Question about Air Lift 1998 GMC Savana 2500 Air Suspension Compressor
What could be the problem
Have 98 gmc sanoma gut off while driving have replaced plugs good battery turns over and over but just wont catch what could be the problem timing chain?
  • 3 Answers
If its shutting off while driving then the timing chain will not be the problem. Id lean more towards electrical. Ignition control module mounts under the dist cap or coil packs.
Posted on May 13, 2014
99 GMC SANOMA NO CRANK POWER TO THE STARTER IS GOOD. TURN ON KEY NO HEADLIGHTS ONLY PARK. TURN KEY NO POWER TO PURPLE WIRE ON THE SOLENOID.
Do you know what a wiring diagram is ? How to use a DMM - digital multi-meter to diagnose automotive electrical circuit's ? Looking at a wiring diagram to see what all is involved in the starter circuit , main battery cables , park neutral safety switch , starter relay etc.. Find video's on youtube . Do you have a manual or automatic trans. ? The purple wire get's B+ voltage from the starter relay in the underhood fuse / relay box .
How to voltage drop test starter motor circuit
When your car wont crank or start part 3 How to check relays fuses...
Nov 08, 2017 | GMC Cars & Trucks
On my 2004 gmc sanoma 4x4 when I turn in 2 wheel drive it seems to pull like 4x4 is still engauged.but it shows to be in 2 wheel.any suggestions thanks
the front axle actuator is stuck engaged. the actuator is located on the right side of the front axle. the part is easily replaceable.
May 06, 2015 | 2004 GMC Sonoma
How do i replace a rear freeze plug on a 2001 gmc sanoma
onlyone way i know off and thats to remove the gearbox .
Jan 04, 2015 | GMC Cars & Trucks
Cant get middle spark plug out of 1999 sanoma streeing colum in way
swivel type socket or socket with wrench style . or remove mid shaft on steering box.
Dec 16, 2012 | Cars & Trucks
I HAVE A 1995 GMC SANOMA AND I NEED TO REPLACE THE U JOINTS AND CARRIER BEARING !
if you don't have a u joint or bearing press it is very difficult to do, best bet is to reove the drive shaft and have a machine shop do the swap for you
Feb 12, 2011 | 1999 GMC Sonoma
02 gmc sanoma turns over but doesn't fire I replaced distributer,rotor,plugs,ignition coil,fuel filter, and the fuel pump turns on and the gas is getting to the fuel rails near the feul pressure sensor.
Check to see if you have compression on all cylinders. If you don't, replace the timing chain/belt. If you do check the ignition relay and fuse panel for blown fuses.
Oct 11, 2010 | 2002 GMC Sonoma Extended Cab
How to replace brake light switch for gmc sanoma 1997
brake light switch located on the brake pedal under the dash-plug and play.
Apr 15, 2010 | 1997 GMC Sonoma
1991 Sanoma Foglights and Overhead lighst wont turn on.....
Sorry to Bear BAD NEWS But the Headliner Has to Come back OUT, as I BELIEVE that SOMTHING has been DISCONNECTED, and the only way to Help LOCATE the problem in to BACKTRACK. Sounds like the OVERHEAD LIGHTS are Tied into Your Power SOURCE And its disrupting the Other Components. I Hope Hubby Can Stand REWORKING the HEADLINER. GOOD LUCK and I can ALSO be reached @ aol.com this Screen Name Is same as Aol name , Feel FREE to Hit me up for More INFO.
Mar 29, 2009 | 1991 GMC Sonoma
Code 304 won't clear new plug wirea,new coils 2002 4cyl sanoma
Code 304 is a cylinder #4 misfire. After changing plugs did you clear your code by removing the negative battery terminal for a few moments and then re-connect. Also if the code returns check your cyl #4 wire for degradtion.
Feb 19, 2009 | 2002 GMC Sonoma Extended Cab
1997 Gmc Yukon wont start
when you say it wont start will the engine turn over?
if it wont turn over i think you should check your battery connections
if the engine turns over then you need to check your fuel pressure and spark and let me lknow
Jan 02, 2009 | 1997 GMC Yukon
Air Lift 1998 GMC Savana 2500 Air Suspension Compressor Logo
42 people viewed this question
Top Air Lift Air Tools & Compressors Experts
John Trevino
Lawrence Oravetz
Are you an Air Lift Air Tool and Compressor Expert? Answer questions, earn points and help others
