Question about Irulu Black 7" 4gb Mid Google Android 2.3 Touchscreen Tablet Pc Wifi free Case Bundle
How do I get into the system?
The battery is fully charged. But the screen does not light up beyond that.
    New Friend:
  • 113 Answers
You may need to reboot your tablet. Try turning it off, then at the same time, Press the "On" button, press the volume up button at the same time. Keep holding till you see the little Android light up, and you should see your tablet come back up. I think your tablet may have froze up on you. Freezing screens is common on these types of devices. Good luck.
Posted on May 13, 2014
How can I tell if my kindle is charging?
When your Kindle is charging, a lightning bolt appears on the battery icon at the top of the Home screen. The indicator light on the bottom edge of your device turns amber while the battery is charging and green when it is fully charged. If you don't see a light, your Kindle is not charging.
Amazon.co.uk Help: Charge the Battery
https://www.amazon.co.uk/gp/help/customer/display.html?nodeId=201241710
Nov 29, 2016 | Tablets & eReaders
My Kindle went on strike yesterday I cannot sweep it to turn it on. I charged it twice
Hi; you need to restart the Kindle in the hope that the capacitive touch mechanism which controls the screen swipe is not broken. First, fully charge the device by connecting it to a wall adapter and letting it charge until the power light turns green. This could take a couple of hours if the battery has fully discharged.
Then disconnect the USB cable and set it aside. Press the power button located on the edge of the Kindle and hold it down continuously for at least 30 seconds. Release the button and then press it again just momentarily as if to wake the unit up from screensaver mode. This should cause the device to boot the operating system, a process which takes a minute or two. After the reboot has finished you should be sitting at the home screen with your navigation tools and books on display. Attempt to operate the Kindle normally. If it works you are now all set. If it doesn't work, then you have a problem which is probably not user serviceable. This could be a cracked screen which is not visible, or it could be a motherboard electronic problem. Those defects can be remedied, but that requires disassembly of the Kindle which is beyond the scope of this comment.
Jan 25, 2016 | Amazon Kindle Paperwhite
What do i do if my Samsung Galaxy tab 2 isnt charging at all?
try a different USB / Charging cable. If still not resolved, replace the battery.
Oct 19, 2014 | Samsung Galaxy Tablet PC
I have had my zeepad on the charger for a few days now and it is not fully charged. What do I need to do for it to recharge?
Probably, the ac charger unit isn't good anymore. Output charge voltage& current isn't sufficient to drive your battery charge beyond 80% threshold.
Change or replace this with a new one (same ac charger specs please) and charge your tab again.
Oct 09, 2017 | Tablets & eReaders
How do i know my kindle is fully charged
It is supposed to turn green when fully charged. There is also a battery charge indicator on screen.
http://www.amazon.com/gp/help/customer/display.html?nodeId=200728630#battery
Jan 19, 2012 | Amazon Kindle Wireless Reading Device
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
Kindle not working. It will not turn on blank screen
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Feb 21, 2011 | Amazon Kindle DX 3rd Generation
My kindle wi-fi is not working. I went to turn it on and the light came on but stayed at the screen saver screen.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Nov 13, 2010 | Amazon Kindle Wireless Reading Device
?how do I charge the battery
You use one of two methods
Method 1
1. Install the battery in its compartment.
2. Plug the AC adapter
The battery will start charging, and the status light for the battery will appear amber. The light will remain amber as long as the battery is not fully charged. When the cahrge is completed, the light will turn green.
Of course, if your are using your computer while battery is being charged, it will take three to four times longer to complete the charge.
Method 2
Toshiba sells battery chargers which you can use to charge a battery outside of the computer.
Hope it helps.
Aug 26, 2009 | Toshiba Tablets & eReaders
Irulu Black 7" 4gb Mid Google Android 2.3 Touchscreen Tablet Pc Wifi free Case Bundle Logo
98 people viewed this question
Top Irulu Tablets & eReaders Experts
john smith
gbob59
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
