Eu ligo a maquina e aparece o erro H1 no display do receptor do controle da Split pioneer 60.000 btu significa o que
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: quando ligo o cpu aparece erro n.302 vendor,o que eu posso fazer para consertar?
google translate
when I turn on
the cpu error appears n.302 vendor, what can I do to fix it
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Posted on Aug 04, 2012
I HAVE A PIONEER XV-EV9, THE TIMER KEEPS ON BLINKING...IT WOULDN'T TURN ON..HELP ME
Hi. I have a Pioneer XV-EV9 and it stopped working sudenly and then the timer was blinking. Probably it has heating. I sent my player to repair, but it doesnt work. Do you want to buy my unit to take parts? Or do you want to sell your to me? I'm from Brazil and you can contact me by rfelini77@msn.com. ok.
Oct 15, 2013 | Pioneer Audio Players & Recorders
Quando ligo o cpu aparece erro n.302 vendor,o que eu posso fazer para consertar?
google translate
when I turn on
hope it helps
Aug 01, 2012 | Intel Core I7-980x 6 Core Cpu, 12gb...
Minha cam digital Kodak aparece com código de
O problema ? que a lente se tornou presa no cano. Existem algumas solu??es DIY, voc? pode tentar, mas a probabilidade ? que voc? ter? de obt?-lo fixo por um profissional. Use estas por conta e risco, pois pode prejudicar ainda mais a c?mera:
Em primeiro lugar, tente conectar o adaptador de corrente alternada ou cabo USB.
Tente segurar o bot?o do obturador quando ligar a c?mera.
Olhe para a lente, e se alguns dos "c?rculos" a lente est? desalinhada ou n?o conc?ntrica e tente mexer-lo (mantendo lente da c?mera para baixo).
Tente gentilmente empurrando ou puxando a lente quando ela se estende, mas isso ? arriscado, pois pode causar a lente para escapar de seu sistema de orienta??o.
Outra maneira de fazer isso ? colocar a lente da c?mera sobre uma superf?cie dura e, em seguida, poder-se. Tenha certeza de usar um pano macio ou algo similar para n?o arranhar sua lente ou inv?lucro. Vamos empurrar a lente da c?mera para cima e para baixo algumas vezes e ?s vezes a resist?ncia do pequeno fornecida pela c?mera ? suficiente para fazer as coisas andarem novamente.
Tente acertar a c?mera perto da lente no corpo com o tecido mole na palma da sua m?o.
Fora isso, eu tomaria a c?mara a um centro de repara??o de uma avalia??o para ver se ele custaria mais do que a repara??o para substituir a c?mera.
Visite aqui: LENSS ERROR
Boa suerte.
Dec 31, 2010 | Kodak EasyShare V610 Digital Camera
Quando ligo o note da dell D600 ele aparece esse erro: Strike the F1 key to continue, F2 to run the setup utility obrigado
Oi Gustavo.
Isso acontece quando seu disco duro do laptop estiver no fim da vida. bom sinal. assim ja podes comprar um novo disco duro para substituir. veras que essa mensagem nunca mais aparecera no seu ecra. Faxa ixo meu irmao.. boa sorte.
Nov 17, 2010 | Dell Latitude D600 Notebook
NAO CONSIGO USAR MAIS O CONTROLE REMOTO, COM ISSO NAO CONSIGO FINALIZAR O DISCO......QUANDO TENTO USAR O CONTROLE APARECE NO DISPLAY " CHECK REMOTE ". E NAO SAI DESSA.
Há algum tempo o meu Gravador de DVD de mesa Panasonic DMR-E55PL-S vinha apresentando a seguinte mensagem de erro sempre que eu clicava qualquer comando através do controle remoto: CHK REMOTE2 Havia entrado em contato com o técnico da autorizada Panasonic de Niterói e ele ficou devendo-me uma solução. Como possuo outros 3 gravadores de mesa (2 Pioneer e 1 Samsung R121), apesar da contrariedade, não esquentei muito a mufa. Hoje, porém, encasquetei, e resolvi tentar, mais uma vez, resolver a má função. Após "ene" tentativas malogradas pintou o insight: - "Cacildas! Se eu faço tanta pesquisa para dirimir as dúvidas dos companheiros, por que não o faço também, para mim"? Assim, digitei no "gluglu": CHK REMOTE2 Panasonic Entre outras dicas, saquei esta: Question: - "Whenever I press any button on my remote control, I get this error message on the front panel display - CHK REMOTE2" Answer: - "Just hold ENTER and press the number indicated on the display for a few seconds, and it will fix the issue". Basta clicar ENTER e pressionar o numero indicado no display do painel frontal do gravador por alguns segundos - isto resolverá o problema. (Clicar ENTER e pressionar o número 2 no controle remoto). Tal dica serviu para o meu DMR-E55PL-S como também para o DMR-E85HS - do **** "flashcode" - devendo servir para outros modelos Panasonic da mesma linha. Soçarba... Mr. Walker
Aug 25, 2010 | Panasonic DMR-E55 DVD Recorder
Não Consigo acessar Serviço de hp plotter Calibração T610. apresentou o Código de 21.1:03 Erro, Substitui uma Estação de Serviço e continuou o Mesmo Erro, Substitui...
helo
Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Check the Primer Tubes. Reconnect the power cord and
power On the Printer.
Perform the Service Station diagnostic test to troubleshoot the problem
further
If the System Error continues, replace the Service Station .
If the System Error continues, replace the PrintMech PCA
Jul 29, 2010 | HP Designjet T610 InkJet Printer
Recording
Grupo: Participantes
PLACA DE PCTV ENCORE....?
Meu PC e windows xp...Ele é da microboard...., vem com 1gb 160Hd placa de pctv, AMD... Mas desde quando liguei meu PC pela primeira vez com o vista, não funciona a placa de pctv, depois que eu formatei, e instalei o xp, continuou não funcionando...já tentei de tdo, e naum sei mas o que fazer....
Tenho o programa ENLTV, que veio junto com a placa de pctv que é da ENCORE... quando tenho abrir este programa aparece um erro assim: " Fail to Initialize hardware!ErrorCode#E0601009 "
E no gerenciador de dispositivos, o driver " Controlador de Multimídia " com um ponto amarelo de exclamação..! Tento atualizar o drive com os cds que vieram junto com meu PC, mas nao adianta, já desistalei o drive, e reiniciei o PC, o drive foi reconhecido novamente, mas nao sumio o ponto de exclamação...
Jun 14, 2008 | Encore ENLTV-FM (EN-LTVFM)
Error code M627-31 WHAT'S THIS?
não sei o que aconteceu com minha câmera da HP, quando ligo aparece a seguinte mensagem?: Lens Error: M627-31
Mar 23, 2008 | HP PhotoSmart M627 Digital Camera
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
