Question about AMT Robot From Lost In Space Movie
How can I make it work?
New batteries. It doesn't work. What do you think is wrong with it?
I have hundai sonata 2006 GLS. V6, I instuall the new battery on The car in a wrong way which cost a problem in the gear.., now the gear doesn't shift unless I shift it by pressing on a small button...
the positive battery battery terminal is always larger than the negative and 99% of modern cars use batteries with the pos terminal to the right with terminal side of battery closest to you
Sep 22, 2012 | Cars & Trucks
No elecectrical won't start
hi lynn. the first thing i would check is battery and battery conection, after that, fuses . J would have to have more information about your dodge to determine what is wrong with it.( does it make any noises when u start up the engine? if you know the battery is ok but wont start up, u should listen if fuel pump is working after u turn key on in ignition. If fuel pump doesn't make any noises thats praboblay what is wrong solution : new pump
Sep 21, 2012 | 2003 Dodge Caravan
Battery is stuck in my new Panasonic Lumix DMC-FH25
get a suction cup that locks on. Like what they use on car GPS devices for car windscreens.
or try
https://www.stuff4crafts.com/suction-cup-hangers-1-57-6-pkg-ha626.html?currency=AUD&CAWELAID=120018150000205418&gclid=CM7Hp4nbs8cCFU5vvAodZk4L7w
Feb 02, 2012 | Panasonic Lumix DMC-FH25 / DMC-FS35...
2010 Elantra Touring - car won't start - doesn't turn over (battery is fully charged), clock/radio & A/C units don't work, and EPS doesn't work. Dealership cannot figure it out.
sounds like a fuse. check them and get back to me. If the shop you took it too cannot figure it out they probably should not be a shop. i hope they didnt get you for a diag fee. Im going to locate a wire diagram to help you figure this out.....Also you said you put a new battery in the car, check that the battery terminals are clean and tight.
Oct 06, 2011 | Cars & Trucks
Brand new Nikon 3100 with freshly charged battery will not turn on for the first time. When I install the battery and close the flap, a small green indicator light lights up, but that's it. On/Off...
Well you have 2 choices...don't go back to Best Buy because you don't want to and you'd rather live with a brand new camera that doesn't work or.....take it back!
Sep 04, 2011 | Nikon D3100 Digital Camera
Where can I buy a battery for the DX-902 Lil Driver golf cart? My golf cart doesn't work, so the first thing I think might be wrong is that the battery doesn't work. The golf cart sat in our...
Dear kimbroberg2
My husband and I did the exact same thing for our grandson when he was 8 months old. We pulled the car out of the attic last night and the battery did not work. My husband called the manufacturer customer service at 714-256-9888. He was told that the batter was too old and would have to purchase a new one. My husband called around for the item description that they suggested and found a comparable battery at Interstate Battery in our hometown. Good luck. I know we were very disappointed when this happened, but there is hope. Hope this helps.
Jun 28, 2011 | Dexton Kid Racer Battery Operated Ride On...
THE T V WILL NOT POWER ON
plug the cord into the outlet. If the wall outlet doesn't work find a different one. If the tv doesn't turn on with the remote take the plastic off of the batteries in the remote. if this all doesn't work, then there's something wrong with the tv and you should return it and get a new one.
May 16, 2011 | Tatung LD30HL Television
AMT Robot From Lost In Space Movie Logo
289 people viewed this question
Top AMT Toys Experts
Andrew Taylor
Andrew Taylor
Are you an AMT Toy Expert? Answer questions, earn points and help others
