Question about IOGear Computers & Internet
Evoluent mouse doesn't work with kvm switch - IOGear Computers & Internet
aryanavisha
  • 3 Answers
SOURCE: ps2 mouse not working on one system
Try and use only USB or only PS2 mouse for the same.
Posted on Jan 28, 2008
SOURCE: USB mouse not recognized
I have similar problem. 2 inland KVM's (both have PS2 inputs, one has USB outputs) do not light or recognize my usb mouse with a PS2 adapter. They do recognize a PS2 ball mouse on the KVM's however. One of the computers (Sony vaio 1.5 GHz) does recognize a usb mouse with adapter on 2 other KVM's (Old Belkin and a Trendnet) (the second computer I have not tried in those configurations). Next I will try an optical mouse with a PS2 fitting. That did work with a fifth KVM at an auto business last week.
Posted on Nov 23, 2008
  • 233 Answers
SOURCE: mouse and keyboard not recognized on second computer
Sounds like KVM has a bug. Maybe their website has a fix.
Posted on Dec 21, 2008
SOURCE: KVM Switch mouse freezes
Used some extra shielding of the trackbal cable
Posted on Jul 07, 2009
  • 30 Answers
SOURCE: GCS1734 KVM with wireless KB and Mouse - GKM541R.
The GCS1734 has a different chipset inside the unit depending on when it was made. Some of the older chipsets will not work with the firmware IOGear has posted on the web site. I was given this link by the IOGear tech support and told to try using the firmwares in this download. These are firmware updates that are supposed to work with the older chipsets. If one firmware errors out on you then try using the other. One of these should work for you like it did for me.
http://www.iogear.com/support/driver/CS-1734A_1732A_V4.1.401.zip
Posted on Sep 02, 2009
My usb receiver broke for my evoluent mouse. Is there a way I can replace only the usb receiver for this mouse or do I have to repurchase the mouse?
I'm afraid you'l have to repurchase a new set of USB dongle and mouse. Dongle of another wireless mouse is not compatible with a mouse not paired with it from babric.
USB Dongle for Microsoft Wireless Keyboard and Mouse 5000
My best advice: don't buy a wirelss mouse. If you want a REAL wireleess mouse, get a blouetooth mouse.
Apr 06, 2015 | Evoluent Computers & Internet
Evoluent mouse
If there are no screws on bottom then usually it snaps apart. Look for a line or crease at bottom plate (where they are joined) and use a sharp edge like a small knife and gently try to unsnap bottom plate from mouse housing.
Nov 06, 2013 | Evoluent Right Handed Vertical Mouse 4...
Evoluent mouse keeps disconnecting.
You might try looking at this photo stream: https://secure.flickr.com/photos/austinhappel/10940723443/
Iwonder if the main cable/wire, which takes a 90 degree turn inside, under the circuit board, could be the problem. I pulled my wire/cable out from under there (after removing the board's screws), and un-crimped it. Currently trying it that way. Haven't tried the method in the photostream above.
Oct 15, 2012 | Evoluent VerticalMouse 4 Wired Left-Hand...
I have iogear miniview kvm (gcs62) keyboard works but mouse conn does not. Mluse is usb mouse with ps/2 adapter. Direct connection via usb works. used to also work with adapter but having tried it with kvm...
USB mouse with PS/2 adapter is not guaranteed to wok with GCS62. This KVM switch is designed to work with PS/2 keyboards and mice only.
When the USB mouse with PS/2 adapter is used in a computer directly, it will surely work, because the USB port can give enough power for the mouse to work. And it can easily convert the signal.
Unlike in KVM switch, the switch serves as a bridge between the mouse and the computer. And the computer does not easily recognize the mouse.
I would suggest to use a regular PS/2 mouse. Or if you want to use USB keyboard and mouse, you need to have a USB KVM switch. Model GCS632U.
Thank you and good luck!
Jan 21, 2010 | IOGear MiniView GCS62 2-port KVM Switch
My evoluent vertical mouse 3 freezes
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the CD Software program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Dec 31, 2008 | Evoluent Vertical 3 Mouse
Mouse and keyboard not recognized on second computer
Solution for the mouse. I have 8 KVM's. Most of my computers work with the KVMs. On 1 inland KVM the logitect and Microsoft optical mice do not work on one computer (but work with the other computers). They both are USB. I hook them up with a USB to PS2 adapter. If I use a ps2 ball mouse connected to the KVM the mouse works. All the Mice work if I directly connect them. Since I do not want a ball mouse I got a Frisby optical PS2 mouse. It works with all the computers on the KVM's.
I do not have a solution for the Keyboard yet. 1 computer (ASUS MB) on my trendnet or belkin 4 postion KVM does not recognize the keyboard.
Aug 25, 2008 | D-Link DKVM 2K (DKVM-2K) 2-port KVM Switch
Ps2 mouse not working on one system
Oct 19, 2007 | Inland 08216 2-port KVM Switch
Not running on startup
I occasionally have a similar problem with a couple of my KVM?s and I think it relates to the circuitry in the KVM that is supposed to fool the PC into thinking a mouse/keyboard is attached. Windows doesn?t see the mouse so it doesn?t load the drivers unless you force it. What works for me is to just start the PC and switch the KVM to that PCs port and leave it there till the computer finishes booting. Then its safe to switch to the other port, probably not the elegant solution you were looking for but it works every time.
Jun 18, 2007 | Belkin OmniView SOHO 2-port KVM Switch
KVM switch mouse trouble
Does a mouse work if plugged directly into the laptop? Sometimes you have to change a laptop in the BIOS to allow a PS2 mouse in addition or instead of the touchpad. It may not be recognizing the KVM as a mouse. Try plugging the mouse right into the laptop and see if that works.
Mar 24, 2007 | Belkin F1DK102P 2-port KVM Switch
Open Questions:
Computers & Internet Logo
224 people viewed this question
Top IOGear Computers & Internet Experts
John Anderson
John Anderson
Greg Cann
Greg Cann
Dave Harris
Dave Harris
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
