I have found several installation manuals on-line, but a search on "door" and "lock" haven't helped me.
SOURCE: hobart fx25 dishwasher
I think you may have the wrong model number of the dishwasher.I work for hobart but i dont recall a dishwasher with the model number you givin me.Look on the data plate again some examples of hobart dishwashers are--sr24---am14---c44---c44a---lx18--lx30--lx40---lxi---uw50--sm6t2.Once you find the model goto this site and you will find a manual.any other questions let me know.http://www.hobartcorp.com/default.aspx
SOURCE: Kitchenaid dishwasher ---Door is locked ond will not open
are you the person i sent the manuel too
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
SOURCE: Door will not open on my KitchenAid Superba dishwasher
Hi Karissa (I LOVE your name!)
I took the opportunity of your post to upload a technical service manual for you. The "child lock" feature is only for the control functions (the buttons) and has nothing to do with the door actually locking. Here is the link to the tech manual. I hope you find it useful.
SG
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
