Question about Panasonic WORKiO DP-1820E All-In-One Laser Printer
Copy Machine is printing copy and then an additional blank page. How do I get this fixed?
When we request for a copy to be made, it prints the copy along with an extra blank page. I have tried to play around with the settings and have not found anyway to get this fixed.
  • Panasonic Master
  • 3,320 Answers
The margin and headers and footers are to big. Select do not print hraders and footers.
Posted on May 14, 2014
Testimonial: "Mike, thank you. How do you select not to print headers and footers on the machine?"
  • 2 more comments
  • Nicole Wilson
    Nicole Wilson May 14, 2014
  •  Mike M
    Mike M May 14, 2014
    in whatever word processor app you are using.
  • Nicole Wilson
    This copy machine is not hooked up to any of our computers. It is only used as a copy machine.
  •  Mike M
    Mike M May 14, 2014
    Here are the manuals. Sometimes a copier will have a setting to insert a blank page between jobs. http://panasonic.net/pcc/support/mfp/dp-... http://ops.novacopy.com/usermanuals/Pana... there are 2 different manuals.
  • 2072 Answers
SOURCE: Panasonic DP-150PA Light Copies to no copies
Have you reseated the drum and toner?
It can be a drum cartridge problem. have you tried that?
You say copy or print, so I am asuming this is multifunction and you do both printing and copying.
1, Have you shook up the toner cartridge well.
After the drum and shaking the toner, I would suspect the transfer assembly, Off hand I cant remember of that machine has a transfer roller, or if there is a channel where there is a hair fine wire running through it.
The wire may have broken, or if its a roller making poor contact.
The laser is also possible.The transfer will be on the right had door assembly.
Take the cartridges out and see if there is anything laying loose in the machine,
what you are describing sounds more like a drum or transfer problem.
sounds very much like a defective transfer. And again, could easily be the drum.
Did you have a jam just before this occured? If you had a jam in particular in the right hand door, you broke the transfer wire.
Yeah, i am rambling huh?
Posted on Apr 10, 2008
  • 624 Answers
SOURCE: Not printing on last copy
My guess is it?s probably the print head. These things are designed to print on single sheets so even though it?s probably well within specs it still doesn?t have enough force to push an image to the last page. Less likely but never the less a possibility this could also be caused by inconsistent paper in the two boxes. Continuous feed, multi-part forms in a box are made by several manufacturers and have different characteristics. -You might try flipping the box of forms from the printer that works to the one that doesn?t just to make sure it?s not the forms. When I used to use multipart forms we would place orders for several boxes of the same form and occasionally some would be from a different manufacturer. The paper looked the same but the characteristics were way different. By the way we tried to do four-part but could never print beyond three part forms. Our fix was that we decided we only needed one in-house copy. -If the problem doesn?t follow the paper then I would suspect the print head. Panasonic print heads are fairly easy to replace and fairly inexpensive so I would try changing it out. With a lot of use the print heads do wear out so even if this doesn?t solve this problem you?ll have a spare when your vertical characters start looking wavy?. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 14, 2007
tech435
  • 284 Answers
SOURCE: Remove misfed paper code J93
J93 means = paper remained in adf . sounds like you have a problem with the reed point sensor in the adf door . little black plastic arm , right side should be dangling
Posted on Jan 13, 2009
copiersplusw
  • 136 Answers
SOURCE: Copy/Printing machine jams
This tells me your DUPLEXER is the one causing the jam, Ok like when you open the duplexer do you see the paper in their
second does your copier indicae that the duplexer is in stalled ?m print the config page to verify. if it worked ok until this incident then your paper feed tires in your Duplexer is worn and needs to be replaced, do not do this yourself call a Service tech or A dealer to do so, uf your in CT we can help.
Posted on Mar 08, 2009
  • 990 Answers
SOURCE: I get an E140 error message when I turn on the copier
Hello sir; The error code you display it means optics fan not working you have to replace it.
Posted on Aug 29, 2009
Lexmark s605 won't make a copy
Check settings from computer, try to send command from computer to scan and copy. May have to plug usb cable in to access all settings unless it's wireless only.
Apr 01, 2014 | Lexmark Office Equipment & Supplies
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Bizhub 250 slow to print files
When you ask to print the page are you asking for more the one copy? If you are there is a collate check button next to the requested sets box, in the print dialog box. Make sure its not check. Collating the print means your PC sends a copy of the file for each requested copy. IE: you print one page and ask for six copies, your PC sends the file six times, one copy of the file for each print requested.
Also because your printing from a windows application IE: Excel you should be using the PCL print driver as apposed to a PostScript print driver. The time it takes to convert the file into PostScript for the printer to process it is time consuming.
May 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
Copy Problem
is scaning working properly? check the scanner section.
Oct 16, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
Panasonic WORKiO DP-1820E All-In-One Laser Printer Logo
56 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
