Question about Bissell 8910 ProHeat Clear View Upright Vacuum
My formula tank is not emptying on my 8910 proheat eurka cleaner
Its not emptying the formula out
  • 39 Answers
Make sure it is on heavy traffic on the selector set. You may find it is on Clear water rinse. FYI you will find your machine will clean better and your carpet will be cleaner if you use a weed sprayer and mix your soapin it. Just spray it down fairly heavy and let it set for 10 minutes. Then just use straight water in both tanks and you will be amazed. It is like a lasagna dish if it soaks for a while it comes cleaner easier.
Posted on May 14, 2014
CompuGuy44
  • 432 Answers
SOURCE: Instruction manual for 8910 proheat cleaner
Heres the website to download the manual. http://www.bissell.com/images/UserGuides/1699_306.pdf
Posted on Jul 20, 2007
reddevil6
  • 1673 Answers
SOURCE: need to download users manual/how to install brush belt
http://bissell.com/images/UserGuides/7901.pdf
same as 8901
Posted on Jan 17, 2008
SOURCE: i have a bissell proheat 8910 steamer and my red
the rounded part of the red float goes inside the bottom part of the tank in tank. If you push the bladder down with your hand you can see grooves on the inside of the bottom tank intnak. This is where the rounded part goes. the longer more straight part of the red thing sits straight across on top of the bottom unit on the straight edge. I honestly cannot remember how exactly I got into place but I finagled it in I am sure...
Posted on Mar 21, 2009
  • 29 Answers
SOURCE: I used my new proheat 2x steam cleaner the first
You may have mislaid a piece when you took your Bissell apart to clean it after using it the first time.
I experimented with mine to try and reproduce your issue. On the bottom of the water tank, there are two pieces that can be removed from it. One of them looks like a black plug at one end, with a red rubber flange piece on the other end. If you push your finger inside the red rubber piece, you can feel a spring move up and down. This is the first piece you place on the bottom of the water tank. I suspect you have this piece, because if you didn't, water would gush out of the water tank as soon as you turned it over after filling it.
The other piece, which is the one I think you may have have mislaid, is a larger black, plastic ring with screw threads. This piece goes over the top of the first plug piece, screws onto the water tank, and holds the plug in place. The words "RECLOSE TIGHTLY" appear on mine. If this piece is missing, the water tank does not sit flat on the base of the Bissell, but kind of flops around, out-of-place, and the unit will not dispense water properly, though it may leak it.
If ithat piece is gone, it should be possible to reorder it. Start here:
http://www.bissell.com/Customer_Service.aspx
If that's not the problem, if you have all the water tank pieces, I wonder if perhaps you unscrewed one black screw to remove the clear front plastic piece from the base of the unit-- the piece through which water is drawn up off the carpet-- to clean it, and didn't get it back into place properly. Make sure the two hooks at the bottom of this piece are inserted, one per side, into the clear plastic side pieces at the bottom. If the hooks are not secured properly, before trying to reinsert them, unscrew the black plastic screw so you don't break the tab. It's easy to miss getting these one of those hooks back in right, but it's important to do that before trying to screw the clear front plastic piece into place.
Posted on Jun 12, 2009
heatman101
  • 43501 Answers
SOURCE: bissell proheat 12 amp turbo carpet cleaner, not
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
Leaks water or cleaner when setting upright
Turn the setting knob to the rinse cycle when not in use, and you have leftover cleaning solution. This is the standard setting when storing , it blocks the soap from dispensing.
Empty the water tank and rinse after each use, and store empty.
If still leaking check the lid on the soap dispenser, make sure the gasket is even before tightening down and or the gasket between the water tank and the body, make sure they seal , check if they are straight and flush where they connect..
Mar 17, 2014 | Bissell 8910 ProHeat Clear View Upright...
How do i fill the water
There is a tank within a tank design on these deep cleaners. Use warm tap water and fill the inner bladder.
The Tank-in-Tank system is designed with a bladder inside for
clean water. As you clean, the bladder will empty. Dirty water
collects in the tank outside the bladder.
Apr 20, 2011 | Bissell 8910 ProHeat Clear View Upright...
Formula dispenses too fast. I only cleaned an area 3x10 and the formula tank was empty.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
Sep 16, 2010 | Bissell 1699 ProHeat Clear View Upright...
Where do you fill the cleaning solution at on this model?
The formula goes in the SmartMix tank on the side of the machine next to the Water/Solution dial.
Below is a link to the User's Guide.
http://www.bissell.com/VideoRating.aspx?id=1555
Jun 16, 2010 | Bissell 8910 ProHeat Clear View Upright...
I have a ProHeat Bissell 8910 Series. Won't release or pick up
heatman101
yoi
Mar 20, 2010 | Bissell 8910 ProHeat Clear View Upright...
Bissell Proheat Clearview Force carpet cleaner keeps leaking water from both tanks. What can I do to fix it?
heatman101
etyyjuefh
Jan 08, 2010 | Bissell 8910 ProHeat Clear View Upright...
How do i disassemble bissell proheat model 8910 carpet cleaner to check motor
heatman101
Nov 06, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
54 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
