Question about Kodak EasyShare ZD8612 Digital Camera
How do i fix my kodak easyshare ZD8612is when wont turn on even with batteries?
The camera wont turn on even with new batteries.
    Top Expert:
  • Kodak Master
  • 6,702 Answers
Where did you get these new batteries?
I hope you know you can't use alkaline or NiMH rechargeable batteries.
Only Lithium batteries can be used, because they do have a higher voltage.
If you are sure you have the correct batteries, check if the contacts are clean and shiny. Clean contacts always with a dry cloth or cotton swabs. Never use anything sharp in or close to a camera.
the picture down here is just to show you can't use alkaline batteries. There are also rechargeable lithium batteries for your Kodak.
How do i fix my kodak easyshare ZD8612is when wont - 0bfe424a-d882-467d-84b0-25065a6663d3.png
Posted on May 13, 2014
  • 110 Answers
SOURCE: my kodak easyshare cx7330 camera wont turn on how do i fix it
USE ONLY LITHIUM BATTERIES.
Alkaline batteries don't last long and often can't supply sufficient power on start-up... even when they are new!
Lithium batts cost more, but they last way longer than the equivalent $ value of alkaline batts.
Posted on Dec 27, 2007
SOURCE: kodak c613 will not switch on put in new batteries had this camera since xmas
What helped my camra to get working is to make sure you have the right battery.
the kodak easyshare takes only AA/lithium,AA/ni-mi,kaa2hr,AA/zr6 and AA/lr6 and akline too. It does not work for durecell batteries.Hope I helped!
Posted on Nov 02, 2008
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
Posted on May 26, 2009
lock123
  • 6831 Answers
SOURCE: kodak easyshare ls743. lens wont retract. camera error #E45 shows on screen. battery is fully charged.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
SOURCE: my kodak easyshare C813 WONT TURN ON!!
After searching and getting the run around, the only solution I've found is to BUY a new camera that IS NOT Kodak!!! I had never had a problem with Kodak until now...I WILL NOT buy this brand ever again!
Posted on Feb 17, 2011
My camera got wet
If one drops or gets a camera wet, it unfortunately voids the warranty because cameras nowadays are sensitive to such accidents.
The water could have destroyed the connection to the LCD, or blown a chip that is responsible for broadcasting the image to the LCD.
Jul 28, 2010 | Kodak EasyShare ZD8612 Digital Camera
Kodak EasyShare M340 Digital Camera
Maybe, the batteries need to be changed to new ones.
Try to use Li ion batteries as recommended by Kodak.
Jul 23, 2010 | Kodak EasyShare M853 Digital Camera
Kodak Z740 digital camera
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Feb 16, 2010 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare V530
Make sure batteries are NEW! Even half-way dead batteries will have negative actions on camera. Also if you have a memory card, try removing it and see if your camera act normal now. Some memory cards have different impact on digital cameras.
Kodak will fix any camera for $40.
May 13, 2009 | Kodak EasyShare V530 Digital Camera
Wont turn on
IT COULD VERY WELL BE THE BATTERIES YOURE USING. IF NOT YOU MAY NEED REAL TECH SUPPORT. I ALWAYS USE DURRACEL ...CHEAP BATTERIES ONLY LAST A FEW DAYS. AND 1 DAY IF YOU USE THE VIDEO.
Apr 26, 2009 | Kodak EasyShare C913 Digital Camera
Kodak easyshare Z740
I hope that helps.
Nov 05, 2008 | Kodak EasyShare Z740 Digital Camera
Camera will not turn on at all
I hope that helps.
Aug 20, 2008 | Kodak EasyShare Z740 Digital Camera
My kodak easyshare cx7330 camera wont turn on how do i fix it
Dec 02, 2007 | Kodak EasyShare CX7330 Digital Camera
Kodak EasyShare ZD8612 Digital Camera Logo
133 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
