Question about Roadrunner Race Scooter 250cc - RR i scooter
Want to replace voltage regulator - Roadrunner Race Scooter 250cc - RR i scooter
    New Friend:
    Problem Solver:
  • 11 Answers
Sell it C:
Posted on May 31, 2014
Where is the voltage regulator located on a 1993 Cadillac DeVille
If I'm not mistaken, GM has had the voltage regulator internal to the alternator for years before '93.
The alternator has to be disassembled to repair the voltage regulator. Most do-it-yourselfers just replace the alternator.
Here's a picture that shows the regulator at RockAuto -
1993 CADILLAC ELDORADO 4 9L V8 Voltage Regulator RockAuto
Jan 20, 2018 | Cadillac Cars & Trucks
EZGO TXT, what is the voltage I should see at the battery while engine running under load?
Around 15 + or - a little. This indicates the alternator is charging.
Oct 18, 2017 | Cars & Trucks
I am getting a code telling me my voltage regulator diodes are bad on my 1996 Dodge Grand Caravan. Should I be replacing the PCM to fix the problem.
Not sure about the 96 but, voltage regulators generally have to do with the alternator. As a matter of a fact you can just replace the voltage regulator on the alternator as opposed to spending the money that it cost to replace the whole alternator, I found this out because a mechanic ripped me off and charged me for a alternator but, he only replaced the voltage regulator diode part on the alternator.. Replacing the PCM is going to be expensive and in my opinion not necessary
Feb 09, 2017 | Dodge Grand Caravan Cars & Trucks
1991 Dodge Dakota electrical problem I have replaced Alternator still will not charge where do I start from here
When you replaced the alternator, did you also replace the voltage regulator? I have read that on this truck, the voltage regulator is internal to the ECU and is located on the firewall near the ignition coil. You may be able to install a separate, dedicated voltage regulator available at your local auto parts store. Please note that you may have to rewire from the ECU connector to the stand-alone voltage regulator. Good luck.
Oct 09, 2013 | 1991 Dodge Dakota
Replacing voltage regulator
Not sure what you mean when you say Replacing voltage regulator. Would need to know the model number of the engine however as a general rule a voltage regulator is fairly easy on most of the John Deere mowers. As with any electronics when you buy they are not returnable. Depending on the engine you have a voltage regulator can be costly and may not fix your problem.
Sep 29, 2013 | John Deere Garden
My 2005 honda 600 vlx shadow when I start it it runs for a few seconds and blow the inginition switch fuse
before you replace the fuse again, get a multimeter
set meter to measure volts,
put red on battery positive
black on battery negative
replace fuse and watch voltage meter when you start it again.
if the voltage is 15.0 or higher , then your voltage regulator is over charging.
replace voltage regulator.
voltage regulators put out 12.75 - 14.50 volts.
notice the meter as you rev it up.
it should climb from 12.75 to 13.50+ just off idle at approx 2000 rpm
voltage regulators go bad.
the signs are over charging and under charging.
replace voltage regulator and retest.
hope your riding soon
Big Al
Aug 08, 2012 | Motorcycles
I have a 1999 3,8L ford mustang my tester indecates the alt is overcharging,but the batt light is coming on but it goes off! is there anything i can do to besides replace the alt?
Your alternator-mounted voltage regulator has failed. Luckily, your voltage regulator is
replaceable separately from the alternator (most voltage regulators are integral to the alternator,
and cannot be separately serviced).
Note: this works for 3.8L cobra alternators/voltage regulators only - in the 4.6L model, the
voltage regulator is an integral component of the alternator.
1999 Ford Mustang Cobra -3.8L engine
3.8L Engines
1. Disconnect the negative battery cable.
2. Remove 4 Torx® head screws holding the voltage regulator to the alternator rear housing. Remove the regulator, with the brush and terminal holder attached.
Fig. 1. The regulator and brush/terminal holder are mounted on the backside of the alternator
Fig. 2. The regulator and brush/terminal holder are secured by 4 Torx® head machine screws
Fig. 3. Hold the regulator while removing the screws to prevent the regulator from dropping out and damaging the brushes
3. Hold the regulator in one hand and pry off the cap covering the A terminal screw head with a small prybar.
4. Remove 2 Torx® head screws retaining the regulator to the brush holder. Separate the regulator from the brush holder.
Fig. 4. Slide the regulator out-the brushes will move out of the holder
Fig. 5. The brush and terminal holder can be separated from the regulator once it is removed from the alternator
To install:
1. Install the brush holder on the regulator with 2 retaining screws. Tighten the screws to 25-35 inch lbs. (2.8-4.0 Nm).
2. Install the cap on the head of the A terminal screw.
3. Depress the brushes into the holder and hold the brushes in position by inserting a standard size paper clip, or equivalent tool, through both the location hole in the regulator and through the holes in the brushes.
Fig. 6. When installing the regulator, press the brushes back into the housing
Fig. 7. Use a thin piece of soft material, like this plastic wire tie, to hold the brushes in position while replacing the regulator, or use a paper clip inserted in the hole
4. Install the regulator/brush holder assembly and remove the paper clip. Install the attaching screws and tighten to 20-30 inch lbs. (2.3-3.4 Nm).
5. Connect the negative battery cable.
Jul 07, 2011 | 1999 Ford Mustang Cobra
Where is the voltge regulator on a 1989 lincoln town car
VOLTAGE REGULATOR IS LOCATED BEHIND BATTERY.YOU PROBABLY MIGHT HAVE TO REMOVE BATTERY TO REMOVE THE VOLTAGE REGULATOR.
May 16, 2010 | 1989 Lincoln Town Car
Where is the voltage regulator located on my 91 GMC K1500 5.7L?
The voltage regulator is inside of the alternator, it is an integral voltage regulator, so if the voltage regulator is faulty, the whole alternator needs to be replaced.
Jan 08, 2010 | 1991 GMC K1500
How to change a voltage regulator for 95 Buick Park Avenue
The voltage regulator is built in to the alternator. It's better to replace the whole alternator then to just replace the regulator. The regulator and other parts like the bearing all have about the same amount of life time, unless the battery is weak which can put extra taxes on the regulator. Good luck and hope this helps.
Nov 03, 2009 | 1995 Buick Park Avenue
Roadrunner Race Scooter 250cc - RR i scooter Logo
37 people viewed this question
Top Roadrunner Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Roadrunner Audio Player and Recorder Expert? Answer questions, earn points and help others
