Question about Dewalt Heavy - Duty 31° Clipped Head Framing Nailer - D51822
I plug the air in and air comes out where the nails come out
Have put new trigger in
    Scholar:
  • 70 Answers
Morning Tommy,
Have you stripped the head valve down? You probably did the right thing replacing the trigger valve but, look at cleaning the O Rings on the inner part of the valve. It's quite common to find corrosion on the casting which prevents smooth running on the head. Best to try and remove any build up using wet & dry sandpaper - very fine grit though- and re lubricate. Whilst you're at it, check that the O Rings still fit properly. Water can be absorbed and swell them so making a very sluggish cycle.
The most common reason is that water from the compressor's receiver gets into the airline and, eventually the tools on the other end. It's alway's a good idea to drain the tank every Friday when you go home.
Regards
Alex
Posted on May 29, 2014
    President:
  • Dewalt Master
  • 1,388 Answers
Most likely the two orings that make contact with the cylinder spacer (white plastic piece around the cyl.) and the cylinder are leaking between the chambers and out the nose. Pull out the cylinder and remove all the lower parts so that you can slide the cylinder out of the spacer. Replace the two large orings (dewalt uses vinyl orings under the cylinder spacer and they fail). Reinstall using white grease and retest. Good luck.
Posted on May 26, 2014
  • 65 Answers
SOURCE: air never stops coming out of gun nail,and gun doesn't sink nails
strip and clean the gun ,you will find that replaceing the seals will help no end
best of look ian
Posted on Mar 24, 2009
  • 1388 Answers
SOURCE: Brand new unit. Used last weekend, no problem.
Orings /other parts tend to stick when nailer is new. Dewalt uses some vinyl orings that have been causing premature failure. Be sure to add a few drops of oil when used. Too much oil is not good. Wrong oil will cause orings to swell and cause problems such as yours. Your nailer's firing valve can be reset by rapping the nailer against rubber surface such as a thick rugger mat or coiled rubber air hose. Remove airline and nails, being carefull not to damage the head, rap had against rubber mat and retest gun. If it did not reset rap against nose of gun and test. If no joy, you will most likely need to remove head and manually move cylinder up/down and /or check vinyl orings for failure. Before you try to reset the gun, make sure that the safety is pushing the firing pin all the way in. Air removed, look under the trigger as you push down on safey, if it does go all the way in try bump-firing the gun (for test have nails removed). Hold in trigger and quicky /firmly strike gun against rubber pad. Good luck
Posted on Nov 15, 2010
  • 20 Answers
SOURCE: nail gun makes a slight air release sound when
oil real good get a rebuild kit
Posted on Dec 11, 2010
  • 1388 Answers
SOURCE: I have a dewalt d51844 nail gun. It blows air out
Dewalt uses two vinyl orings against the cylinder spacer seal. Most likely one or both have have failed. These orings are included in the repair kit available thru dewalt service center near you or on the web. If you have a source for orings, like a bearing retailer, you could replace with generic viton orings. Take cylinder and cylinder spacer with you so that you can fit them in. The orings should allow cylinder spacer to fit snuggly and allow the spacer to have about a 1/4 in travel without jamming. If a kit is not available, then only option is to convert to generic orings. Good holidays
Posted on Dec 14, 2010
  • 1388 Answers
SOURCE: Dewalt D51822 nail gun does not fire nail. When
There are 4 orings that cause this problem. Two are in the trigger valve installed on the firing pin. The firing pin can be seen just under the trigger, however if you replaced the valve, you could assume no problems with the trigger valve. I would take apart the old trigger valve and examine the orings on the pin. The pin should fit snugly in the trigger valve cap and also in the valve. If the orings look good and it does fit snugly, most likely valve is still good. The other two orings to suspect are installed on the cylinder inside the nailer and make contact with the bulkhead (white plastic piece that seals the cylinder note parts reference 55, 74, 11 on the parts list). For parts list and to order parts go to www.toolpartsdirect.com Good luck with your repair.
Posted on May 27, 2011
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
I have a bostich rn46 wont fire a nail just leaks air.put new trigger assembly in
depends on where the air is leaking from, if the top of cap you have a pinched o ring, from the bottom of tool you have a problem with the cylinder or seal, the trigger assembly has a broken o ring. Let me know where the air if coming from and I will try and help.
Mar 13, 2012 | Stanley Bostitch Nail Gun
I have a N80SB stick nail gun that have been leaking air from the trigger valve but was still able to shoot nails. After 3 months of discontinued use, I plugged in the air hose and fire the first nail
A new trigger valve and o-ring kit will give you a like new gun. Just remember to replace all available o-rings in the kit, lightly grease all of them as you reassemble the gun and use pneumatic oil at the beginning of the day so you won't be doing it again in a couple months.
Feb 23, 2012 | Stanley Bostitch Stick Framing Nailer...
Instructions to install trigger assembly in n60fn air nailer
Easy to do. Use 3mm roll pin punch to remove pins at trigger and one or two pins just above the trigger valve in the body of the gun. With pins removed and trigger out, nails removed and with a gloved hand, apply air pressure to gun to pop out the valve. Use caution because the valve will come out with force if air pressure is too high (reduce air pressure at compressor). Make note of grooves cut into the old trigger valve in relation to how the valve was aligned and held in with roll pins. New tva6 valve is sold on ebay for under $20. Good luck
Jul 28, 2011 | Stanley Bostitch Nail Gun
Paslode 16G finish nailer fires intermittently. Fan runs with each trigger pull but nail only fires about 1 out of 10 pulls if I'm lucky. I've installed a new gas canister so I know thats not the...
Clean it and oil it according to directions, then put a dab of dielectric grease on top of the spark plug. If this does not work ...Change the spark plug. I found one spark plug that had broken in half and made good contact intermittently which caused the problem you describe
Nov 27, 2010 | Craftsman Nailer Kit, Palm Air Driver
Air coming out behind trigger.will sink nail
there is a split o ring on the trigger assembly that needs replaced or the whole trigger valve assembly needs replaced.
May 22, 2010 | Stanley Bostitch N86S 1 Factory...
Air leaks arond trigger when depressed, but no nail fires.
Where does the air leak out from? If it leaks from the trigger DeWalt makes a trigger valve assembly part # 641006-00 list 8.89 BUT if it leaks from other areas we have to look into it deeper. If it is just the trigger valve let me know and I will give you instructions how to remove and install the new one.
Feb 05, 2009 | Dewalt Round Head Framing Nailer D51845
Once trigger is depressed, air leaks and no nail is fired....
Sounds like the trigger o-ring is damaged, either because of not being oiled frequently, or the pneumatic tool has not been used for a while. O-rings will harden up if not used. Look for a place that sells fasteners, or nails and see if they can put a new o-ring in the trigger asm. for you. If you take the gun to a place where you purchase your nails, they should repair for little or no cost. it is an easy repair if you have the tools, parts, etc.
Dewalt Heavy - Duty 31° Clipped Head Framing Nailer - D51822 Logo
101 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
