Question about Panasonic KX-TG4500 Phone
Panasonic KX-TG6711E Cordless phone
Phone display says check phone line. All connectors are in place, I even took the handset batteries out and left it off over night but still not working. Any help?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Have you check another phone jack in the home? sometimes it is a bad jack that cause it not to work
Posted on May 13, 2014
No display panasonic cordless phone
The display on that particular phone may have to be replaced.
Dec 28, 2013 | Lands Phones
I have not used my Panasonic KX-TCD200CX cordless a Month. Now when I plugged it in, it does not seem to be charging. The screen is blank even after 5-6 hours of charging.Please advise what I should do...
Possible that the battery Voltage has gone BELOW the THRESHOLD level and so will take a long time to come up so that the display light ups. It is best to see if the battery is leaked, damaged or the connectors clogged. Test the voltage on the battery and replace if the voltage is low. Also keep the phone plugged on overnight so that the circuit warms up and clears all disturbances.
Jun 17, 2011 | Panasonic GigaRange KX-TG5432 Cordless...
The line 2 ringer is off (it displayes message "ringer off line 2" on the number 2 remote phone panasonic kx-tg6700 & I cannot figure out how to turn it back on
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 20, 2011 | Panasonic KX-TG6700 Phone
My panasonic kx-tga520m cordless handset does not display caller id anymore. the second handset does display this feature. What should I do?
Because your phone was low on battery, you will not see this feature. Once you charge your phone fully, you will start receive phone calls and you will see this feature activating again.
Jan 18, 2010 | Panasonic KX-TGA520M Cordless Expansion...
Panasonic phone system, won't release the phone line
You might try removing the battery pack and see if that resets the phone. If not, you probably have a component inside the phone that has failed.
On most cordless phones, it is not cost effective to have them repaired.
Oct 16, 2009 | Panasonic KX-TG5673 Trio Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Cordless phone left outside in rain
there is a small transistor that drive the power maybe is short but nowk how to use a vom?...you will need it..just follow the circuit from the batery..good luck
Jul 27, 2006 | Panasonic KX-TG5571M Cordless Phone...
Panasonic KX-TG4500 Phone Logo
71 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
