Question about Garden
Husqvarna AWD lawnmower idles too high
My brand new Husqvarna AWD lawn mower worked fine, first day out of box, second trip out, the motor is idling REALLY HIGH. How do I turn the idle down?
  • 708 Answers
There is a throttle stop screw on the carburetor, turn it counterclockwise to lower engine speed. Check the carburator bolts to make sure the carb. bo
Posted on May 13, 2014
  • 3 Answers
SOURCE: idles really high after changing the bag and hitting rock
You may have partially sheared the flywheel key when you hit the rock and this will change the timing.
Good Luck
Bart
Posted on Jun 11, 2009
  • 57 Answers
SOURCE: mower was running fine, ran out of gas, refilled
Check the jets in the carb for dirt
Posted on Aug 27, 2009
  • 52 Answers
SOURCE: I have a puch lawn mower that is idling high and
I don't know what type carb is on this one, but most have a diaphram. If the diaphram is weak it will cause this. You can purchase a new diaphram at a Lawnmower service center. It's not that hard to install.
Posted on Apr 28, 2010
Biggdex35
  • 333 Answers
SOURCE: 3.5 TECUMSEH ENGINE CRAFTSMAN LAWN MOWER. STORED
Float stuck in open position. When the gas evaporated in it there was a gunk left behind and then It was down and either froze up or there is trash keeping the needle valve from sealing up all the way.
So when you start it gas keeps pouring into the motor. It is suposed to shut off once it gets enough to run on.
Be real careful take the carb off and remove the bowl. And then the float. Take a q-tip and clean the needle valve port ou real good. And clean the rubber tip gently. Then put back together.
When it is upside down the float should be parallel with the carb. That would be the shut off point. You may have to adjust it.
That should do it. When you hook the gas line back up loosen the bowl and let gas in carb til it starts to run out. Then mow.
Posted on Oct 02, 2010
  • 6468 Answers
SOURCE: how do I stop my lawn mower from idleing high and low?
clean out the carb
Posted on Apr 06, 2012
Problems starting husqvarna 6.25 awd walk behind mower
Hi it's probably a Briggs & Stratton motor good motors first of try a new spark plug if this doesn't work give the carby a good clean blow out all the jets inside .,.good luck
Apr 05, 2016 | Husqvarna Garden
Husqvarna riding mower
It could be due to idling problems. See solutions in this video
Learn How to Fix Idling Issues on your Husqvarna Lawn Tractor
Also may need to make sure the carburetor and fuel filter are not dirty.
Aug 13, 2014 | Husqvarna Garden
Lawn mower idles low
Find a screw touching the linkage on the carb. Turn that screw to speed up the idle.
May 29, 2013 | Husqvarna 7021P 21-Inch 160cc Honda GCV160...
Lawnmower idles full speed
cange the spring
May 12, 2013 | Garden
Husqvarna lawnmower will not start after sittling idle for winter. Bought new last fall.
I fear this is stale fuel in both carb and tank, drain the tank, if the carb has a float bowl remove it and empty the contents, refill with fresh fuel and pull until it fires up.
Mar 09, 2013 | Garden
Motor will not Idle up to Medium or High
Does the engine want to bog down when you move the throttle? Or does it do absolutely nothing?
If it bogs down when you try the throttle, It could be:
water in the gas
bad or distorted diaphragm (if no float)
stuck needle valve
stuck float
May 31, 2017 | Briggs & Stratton Briggs Stratton...
I have a husqvarna YTH150 hydrostatic kohler motor 1995-1999 upon starting it takes many tries then when started its like its on a steady idle it'll idle high then low in a steady rotation until it cuts...
Sounds like fuel starvation, clean the fuel filter and lines, make sure there's no muck in the fuel tank. It's also possible the choke is sticking, although the exhaust would smoke and smell of petrol (gasoline).
Aug 20, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Apr 27, 2010 | Garden
How to set the jets on a 125 weed trimmer. The revs are too high and adjusting the idle screw makes no difference.
The idle screw is just that, for idle. The second screw is for high speed. I'm not real familiar with this motor. Try turning the second screw in or out slowly but not to far, you'll want to make sure you still maintain good throttle response. Hope this helps
Apr 26, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
What weight motor oil do I put in?
lift hood you will specks usually under hood or around in that area I usually use a good brand 30w oil
Apr 22, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
