Sagem digital recorder
Has been working fine for past 4 years. Switched on this week and it goes through the set up process and a channel number appears on the TV screen but screen remains blank.Can use remote to change channel, but still no picture no sound, even though the channel number/ name is displayed on the screen. Any ideas as to what the problem could be and how to resolve. I am going to try another Scart lead.
  • 5 Answers
SOURCE: LG HD Digital Video Recorder LST 5402P has stopped displaying menu onscreen
first i assume you are trying to watch the unit through AV. If this is the case, turn on unit, press "Display Format" on the front of the unit, keep press it till you have "YPBPR" displaying, press select on front panel, next press "Display Format" again till you come to 576i, press select. Now press menu and it should display. If this problem occurs with HDMI, simply change the display settings to HDMI, and 1080i. Hope it helps, Murder-face.
Posted on Jan 18, 2008
SOURCE: Sagem ITD 62
Yes you can disable the monitor network setting which should stop the behaviour. I have seen it too, its annoying and very odd.
Posted on Sep 20, 2008
SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Posted on Oct 13, 2008
SOURCE: Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Posted on Mar 31, 2009
Obertelli
  • 3006 Answers
SOURCE: have retuned sagem pvr 6200 and lost BBC1 and 2
The Sagem PVR 6280 is specifically listed as a model which will have problems with the retune. Although the Sagem PVR 6200 and 6200t are not specifically listed as problem models they are very closely related to the 6280/6240 models and share most of the same firmware and software.
See the address below for a chart of affected models, you'll need to contact Sagem directly on 0845 0900 316 for either an over the air update or an update DVD depending upon the manufacturer.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
Sorry I can't provide you with a definite solution but it's very likely that your model is one of those which only Sagem can sort out.
Please return the favour by rating my answer.
Posted on Oct 02, 2009
Testimonial: "Thank you - I will contact them"
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
I am unable to make the screen full size when the
you need to go into the settings on the box and turn off letterbox on the picture setting.
Mar 29, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
We are missing a number of channels including all ITV and Channel 5 since the retune yesterday. I have a Sagem PVR 6600T I have tried to do the automatic channel scan at least 6 times and each time they...
I had same problem, first reset to factory default (code should be 1234) then keep trying the auto tune. It took me about 10 goes over different days since wedn 30th, managed to get all channels last night 1st Oct.
Oct 01, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Lost BBC channels on my SAGEM PVR6200T during a retune
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Jul 06, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Sagem ITD 62
Sep 06, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Sagem PVR 62160T UK
I left it plugged in while watching a DVD for about 90 min (as Sagem and DVD are all connected up with the TV). Afterwards I noticed the Sagem was now displaying Er09. I tried pressing the green button on remote control to activate the Sagem and hey presto everything came back on (with a message saying that the download was now complete). All back to normal now. I think the 00 and flashing dashes just meant that the Sagem was downloading and that this took longer than the specified ' few minutes'. Not sure what the 'improved DTV' was though - I can't see the difference!
Jul 16, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
DVD Recorder Is Unable To Find Digital Channels
Try resetting it here is the procedure
1. open thr front lid
2. press and hold for 5 sec. the up and down buttons.
this will reset the clock and the channel settings
Ihope this helps
Jan 22, 2008 | Panasonic DMREZ27 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
