Question about Konica Minolta KONICA BR BIZHUB C10X 1-SD YLD BLACK TONER YIELD 4,500
How to remove error code service call 16H
I have just installed a new bizhub c10 transfer belt assembly and got an error code "service call 16H" immediately. how can I solve this
  • Konica Minolta Master
  • 6,271 Answers
Did you remove all the shipping parts. or go a bad belt replace with new one
Posted on May 14, 2017
My printer fuser and transfer belt did not open with error code c2152 i tried to reset the printer but not still working pls what can i do
PROBABLE CAUSES:
1. Detecting Plate not positioned properly.
Shape of the detecting plate has been modified. Install the modified Detecting Plate (p/n A02E 5033 01). Please refer to the attached procedure for
instructions on how to install the modified bracket.
Note :The following are the serial number cut-inswith themodified Detecting Plate installed:
bizhub C353 - A02E010005899 and onward
bizhub C203 - A02E012005777 and onward
bizhub C253 - A02E011005566 and onward
bizhub C353P - A02E013000060 and onward
magicolor 8650 - no cut-in available
2. Transfer Belt Retraction Sensor (PS31) mounting bracket (p/n A02E 1121 00) is fixed with a screw and it can be tilted while assembling. If the bracket is
tilted, the sensor cannot detect the Transfer Belt position properly. In order to avoid tilting the bracket, the shape of the bracket has been changed.The shape of the sensor actuator has also been changed because the actuator could touch the other parts.
PARTS
A02E 1121 00 -current Bracket
A02E 1121 11 - modified Bracket
A02E 1122 01 - current Actuator
A02E 1122 12 - modified Actuator
Notes :
a.When at the machine, please check the condition of Sensor Bracket and change the Sensor Bracket and Actuator if necessary.
b. Please refer to details in attachedBulletin Number 6252 (applies tobizhub C203/C253/C353).
3. Somepacking material was not removed froma new Transfer belt before installation. Ensure that allpacking material has been removed before the Transfer belt is installed.
4. Failure of the Transfer Belt Retraction clutch (CL7).
Check for wiring being pinched from bypass door and replace the failed parts.
PARTS
CL7 (p/n A02E M200 00)
bizhub C353 Drive Wiring/1(p/n A02E N10F 02)
bizhub C253 Drive Wiring/2 (p/n A02E N117 02)
bizhub C203 Drive Wiring/3 (p/n A02E N10Y 02)
bizhub C353P Drive Wiring/4 (p/n A02E N11A 00)
magicolor 8650 Drive Wiring/6 (p/n A02E N11C 00)
Mar 16, 2015 | Konica Minolta Minolta Bizhub C353 Copier
How can I resolve error code C-2451
Release new transfer belt unit
• A new installation is not detected when a new transfer cleaner unit (image transfer belt unit) is installed. Remedy 1 Reinstall unit. 2 Check there is a short circuit in the fuse of the transfer belt unit. 3 Check the PRCB connector for proper connection and correct as necessary. 4 Change PRCB
Feb 02, 2015 | Konica Minolta Bizhub C550
How to clear error service call (16H)
Take belt out did you remove all the tape that KMBS applied. check the inst again. also reseat the belt properly.
May 13, 2014 | Konica Minolta magicolor 2500W Laser...
I just replaced new transfer belt assymbly then error 2152 appeared
Sir, Open close front door. to reset. Ensure belt was install properly the code is for that device also check the transfer roller sponge one. ensure shipping parts remove before installation.
Jan 31, 2014 | Konica Minolta Konica Bizhub C353 Drum...
C13c8
C13C8 A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
When a new transfer belt unit is installed in a machine an internal component on the transfer belt unit changes state; this now indicates that the transfer belt unit is used
http://kmcopierservice.blogspot.com/2011/02/how-to-reset-transfer-belt-bizhub-c203.html
Apr 10, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Error 2451
Sir did you remove all of the tape from the transfer belt. when you installed it the the code has to do with new belt. Pull it out and check for any thing odd.
Apr 21, 2010 | Konica Minolta Bizhub c203 Copier
Konica Minoltra Bizhub C250 Malfunction detected C-2451 This message I got after I changed fuse on transfer unit. How to solve it, or at least what this error code means?
hi, from the service manual:
C2451:
Item:
Transfer Cleaner Unit New
Article Release
Description:
installed.
for the solution, SM says you should try refitting Transfer Cleaner Unit(misplacing could occur) or change the PWB-M board.
Feb 09, 2010 | Konica Minolta bizhub C250 All-In-One...
Error code C-2152 on C351 Bizhub All in One printer
C2152: Transfer belt separation
it seems that it the you transfer belt. to be sure, take the old one into the copier, swith off th copier, with 10 seconds or more, then swith on. the error code will disappear :-)
Dec 11, 2008 | Konica Minolta bizhub C351 All-In-One...
Fatal error Code 16H
It relates to the transfer belt unit, replace it
Jun 04, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta KONICA BR BIZHUB C10X 1-SD YLD BLACK TONER YIELD 4,500 Logo
32 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
