Question about Poulan Pro 46Inch 22 HP Yard Tractor with Briggs and Stratton Engine PB22H46YT
Briggs engine tries to fire but just stops
Absx.5002vv
  • 684 Answers
Try adding a product called Sta-bil to the gas. Often when an engine sits for a long time the gas gels. The Sta-bil will dissolve the gel and varnish from the fuel system. I would also replace the spark plug, they corrode when sitting for long periods and will not spark well under compression.
Posted on May 13, 2014
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
We have a 27hp v twin briggs & strattion which back fires and surges when engine is hot
have you tried checking the lean,rich needle on the carb sounds like it's to lean. good luck
Aug 11, 2014 | Briggs AND Stratton Intek Briggs &...
My Briggs 675 series want start I put in a new spark plug and I took out the spark and put gas in hole and it still want start
clean the gas out of engine put plug back in get some startinfliuid and sray a little in carb until it starts
Jul 01, 2014 | Briggs & Stratton Garden
I HAVE A BRIGGS AND STRATTON ENGINE THAT IS NOT FIRING ,i NEED HELP
Hello Rodger. I'm George. Try this. Pull the engine cover off and using a 3 x 5 index card to set the gap between the coil and flywheel magnets. Once you do that, try and start the engine. If this doesnt work, locate the wire going to the coil. Pull it off and move it away from the flywheel to keep it from getting cut and start the engine. This will isolate the coil from all of the safety switches that come on today's mowers. If it starts, your coil is good and you have a safety switch that is causing the problem. You will have to choke the engine to get it to stop because the wire you took of the coil is your kill wire. If the engine doesn't start, your coil is bad and needs replaced. Good Luck and Thanks. George
Mar 20, 2013 | Briggs & Stratton Garden
Engine won't start getting fuel and fire crank but won't start it wants to backfire
Try posting this question under mowers. This is the measurement tools category.
Aug 27, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Engine turns over but doesn't fire.
check it for spark then check if it is getting fuel cuz that might be the problem
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman lawn tractor briggs 19hp engine, no fire to the plugs, has new coil, new plugs, seat switch, could it possibly be in the stator?
try disconnecting the black ground wire from the coil,if it starts or fires then it is a saftey switch,then it is a process of eliminating the bad switch.
Apr 22, 2010 | Briggs & Stratton Garden
Have MTD with 5 hp briggs when trying to start back pressure is so bad it stops the pull and won't start just back fires some times
sound like the key in the flywheel is sheared. when u replace it be sure to make it good and tight or it will break again
Apr 01, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
17HP Briggs Intek engine ran good then quit. Now
Intake and exhaust valves need adjustment. Intake .004, exhaust .012.
look for wear or loose rocker arm bolt before adjusting valves.
Nov 22, 2009 | Briggs & Stratton Garden
Linkage hook up for a briggs and stratton engine
wow, i have not ran into this problem yet. I am not getting any results for that engine in my usual locations, which have great diagrams. here is a link to the only diagram i can get a hold of. hope this works.
http://www.m-and-d.com/pdfs/briggs/135200-ms2810-0802.pdf
Mar 18, 2009 | Garden
Poulan Pro 46Inch 22 HP Yard Tractor with Briggs and Stratton Engine PB22H46YT Logo
53 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
