Question about Magnum Air 8 10 Gauge Framing Nailer
Where can i get head cap/body gasket for magnum air 33 degree nail gun
2 Suggested Answers
  • 1383 Answers
SOURCE: i have a magnum air 33degree gun, i removed the head cap to replace blown gasket, when i put it back on the gun will not fire.
Check the alignment of the of the gasket in reference to the small hole on the sealing edge(gasket has four bolt holes and one vent hole). This small hole allows air to vent from the upper part of the head when you depress the trigger casuing the gun to fire. If the gasket seals the hole or if air is leaking past the orings in the head vale the gun will not fire. If you hear air leaking from trigger when you attempt to fire the gun, most likely orings are not sealing. Remove the headvalve and lube the orings. If no air leaks from trigger when your attempt to fire, vent hole blocked. Good luck with your repair.
Posted on Aug 28, 2012
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
I have a magnum air 33degree gun, i removed the head cap to replace blown gasket, when i put it back on the gun will not fire.
Aug 27, 2012 | Magnum Air 8 10 Gauge Framing Nailer
I have a N59 FN air is leaking from the bottom of gun I put ne trigger and O rings still leaking now what.
Air leaking from the bottom of the gun (path of driver) indicates that cylinder seal orings are leaking (if without nails in gun the driver is slowly pushed down the cylinder when air is connected then cylinder seal is leaking ). Cylinder seal snaps on the top of the cylinder and should fit snug and have no cracks. Easy fix for cylinder ring. Remove head and pull out cylinder. Then remove the cylinder ring (part #n50015). Examine ring for cracks and replace as needed. Examine body of gun where spacer oring makes contact and sand fine scratches. Replace orings as needed. If air is leaking between body of the gun and nose casting, replace gaskets. Good luck.
Jun 25, 2012 | Stanley Bostitch Nail Gun
Will the 901xp use any brand of papertape 33 degree nails? I have probably 12 cases of collated papertape and would hate for them to just go to waste but the 901 is not listed as compatible.
Most Senco nail guns are great about listing out brands of nails that will work with their guns, they are not particular to using their nails. The 901 does use 33 degree nails but if Senco does not list the brand that you have then I would recommend not using them so you do not damage your gun. Maybe you can sell them on Craigs List?
Hope this helps James
Apr 05, 2011 | Senco SN901XP Clipped Head Framing Nailer
I have seen many nails that supposedly fit the senco sn4 nail gun. Some are 31 degree, some are 33 degree. All have paper collating. What angle nails should I search for to fit the senco sn4?
Senco uses 33 degree paper tape clip head, however many generic brands will label their box 30-34 degree to fit several nailers. This practice causes jams in some guns and others work fine. The goal is to save money but could cost more in the long run if gun is damaged. You can use generic (other than 33) if you take a strip of nails and place them against the outside of the rails aligned with either the line of driver path of angle of the rails. This will give you a visual as to the alignment. Best result is when the complete nail is in line with the path of driver. Next best result is when the head is in the path of driver and point of nail is slightly away from path, worst is when point hits path and head is back. Good luck
Mar 26, 2011 | Senco Air Tools & Compressors
Nail gun doesn't shoot and air blowing out vent constant.
We used nail guns for years. I still own 6 guns, but they aren't used much anymore.
You have a 'blown head gasket.'
Or there is debris from the air hose that got lodged into the gun.
There is a head gasket and a trigger gasket.
Both can blow out any time from use, lack of oil, or they can stick open from debris.
You can take apart the head and clean it up and add oil to see if that solves problem.
You can order a gun re-build kit for your model and put in the parts yourself.
You can have a nail gun repair shop do the job.
Nail guns require gun oil.
If you don't use gun for a while, oil should be put into air hose opening and then left to run down into gun. More oil is better.
If you use 3-in-1 oil or some oil besides gun oil, then it will corrode the gaskets.
When storing air hose and guns, put tape over openings so they stay clean.
Before hooking air hose to a gun, you can also put a blower on hose and blow out the line first
Oct 21, 2010 | Dewalt Round Head Framing Nailer D51845
Nail gun will not shoot and air is exhausting out top vent all the time.
Oct 21, 2010 | Garden
Wiil a 22 degree Paorter Cable FR350A Round Head
No... it will fire 21-degree nails and perhaps 23-degree nails (but sont think they exist) and it is a full-head framing nailer so it is designed for firing round head nails. Using clipped nails will likely jam the nailer as these nails are stripped closer together with overlapping heads in the nail strip and the FR350A has a full round driver so you will run into issues with clipped nails. If you are having problems finding full round head nails, you can find them on Amazon to fit this nailer. Otherwise any good tool or trade tool store that sells nailers will likely have a suitable nail supply available for the FR350A.
Feb 09, 2010 | Porter Cable Air Tools & Compressors
What brands of nails will work in my 15ga finish nailer 1000993
Here are a few tips on buying nails for your nailer. Nails are sold in two basic categories, clip head and full round head. The clip head are lower in price and are usually taped on glued together with no spacing between them. The full round head have spacing between each nail and are held together with plastic. Some nailguns can use both types. It is important to verify the angle of your gun. To measure the exact angle use a straitedge along length of rails and a protractor at the barrel of the gun. Place the protractor on the barrel with the 90 and 0 degrees aligned with the barrel and hold the straitedge aligned with the rails and the 0 degree mark. Read the angle. You may find that your gun measures a different angle. Nails are sold from 0 to 34 degree. 34 degree is usually clip head for Paslode, Senco, Hitachi and other brands. I find that many brands of nails do not list the angle, but list the name of the gun instead. This makes it difficult for non-branded guns. Take the protractor into the store and measure the angle of the nails or place the nails on the outside of the rails to see if they align with the barrel. Shop several stores because nails vary by brand. Once you verify the perfect fit, ask for a sample strip to try in your gun. When you identify the angle and type, use this information to shop for price. Most nails are imported from around the world, however there are nails still produced in the US costing more. Home Depot and Lowes do not carry a full range of nails.
=Google the internet for more info on nails such as www.nailzone.com. They sell a 33 degree nail that may fit your gun. Good luck and email me or post again with more questions.
w
Jan 19, 2009 | Northern Industrial Tools Air Tools &...
Magnum Air 8 10 Gauge Framing Nailer Logo
35 people viewed this question
Top Magnum Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Magnum Air Tool and Compressor Expert? Answer questions, earn points and help others
