Question about RCA P52926 52" Rear Projection Television
Rca projection tv will not change channels - RCA P52926 52" Rear Projection Television
SOURCE: rca rear projection set
Buy new T.V.
Posted on Apr 14, 2007
SOURCE: RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Posted on Sep 18, 2007
yambo
  • 230 Answers
SOURCE: my rca
This happening because you have loose connections in the tuner. Re solder and you will see changes. About sound, did you try to move switch repeatedly ? ( back on) sometimes corrosion inside do problems contact. I hope this work for you Am here any time .. Thank you. Yambo
Posted on Aug 13, 2008
texasdan
  • 60 Answers
SOURCE: Is the tubes going out on my rear projection tv?
If the red, green, and blue colors are separated like a rainbow, then the convergence amps are going out. This set has a common problem of two electrolytic caps going bad. The caps are in the upper left-hand corner of the main board and will have a bulged top if bad.
I would not think the picture tubes are bad, especially all at once.
- Dan
Posted on Apr 28, 2009
ladywinn
  • 5138 Answers
SOURCE: RCA D52W23 tv
Front Panel Board needs cleaning or replacing Call Encompass Parts 1-800-638-3328 and for just contact switches Call Mats 1-800-628-1118
Posted on Jan 18, 2010
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Feb 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
My big screen tv keeps changing channels. when i set it on one channel
YOu channel changing button on the TV have pressed in, just try pressing the channel button in you tv so that it gets released..
This should solve your issue..
Please rate this solution if this solves your issue, or leave me comment ill help further
RNJ VINODKUMAR
Dec 17, 2009 | RCA P52926 52" Rear Projection Television
My RCA Rear Projection wont change from channel 3.
use the remote that came with it when you bought it and go into channel menu and rescan your tv channels
Feb 17, 2009 | RCA P52937 52" Rear Projection Television
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
Rca hd52w67 rear projection tv
MAY BE A GLITCH IN THE EPROM (MICRO) IN THE SET...HERE'S A QUICK FIX,,HOPE YOU ARE ON SATELLITE OR A CABLE BOX....TAKE SOME LONG AV CABLES AND TAKE THE SIGNAL "OUT" OF THE SAT OR CABLE BOX AND PUT THE OTHER END IN THE AV "IN" ON THE TV...NOW SELECT THE AV 1 (OR WHICHEVER ONE YOU USED) AND YOU WILL HAVE SOUND AND PICTURE AND YOU CHANGE CHANNELS USING THE SAT OR CABLE BOX---IF YOU DON'T HAVE THESE SIGNAL SOURCES ,,,YOU CAN ALSO USE A VCR AND CHANGE CHANNELS ON THE VCR--LEAVE THE TV ON AV1...TUNICA
Oct 07, 2008 | RCA P52926 52" Rear Projection Television
TV WILL NOT STOP CHANGING CHANNELS
Go and "hide" the remote from the set and see if that helps. Rare, but possible is a problem with the phase-lock loop circuit in the TV, or, encoder for that remote that you just hid....accordianman
Aug 10, 2008 | RCA P60920BL 60" Rear Projection...
When powered up-TV continually changes channels---RCA P52937SG MFG 2003
Verify that you don't have a stuck channel up button on the panel. Next check the solder connections on the IR receiver (3 pins). Also check the +5 supply for excessive ripple. Any of these can cause odd behavior. Let me know how you make out.
Dan
May 02, 2008 | RCA P52937 52" Rear Projection Television
TV (RCA model F32705) stuck on one channel
go to setup in menu from fromt of set. do 1st time setup ...tell it you do NOT have a cable box. if it thinks you have one it deletes all channels but 3.
Jan 04, 2008 | RCA P46924 46" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
18 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
