Question about Polaroid Tablets & eReaders
Polaroid service center philippines
My daughter tablet 7" Neon has fall down and now there is no more display in her tablet only white lights i think the lcd is dmage if that case I would ask if it can be repair and
    New Friend:
  • 16 Answers
Sir it is not cover under warranty but can be possible they replace it by charging you some amount ....
Posted on May 21, 2014
Gryfox
  • 216 Answers
SOURCE: Repair of cracked LCD?
The LCD is easily replaced, but the part is expensive. Most independent shops could replace it for around $120 parts and labor. Olympus factory price is between $134 and $174 depending on any other damage.
Posted on Dec 13, 2006
  • 212 Answers
SOURCE: Authorised service center in Hyderabad, India
+(91)-(40)-66048356----call this number this is the service center number for polaroid digital cam its located in :Secunderabad, Hyderabad-500003
Posted on Jul 03, 2009
SOURCE: my camera doesnt work at all,my daughter played it & she threw it
my olympus fe340 have a black screen and when i try to take a photo it comes out black... though when i change the mode i can read everything on screen
Posted on Jan 05, 2010
SOURCE: Authorized Service center in the Philippines
My camera has no power even if i put new batteries.
Posted on Dec 11, 2010
  • 11967 Answers
SOURCE: My camera was falling while we taking a picture
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 19, 2011
Need a manual for Polaroid S7BK S7 7-inch dual camera internet tablet
The Polaroid Tablet manuals are available here: http://www.southerntelecom.com/polaroidsupport_tablets.html . Scroll down the list to the S7. The direct link to the S7 tablets is currently: http://www.southerntelecom.com/polaroidsupport/downloads/S7.pdf . (The final two letters indicate the color of the tablet.) This is the only manual available, as far as I know.
I hope this helps.
May 02, 2016 | Polaroid 7-in. Internet Tablet - Other
How do I find the tech support group I spoke with last nite about my daughters tablet
Take it to a place that works on tablets like yours, local search for tablet repair. if nothing mail it for repairs.
Jul 03, 2015 | Polaroid 7-in. Internet Tablet - Other
Polaroid s7 won't fully boot up
Check the charge of the battery. Replace the battery and check. If it do not help you; the software might have been corrupted. Contact the authorized service center to re-load the O/S.
Jun 07, 2015 | Polaroid S7 7-in. Internet Tablet
How do you fix a white screen?
Not sure what you've tried so far, but have you downloaded and installed the firmware update? You will have to download it to a Micro SD card using a computer. Once you have it downloaded, insert the card in you tablet then to a hard start up. Do this by holding the power button and the volume down button at the same time. You will be asked what you would like to do. Select install upgrade from SD card. Once that is done, restart tablet. Good luck!
Jun 24, 2014 | Polaroid 7-in. Internet Tablet - Other
How do I fix the white screen on my Polaroid Tablet S7? I cannot get the screen past the white.
either a virus, or something has become loose inside (dropped it and the LCD connector is out).... Google "screen replacement video" and see if you're brave enough to check.
Jun 24, 2014 | Polaroid S7 7-in. Internet Tablet
Kids polaroid tablet
my daughter power button is stuck down so tablet will not turn on now what can I do to fix this problem?????its a polaroid 7inc v7
Jan 04, 2014 | Tablets & eReaders
Service center philippines
no i dont think so i guess if you try and remove the back then itll mess up the wires in the tablet.
Nov 28, 2013 | Polaroid 7-in. Internet Tablet - Other
Why won't my Polaroid 7" tablet charge?
My polaroid does the same thing just hold the charger in while pushing it down but it will take a while
Aug 13, 2012 | Polaroid 7" Internet Tablet Android 4.0...
Tablets & eReaders Logo
Top Polaroid Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
