit,
its a pretty common error code on these machines, you need to replace your ITB frame and it prob has broken the belt also
Jun 04, 2009 | Canon imageRUNNER C3200 Copier
98 people viewed this question
k24674
jasbo
jasbo
