Question about Brother XL-2610
The top and bottom threads won't connect, to make a stitch.
Have used the correct bobbin.Threaded the machine correctly and adjust the tension. It was working a bit and now has completely stopped stitching.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Brother Expert
  • 300 Answers
Replace the needle with a brand new "Schmetz" needle..
If it still won't pick up the bottom thread, take it in for service.
Posted on May 14, 2014
  • b_gt May 20, 2014
    I have the same problem it will pick the thread up from the bobbin but it won't form a stitch it was working now it is not help
  • BJ sewing May 21, 2014
    Replace the needle with a brand new "Schmetz" needle.. If it still won't pick up the bottom thread, take it in for service.
5 Suggested Answers
  • 37 Answers
SOURCE: My four-year-old XL3500 seems to have a tension
according to the diagram in the manual, the upper thread tension is set by the wheel/knob on top and just to the right of the thread take up lever and thread guide. If you don't have a manual, go to www.brother-usa.com they have a downloadable manual for your machine.
Posted on Jun 05, 2009
  • 79 Answers
SOURCE: I am using my new
Hi. You "feel" that the machine is threaded correctly? You should probably completely pull the thread out and start over, making certain that it is threaded correctly. Once that is done, double check to make sure the thread is pulled all the way into the tension discs. Make sure also that you have lowered the presser foot. Is the bobbin inserted in it's case correctly? Every aspect is critical to proper function. You may also want to revue your manual.
Posted on Sep 23, 2011
SOURCE: I actually have a Brother XR40 sewing machine (not
Hello.
I own a Brother XR-40 Sewing Machine.
I can not figure out how to select straight stitiching in the display area.
I only see #17 Feather Stitching.
It appears that it is locked into its memory.
Help!!!
Denice
San Antonio, Texas
Posted on Oct 28, 2012
  • 1564 Answers
SOURCE: how can I adjust the timing on a brother ls 1217 sewing machine
Unfortunately, it's not recommended for users to repair their own brother machines. It sounds like the timing is out anyway... to take it in and have it "Cleaned, Lubed, timed and the Tension repaired"
Or you could use it for target practice and just go buy another machine.
Posted on Dec 13, 2012
Tension does not seem to adjust, what can I do? Can I repair it or do I need to find a repair shop.
no connection between tension ans stitch
check that you have the thread between the tension plates and not behind them
Nov 16, 2017 | Sewing Machines
Bobbin stitch is loose. can be pulled out
When the bottom stitches are loose it usually means the machine isn't threaded correctly. Un thread the machine and take the bobbin out. Rethread the top making sure the thread is in the tension slots securely. Replace the bobbin making sure it is inserted correctly. You might also need to replace the needle.
Jul 02, 2017 | Sewing Machines
Adjusting top and bottom stitches...
the stitch length is set by the amount the foot pulls the material through
adjusting the needle thread tension is the main adjustment to ensure that both threads meet at the center of the materials being sewn
Mar 10, 2017 | Sewing Machines
Bottom stitch is gathering, but I think the machine is not threaded correctly
I would start by re winding your bobbin and making sure that it is done though all the correct tension loops. A bobbin that is wound to tight or loose can cause all sorts of problems. If that has been done then completely rethread the machine from scratch. Now go through and check all your tensions, it sounds like the bobbin tension is too loose and your stitch tension is too tight. Adjust and try again.
Good luck
Feb 12, 2014 | Euro-Pro Shark Mini Mechanical Sewing...
Singer5050 sews a little then jams top thread in pieces in bobbin area
Start from the begining.
Use your Instruction Book and make sure the machine is threaded correctly.
Put in a new needle.
Adjust the top tension to about halfway.
Fit a fresh wound bobbin that does not have all sorts of different threads still wound on it(a bad habit with a lot of people).
Make sure the bottom tension is correct.
Make sure the bobbin is fitted corectly.
Set the machine to do basic straight stitch(mid range stitch length).
Try sewing and see if the problem is solved.
Apr 19, 2012 | Singer 8280 Mechanical Sewing Machine
I have a Viking/Lisa Model. I am having trouble with my tension and I am not sure if it is the top or bottom. My bobbin thread is all of the sudden too loose.
I just bought a Viking Lisa, and also had to adjust the tension. Use the manual to make sure you've threaded the machine correctly and put the bobbin in correctly. (I wasn't getting the bobbin thread the way it needed to be.) Then gradually increase the tension on the dial inside the top cover, checking the bobbin stitches every two inches, ending up on about 4 1/2. If this doesn't take care of the problem completely, gradually increase the side tension dial, and between adjustments on both dials, you should end up where the stitches look good. Also make sure to use cotton thread; mine doesn't like polyester thread. :o)
Aug 20, 2011 | Husqvarna Sewing Machines
Model 7467. bought in april and it was working. now top and bottom threads will not form "stich". it is threaded correctly! took off face plate - nothing jamming up. machine made a clunking noise...
try changing the needle
check the top thread tension
check to make sure the bobbin is inserted in the bobbin case correctly
check to make sure the bobbin case is correctly inserted into machine
Sep 30, 2010 | Singer Confidence 7467 Mechanical Sewing...
Pfaff varimatic 6091 sew a rag quilt with jean and flannel,I can't get my tension right it seems to be funny on the bottom stitch,where shoulf the top tension be set at 4 1/2 ,when do I adjust the bobbin...
Hi! The bobbin tension rarely needs to be adjusted. First, make sure you're using the appropriate size needle and thread for your fabric (I'd probably use either a 'denim' needle or a universal size 14) and also that the upper thread and bobbin are threaded absolutely correctly. These can throw off the tension! Also, take the time to clean out the bobbin area. That can throw your stitch off also.
If the stitch on the bottom is loose, so that you see the top threads, then the top tension is too loose. If the top stitch is too loose and you see the bobbin threads on top, then the top tension is too tight.
It helps to thread the machine with different color thread on top and in the bobbin, and then stitch an inch or so on the same type of fabric as you're using in your quilt. Check the stitch. If you need to adjust the top tension, make sure the pressure foot is down! Adjust a little, stitch a few inches, and check again. Repeat until you don't see any (or very little) bobbin thread on the top or top thread on the bottom.
If you go through all these steps, and the bobbin thread is still loose (and you've tightened up the top tension), then there is a tiny little screw on the side of the bobbin case that you can use to adjust the bobbin tension. Turn the screw just a little bit (less than a quarter turn), stitch, check, etc. Once the bobbin tension is set, you shouldn't ever have to change it.
Let me know if this helps, ok?
Happy sewing!
Feb 10, 2010 | PfaFF Sewing Machines
Kenmore Sewing Machine Drop-in Bobbin Tension Adjusting Problems
looped stitches are usually caused by improper tension. when the loop is on the upper side, it may be corrected by loosening the top tension or by tightening the lower tension (turn the tension screws on the bobbin a hair at a time)
since using the machine only a few times it is best to clean the machine from dust (can use a can of air) blow air into the bobbin area and between the tension disks and under the throat plate.
make sure the machine is threaded correctly and bobbin is evenly threaded
Aug 26, 2009 | Kenmore Sewing Machines
Loose stitches on bottom
FYI.. Loops on the bottom, problem is on the top..
Loops on the top, broblem is with the bobbin.
Apr 11, 2009 | Singer Sewing Machines
Brother XL-2610 Logo
105 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
