Question about Amana PTC123B35AE Air Conditioner
Is It Difficult To ADd Freon To My Amana PTC123B35AE Air Conditioner?
I've Never Done This Before --------> Amana PTC123B35AE Air Conditioner
  • 30 Answers
That appears to be what is referred to as a P-Tac. Adding refrigerant to anything can be dangerous due to the fact that it's pressurized gas/liquid. More than that, it must be added in precise quantities. Safer, ESPECIALLY if you've not done this before, to have it done by a qualified repair shop.
Posted on Jun 15, 2014
Need to Add air conditionaer coolant
R-134. Your local parts place might have a kit that has everything you need to add R-134 FREON. I've also seen them at wal-mart too. Follow the instructions exactly as written.When you say Air Conditioner coolant I am assuming that you need the Freon and NOT the Anti-Freeze that goes in the little tank mounted on the firewall.
Jul 06, 2012 | 2001 Ford Escort ZX2
Tip
How to add Freon to a Air Conditioner or Refrigeration System
Adding Freon to an air conditioner or refrigeration system takes very specialized equipment and years of experience...it would be impossible and irresponsible of me to try to tell you how to do it through a computer.
Let me explain this further….
In small refrigeration systems such as you have in a refrigerator or a beveage cooler, the amount of freon in the system can often be measured in ounces of weight. Many times, just a few ounces. To get these charged correctly takes tons of experience and very finely tuned equipment. Just removing the hoses can release enough freon to make the difference between the system working or not working. Very sensitive scales are needed to weigh in the freon. To make sure the correct amount of freon is in the system, the system must be evacuated to a complete vacum. You need to have a special pump to do this.
To add to this, most small refrigeration systems are factory charged and sealed. They do not have access ports built into the system. To do anything to these system an access port must be correctly placed in the system for proper evacuation and charging. Then also add the the equation the fact that if you need to add freon to your system, where did the exsisting freon go? Finding and fixing very small leaks also takes sophisticated detection equipment.
The next problem is the many different types of freon that are used today. Some equipment has the type used, very clearly marked, but many do not. Only knowledge and experience can tell what type freon is in the system, and then it can be very difficult sometimes.
Air conditioning systems can be a bit more forgiving, but are getting more and more difficult to analyze and figure out exactly what is going on. The many types of refrigerant and variable speed compressors are making troubleshooting very difficult. Add temperature sensors and variable speed condenser fan motors into the mix and it becomes a nightmare.
Heat Pumps are very sensitive to either under or over charging. The only correct way to charge a heat pump is to evacuate the system and weigh in the correct charge.
Leaks in heat pumps or air conditioners are often very difficult to find, also. But finding a leak and fixing to correctly is the only way to achieve a successful repair of an air conditioning or heat pump unit.
So hopefully now you can see that refrigeration, air conditioning, and heat pump system charging is not something that can easily be done without the proper training and equipment.
Oh, and did I also mention that it is illegal to handle and repair any type of system the contains any type of refrigerant with out a refrigerant handling certification in the United States? Yes, and the although rarely anyone has been charged, it still is the law.
Please call for a certified repair technician to repair any refrigeration system and do not try to do it yourself.
on Aug 18, 2010 | Refrigerators
Amana ptc123 UNIT STOP WORKING
Indoor or outside. Im pretty should the compressor has gone. If you turn it on does the indoor fan and outdoor fan work but not cooling . or does it not turn on at all.
have you checked your fuse box.
Jan 30, 2012 | Amana PTC123B35AE Air Conditioner
Describe your Problem What is the right amount of refrigerant . (charge) for the Amana Model BB20
Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
heatman101
Aug 28, 2011 | Refrigerators
Ice build-up on the front, what to do?
Check the filter and the coil for dirt...if clean then you have a refrigerant leak and need to add freon...
heatman101
Aug 23, 2011 | Amana PTH123B25AJ Heat Pump Air...
How do I take out the filter of an Amana wall ac. to clean it. Thelight keep coming on and I don't know how to take it out to clean it.
THE FRONT TOP OF THE COVER LIFTS UP AND THERE THE FILTERS ARE, THEY USUALLY HAVE A TAB TO GRAB HOLD OF .J
Jul 28, 2011 | Amana PTC123B35AE Air Conditioner
I need to add freon to my a/c unit but do not see valves can this be done by a repairman
There are no factory service valves on a wall unit, a service man can add tap valves and charge, but first the low charge diagnosis must be confirmed
Jul 12, 2011 | Amana AH123A35MA Thru-Wall/Window Air...
My Amanda wall unit keeps freezing up. Cleaned filter and coils, please advise. Thanks, Gilbert
If a AC unit starts to freeze up, then that is a sure sign that it is low on freon. A wall unit is harder to add freon to since those units generally do not have Shrader valves to purge or add freon. It is sort of like your refridgerator in that the freon is sealed in the factory and to add , a technician has to cut the evaporator tube and add a valve, then add freon, pinch the tube off and seal it once the correct pressure is adjusted.
I would say that somehow your unit has developed a leak, and will get worse.
see:http://real-estate-agents.com/tips/hvac/maintain-air-conditioner/
Jan 23, 2011 | Amana PTC123B35AE Air Conditioner
My frige is not getting cold how can i put coolent in
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
heatman101
Dec 06, 2010 | Amana ABB1927DE Bottom Freezer...
Heat setting blows cold air
you have a bad heater coil. This coil is located behind the evaporator coil in the unit. To access this coil you will need to remove the a/c from the casing. Right behind the coil you will see a metal box that has metal strands crisscrossing inside of the bos this is your heater coils. Take the model number and serail number to an appliance parts house for replacement part. Good luck on your repairs hope this helped
Dave
Nov 17, 2009 | Amana PTC123B35AE Air Conditioner
Amana PTC123B35AE Air Conditioner Logo
85 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
