Question about Nokia X3-02 Touch Type - Lilac Unlocked GSM Cell Phone
Forgot the pairing code for iNext bluetooth headset
SOURCE: no connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Posted on Mar 12, 2007
SOURCE: accept code for a bluetooth headset
If this solution doesn't work hold down both the volume up and down buttons on the head set for about 5 seconds whilst searching for a new paired device with your phone then when asked enter the code 0000 and connect
Posted on Feb 11, 2008
  • 3 Answers
SOURCE: my wireless bluetooth headset is connecting failed
please try to powercycle your phone... turn it off and remove the battery.
make sure your headset is fully charged... the indicator light should be in steady blue before pairing it
Posted on Feb 09, 2010
  • 4 Answers
SOURCE: trying to pair nokia x6 with nokia BH-214
You have to hold the button down on the headset controller for approximately 6 seconds until the little LED on it flashes blue very quickly. The X6 will see it and match a pair automatically. If you just switch the headset on and the light flashes green the x6 will ask you for a passcode ... it doesn't matter what you put in (it seems) even '0000' ....it won't match the pair. HTH
Reply
Posted on Sep 17, 2010
tinualbinale
  • 436 Answers
SOURCE: I am trying to pair
Please follow the proper instructions given below to successfully pair your Nokia E63 with the Nokia BH-213 Bluetooth Headset.
1.Ensure that your phone is ON and headset is OFF.
2.Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly.
3.Activate the Bluetooth feature on your phone, and set it to search for Bluetooth devices.
4.Select the headset from the list of found devices.
5.Enter the passcode 0000 to pair and connect the headset to your phone.In some phones,you may need to make the connection separately after pairing.
6.When the headset is connected to your phone and is ready for use,the green indicator light flashes slowly.
However if you are having problem with the Bluetooth connectivity of your phone the most probable cause may be a malware attack.It can be solved by cleaning your phone memory by entering *#7370# on your phone and restoring the default settings when prompted.Make sure you back up your contacts to the memory card or copy it to the SIM directory.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Posted on Jun 24, 2011
I forgot the cod
Once you make your phone discoverable, then put the Plantronics 230 headset into pairing mode by pressing the call control button until it flashes red and blue. The passkey code is " 0000 " (four zeros). Here is a link for the pairing instructions:
Plantronics Explorer 230 Pairing Instructions
Good luck from Headsets Direct!
Jul 14, 2011 | Plantronics Explorer 230 Bluetooth Headset
Forgot pin to emerson em227 bluetooth
I have lost the manual so i cant add my bluetooth to my phone with the pass key
Apr 13, 2010 | Southern Telecom Emerson Bluetooth Headset...
I forgot the passcode so it wont pair with my blackberry i dont know what to do ???
the problem is not on your bluetooth headset your phone set pass code try it to the other phone it working
Feb 25, 2010 | Motorola Mobility H555 Bluetooth Headset
Forgot the code
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jun 14, 2009 | Motorola Mobility H350 Wireless Headset
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
CONNECT GE BLUETOOTH TO SAMSUNG SGH-a737
For most of the Bluetooth devices the password is 0000
Apr 24, 2008 | GE Bluetooth In-ear Headset Wireless...
Nokia X3-02 Touch Type - Lilac Unlocked GSM Cell Phone Logo
18 people viewed this question
Top Nokia Video Cameras Experts
Are you a Nokia Video Camera Expert? Answer questions, earn points and help others
