Divide the word Dangerous into syllabes - Computers & Internet
    New Friend:
  • 117 Answers
(sounds like a school assignment to me) ;-)
-count (& save) the 3 characters (1st syllable).
-start at position 4 (3+1 chars) in the string.
-count (& save) the 3 characters (2nd syllable).
-start at position 7 (6+1 chars) in the string.
-count (& save) the 3 characters (3rd syllable).
Logic:
-Initialize syllable-counter (x) to 1, position-counter to 1 (z).
-Initialize syl(x) strings to Null, where x = 1 to 3.
-Assign "dangerous" to string variable.
z = 1
y = 1
x = 1
string = "DANGEROUS"
For x = 1 to 3 DO
*Comment. read 3 chars (in a loop), add them to Syl (x).
For y = 1 to 3 DO
read a char(y) from the string at position-counter(z)
syl(x) = syl(x) + char(y)
z = z + 1
END DO
END DO
NOTE: not 100%, but close.
Posted on May 27, 2014
How to divide 1 2/3 by 3
First make 1 2/3 into a mixed fraction and then divide it by 3.
To make 1 2/3 into a mixed fraction, multiply the whole number, in this case, 1, by the denominator (the bottom number) and then add the numerator (the top number). Thus, we get (1*3+2)/3 or 5/3. Now we have to take 5/3 and divide it by 3. I was taught that in this case, dividing by 3 is the same as multiplying by 1/3. 5/3 x 1/3 = 5/9.
If you have access to a calculator you can always check this. On the calculator, do 2 divided by 3 and add 1. Now take that answer and divide by 3. Write down this answer. Now take 5 and divide by 9. Write down this answer. They should be the same.
Good luck.
Paul
Mar 17, 2015 | Office Equipment & Supplies
How to divide fractions using calculators?
To divide fractions proceed as you usually do with any number. Just make sure to enclose each fraction in parentheses. You may want to remember a simple rule: To divide a fraction by another, multiply the first one by the reciprocal of the other:
(a/b)/(c/d)=(ad/bc)
Sep 08, 2014 | Office Equipment & Supplies
Magna great divide
The Magna Great Divide does not have a quick release lever on the rear wheel.
Aug 02, 2014 | chitech Magna Womens Great Divide 24"...
How do you identify prime numbers
One trick I use is to add up all the digits and divide by 3. If the answer is even, (a multiple of 3), it's not a prime number.
57 = 5+7=12. 12 divides by 3 evenly (4), is not a prime.
59 = 5+9=14. 14 does not divide by 3 evenly, therefore prime.
999 = 9+9+9=27 divide by 3 = 9, not prime
997 = 9+9+7=25 divide by 3=8.3 not even and is prime
May 30, 2014 | Computers & Internet
Syllabication of the word Nakinilerak
Here is an excerpt from a manual for transcribing Braille.
" When it is not possible to determine the correct syllabification of a proper name in a dictionary or other source, it is often possible to find the word divided in the print text. If the entire print book In the Shadow of a Rainbow were available, it would be obvious to the student that later in the text the name Babine is divided Ba-bine, Nakinilerak is
divided Na-kin-i-ler-ak, and Nahani is Na-ha-ni. "
From this site
http://www.jjkvc.org/Documents/Instruction%20Manual%20In%20Braille%20Transcribing.pdf
Dec 10, 2013 | Computers & Internet
I want to step up the voltage of a 12voltt battery to 110 in order to power a dc motor with a dc volt of 110v
You can purchase a commercial inverter that will convert the voltge for you. This is a source I found on the web: http://aconinc.com/index.php?route=common/home
I am not familiar with them but they give you some options.
CAUTION:Electrical work and repairs can be dangerous, especially around water. There is a risk of shock or electrocution, which could result in serious injury or death. We strongly advise that hot tub electrical wiring be referred to a licensed electrician. Local code requirements for wiring vary and may differ from the educational examples on this web site. The local code regulations must be followed, with permits and inspections obtained. The installer should read and follow the hot tub owner's manual and associated electrical component owner's manuals and instructions.
Watts is Watts plus some loss. Take your load voltage (motor) times its current that will give you the watts. Then divide that number by the source voltage (battery). Multiply by about 1.2 to pick up losses, that gives you an approximation of the wattage required from your source. Divide that number by the voltage that will give you the current required by your load. When you make the connections be sure the wire sizing is large enough especially on the low voltage (battery) side.
Nov 04, 2013 | Tools & Hardware - Others
How to divide mixed numbers?
Probably the simplest is to convert both numbers to improper fractions then divide.
Some calculators can work with fractions. With one of those, simply enter the first mixed number, then divide by the other.
Aug 14, 2013 | Mathsoft Computers & Internet
3(3 divide 4) times 8(2 divide 3)
Without knowing your grade or class, I think this problem is to teach you the correct order of doing stuff in a big problem.
1. First you do the parts in parentheses: so 3 divide 4=.75 and 2 divide 3=.66
Then the problem should look like 3(.75) times 8(.66)
2. Then you multiply the number in the parentheses by the number to the left of it: so 3 times .75 = 2.25 and 8 times .66 = 5.28
Then the problem looks like 2.25 times 5.28
3. Multiply what you have and 11.88 should be the answer
Apr 18, 2013 | Office Equipment & Supplies
How do you figure out the gear ratio on a 1972 chevy blazer. the crown gear has 41 teeth
if the ring has 41 and the pinion has 10 divide 41 into 10 = 4.10 so take and divide the higher tooth count and divide by lower tooth count another Example 44 Into 12 = 3.41 Ratio good luck
Aug 17, 2011 | Chevrolet Blazer Cars & Trucks
Computers & Internet Logo
195 people viewed this question
David Payne
David Payne
