Question about Danby Dehumidifiers
Manual for DDR60A1CP Danby Premiere
Need a Manual for DDR60A1CP Danby Premiere for how to run this equipment?
2 Suggested Answers
  • 10 Answers
SOURCE: I have a DANBY PREMIERE
On the control panel the 3rd button from the left is the timer button. If you press this button when the unit is running the number display on the left will start blinking- use the up/down arrows to set the time that you want the unit to run.
If you press the timer button when the unit is off it will run on and off for the designated time you set- eg if you set 1 then every 1 hour the machine will switch on and run for 1 hour.
(The left # will just blink once you have the time you want just leave it and eventually the normal humidity setting reading will show)
Posted on Oct 23, 2010
My Danby premiere dehumidifier does not kick in.Could a bad compressor be the problem.
Hey Darwin,,,, By dehumidifier.. Do you mean air conditioner.. if so, the issue is more than likely you are low on freon.. have it charged and you should be fine.. If this does not fix the problem, it could be the compressor, the pressure switch or the fuse..
Jun 19, 2017 | Danby Dehumidifiers
Fan running but no water and hot on inside. 50 pint danby premiere dehumidifier
Compressor not running, possibly because refrigerant is low
Jul 30, 2016 | Danby Dehumidifiers
We have two Danby Premiere Dehumidifiers. Both have stopped picking up water. The filters are clean, the fans run and there is alot of moisture in the air? Any ideas on how to fix them?
I assume that you have already:
  • Emptied the water buckets.
  • Are sure the buckets are properly in place.
  • Are sure the bucket switches are not stuck in the full bucket position.
  • Cleaned the cooling coils.
  • Verified that the controls are set for a low humidity
  • Verified that there are no trouble lights or codes,
  • Know that the area to be dehumidified is well above freezing..
It sounds like they are both stuck in defrost mode or the compressors overheated and need to cool off. "Both" is a bothersome word. Both might imply a power surge that wiped out the controls. I would:
  1. Unplug them and let them cool off 36 hours.
  2. Check your manual for a control panel reset.
  3. Take off whatever covers I could, to let me touch the cooling coils to be sure they get cool.
  4. Plug in # one and reset the panel.
  5. Let it run and see if the coils get cold.
  6. Plug in # two and reset the panel.
  7. Let it run and see if the coils get cold.
And then decided what to do next. Hopefully the cool off and reset did it .
Good luckl.
Jun 07, 2015 | Danby DDR60A1GP 60 Pint Dehumidifier
I have a danby premiere r410 a, the compressor will not come on
Hi There,
I would love to help you, however I am not sure which model you have. R410A is not a Danby model number. The correct number can be found on the back of the unit as well as on the front cover of the owners manual. The numbers usually begin with "DDR"
Jun 28, 2012 | Danby Dehumidifiers
DANBY PREMIERE DEHUMIDIFIER R410A OWNERS MANUAL
I have 70 pint premiere dehumidifier , and it's not producing any water . What should I do ?
Jan 27, 2012 | Dehumidifiers
Looking for replacement blower fan for Danby premiere DDR 7009 REE. The part is ABS D5304-130. Any help?
If your Danby humidifier is still under warranty, call 800-263-2629. If it's not still under warranty call
800-496-6049.
Hope this helped you. Please let me know. Thanks.
Jun 16, 2011 | Danby DDR7009REE Dehumidifier
I have a DANBY PREMIERE R410A dehumidifier. I have misplaced the manual. I want to have the unit run for a fixed period of time (not all the time). HELP!!!
Oct 18, 2010 | Danby Dehumidifiers
Dehumidifiers Logo
141 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
