Question about Maytag Washing Machines
Vibration on a312 top load maytag washer - Maytag Washing Machines
    Problem Solver:
  • 6 Answers
Broken sping that balance tub
Posted on May 14, 2014
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Posted on Sep 02, 2007
dididsaythat
  • 291 Answers
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
THENTHEREWER
  • 131 Answers
SOURCE: Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Posted on Nov 16, 2008
SOURCE: Out of balance
Installed no slip carpeting underneath machine, worked fine.
Posted on Feb 16, 2009
  • 130 Answers
SOURCE: Maytag washer MAV551EEWW top load with loose tub
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
Posted on May 07, 2009
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Maytag a312 washer shakes bad when spinning
Most likely the tub is off balance. Open the lid, wait for it to stop then move the items around in the tub so that they are more evenly distributed. Close lid and let the spinning begin. If it still shakes but not as much repeat what I suggested. Check that the machine is level and that none of the 'legs' lost anything like the rubber pieces to prevent floor scratches and movement of machine. As stated in the beginning, most likely it is an uneven load. Super simple fix.
May 13, 2014 | Maytag Washing Machines
My new Maytag Bravos HE top load MVWX500XW vibrates during spin, is this normal?
from the way you describe the issue it sounds normal, all washers vibrate at least a little or alot (depending on the balance or unbalance of the load) if it is just vibrating and not making a grinding or scraping noise it is fine, if its vibrating too much for your like, try to rebalance your load.
Oct 03, 2012 | Maytag MVWX500XW - Bravos XTM HE Top Load...
Maytag clothes washer vibrates excessively
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 25, 2011 | Maytag EPIC MFW9700S Front Load Washer
We just had a new top-load Maytag Washer delivered. When the man finished installing it, he started a wash cycle and left. When it got to the spin cycle there was a lot of vibration. It doesn't...
NO. Have you checked if he installed an anti vibration pads. This is because the high frequency vibrations caused by the spin cycle can cause annoying noise and very serious long term structural damage to you home.
Jan 12, 2011 | Maytag Bravos MTW6600T Top Load Washer
The motor is making a loud vibrating noise
Maytag PAV2300 top load making very loud squeeking noise when set at spin
Jul 09, 2010 | Maytag PAV2300 Top Load Washer
Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Nov 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Apr 13, 2009 | Maytag Neptune MAH6700A Front Load Washer
Out of balance
Feb 15, 2009 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
