Question about American Standard Heating & Cooling
I have an American Standard Model TWV030B140A0 air handler and need a coil. Our current coil, they detected leaks and said they cannot find a coil for us. There HAS to be one out there somewhere. Anyone know of any good and reliable sites I can check out for a new/used coil that would work? Thanks so much!
  • 5 Answers
SOURCE: reset button
nope but there is a control fuse
Posted on Sep 19, 2008
  • 124 Answers
SOURCE: cleaning coils on air handler
i use a good medium bristle wire brush with smaller brisstles. gently scrape the surface of the intake side of the coil. clear a section about 6 inches square, then put a drop light on the other side of you can see light clearly through the area you cleaned then you can get by with what we call surface cleaning. continue to clean and vac with shop vac and brush, gently .do not crush or mash fins. dont get cut they are sharp. the only coil cleaner i would use is evap power self rinsing cleaner that has no alkalie or acid to eat up the coil. it disolves the algae on contact and rinses with drain condensate. after a good brush and vac you can gently use a water hose on med spray to flush thriugh the coil .put down towels, use a shop vac and **** out drain with a vac as you do it.unless you are impacted with lots of crud you can usually clean in place. if they are to bad call a servvice company and have them pump it down and pressure wash and sanitize it. with proper filtration a coil should never need cleaning, ever. get a price on an aprilair filter installed if you pay a pro to clean coil. filters last a year and no part to replace. filtration down to 3 microns and filters last a year at 42 bucks a piece. at least consider going to p[leated filters if you dont upgrade to a pro filter system. good luck, wear old clothes ,you are going to get dirty, but that is the joy of home ownership.
Posted on Oct 25, 2008
SOURCE: Rheem Air Handler will not run
We tried to bypass at the Tstat. Thanks for your time and interest.
Posted on Apr 12, 2009
  • 674 Answers
SOURCE: air handler motor stopped working
Check the capacitor before you replace the motor. It's a common problem that's easily fixed. Make sure the fan rotates freely.
Posted on May 23, 2010
SOURCE: Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
Posted on Jun 11, 2010
I have a 15 seer American Standard Heat Pump and the air handler is leaking out of the cabinet instead of the drain pipe.
ONLY GUESS BUT ONE THING IS PAN CRACKED ON EVAP COIL OR IT COULD BE COND. TO MUCH WATER FROM LOW CHARGE OR DIRTY AIR FILTERS ONE WAY THAT IS EASY TO CK IS REMOVE COVE OFF AIR HANDLER TURN OFF UNIT AND ADD A LITTLE FOOD COLORING WITH A LITTLE IN PAN AND SEE IF YOU CAN SEE LEAK USING DYE , ALSO MAKE SURE PORT LEAVING PAN IS FOR SURE UNOBSTRUCTED****** IMPORTANT THEY CLOG RIGHT WHERE IT LEAVES UNIT OFTEN
Aug 18, 2014 | Heating & Cooling
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
American Standard AC Maintenance Procedures
Open the air handler by removing the 5/16 screws on the cabinet
Sep 02, 2013 | Heating & Cooling
Wiring thermostat to a American Standard 5ton air handler I don't have the schematics Model twe6a300ab serial# e23176168 year 6-1990
On the thermosta there are terminals, what you need to do is look at the old thermostat that you are replacing and make a note to yourself; what color of wire goes to which terminals,, Rc, R, C, G, W, Y, O, ect.
This is because the installer can use any color of wire. Then just hook the wires up to the same lettered terminals. American Standard should be standard terminal setup.
Mar 09, 2010 | Heating & Cooling
Need a replacement coil for a Coleman Evcon air handler Model # AH12L10NA. I am losing freon at a rapid pace. Leak detector indicated leaks in the indoor coil in the air handler. PLEASE HELP! Thanks in...
This may be a bigger issue than you want to tackle alone, generally speaking the coil will have to be ordered from a dealer, as most wholesalers will not sell to the general public. Further, this will require brazing the new coil in, evacuating the system, installing a dryer and recharging.
Jul 12, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
105 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
ROCKIT957
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
