Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
I have a manitowoc sd0302a maker that will make one run of ice then not put water back to make the next.
  • Kenmore Master
  • 4,654 Answers
Here is the=> SD0302A Technical Service Manual. Search this manual for Sequence of Operation From there you need to watch and listen to these events to see why the water trough is filling only one time. I am here if you have questions, Thanks John Tripp Appliance 911
Posted on May 13, 2014
  • 6 Answers
SOURCE: icemaker
Check the power conection to the ice maker. If that's ok, then I would think the solenoid that controls the water flow has gone bad. Unfortunately, you will likely have to replace the whole ice maker, I don't think they are reparable.
Posted on Feb 12, 2007
applianceboy
  • 77 Answers
SOURCE: Ice maker for kenmore 77181791
check the fill tube at the back of the freezer for ice build up. (top if it is an ice in door model) if it is plugged use hair drier to defrost. if not iced up run the ice maker and listen carefully for the water valve to come on. if you dont hear it check the voltage to it with a meter or check the contnuity of the valve. good luck
Posted on Sep 26, 2007
  • 833 Answers
SOURCE: Ice Maker
First, are you getting water at the door? If not, the filter is installed wrong or there is some packing on the filter you didn't remove.
Posted on Jan 10, 2008
  • 1214 Answers
SOURCE: ice maker won't work
Several issues can occur with this icemaker, the most common one being the shut off arm (the wire arm on the right hand side of the ice maker) is lifted into the off position.
Or, there has been
1) Mold thermostat failure
2) Mold heater failure
3) Motor failure
4) Fill switch failure
5) Water fill valve failure
Posted on Jan 20, 2009
SOURCE: Ice maker not working
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Posted on Mar 31, 2009
Water continuously runs and drips while making ice
water level sensor is bad, check Your lights on control board, it will stay off at water level light when water touches the sensor.
Apr 19, 2015 | Manitowoc SM50 Series Ice Maker
Manitowoc QM 30 ice machine ice gets slushy
Water restricted somewhere. So 1st filter; 2nd water inlet valve. You need to deep clean this machines every 3 month.
Aug 15, 2014 | Manitowoc QM30 Under Counter Ice Maker
How can i fix my manitowoc qm45a runs water but won't freeze the water?
The thickness sensor is shorting, making the machine continually harvest. Clean it and dry it. If it still happens, replace the sensor.
Aug 05, 2014 | Manitowoc Compact Undercounter Ice Machine...
Manitowoc QY0135W is this ice machine spends to much water ?
it does drain out the tank what it does not use to make into ice; so in that sense, yes.
Jan 17, 2014 | Manitowoc QY0135W-251 Half Dice Water...
Water reasavore over flowes
Replacing Manitowoc water level probe and Ice Thickness
Feb 12, 2013 | Manitowoc SY0454A S Series Ice Maker...
Manitowoc ice maker does not produce ice
If it doesn't run at all open the front panel and peer inside of the control box. See if there are any indicator lights on the control board lit or blinking. Check the plastic water curtain on the machine and make sure that the magnet is in place on the bottom right. Will need more information as to what lights are lit. Printed on the board next to each light is its corresponding function or response.
Nov 11, 2010 | Manitowoc SY0454A S Series Ice Maker...
I have a manitowoc QY0424A ice maker and the water runs over the catch basin but it still makes ice. It doesn't run over all the time but most of the time.
Turn back the pressure on the water going into your home and or if there is an adjuster on the back of the fridge set it for 1/2 less.
Are you in a house or a flat?
Mar 20, 2010 | Refrigerators
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
128 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
